Post new topic Reply to topic  [ 12 posts ]
 Post subject: Tubeless carbon rims?
PostPosted: Tue Dec 18, 2012 2:18 pm
Location: Dullsville Australia /Praha 9 Ceska Republika
Seen some Corima Hutchinson branded wheels a while back but does anybody know of any recent developers of a deep carbon rim which is tubeless compatible?
PostPosted: Tue Dec 18, 2012 3:26 pm
I know lots of guys that are running any of the Reynolds Clinchers tubeless. Just be sure to use two layers of tape.
PostPosted: Tue Dec 18, 2012 4:58 pm
Just convert them with Stan's rim tape and valve. If it is a wide rim (like the Zipp Firecrest) you will probably want to use the wider 25mm tape.
Here is a review where they do this conversion to a Zipp Firecrest:
http://nyvelocity.com/content/equipment ... -clinchers
Here are the conversion products:
http://www.notubes.com/Road-Tubeless-C78.aspx
Here is a good instructional video:
http://vimeo.com/34383932
PostPosted: Tue Dec 18, 2012 5:00 pm
In reality, any clincher (alloy or carbon) can be setup tubeless. I just setup my old Edge rims (Enve) tubeless. I just used a layer of electrical tape with some Stans over the top.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Tue Dec 18, 2012 5:15 pm
Have any of you guys heard about bumps or potholes burping a tire on the road? That's what scares me. The flat could be swift and painful if it lost all air in seconds. In cross or mtb you aren't traveling as near the speed.
PostPosted: Tue Dec 18, 2012 5:43 pm
I find burping road wheels less of concern because the pressure is so much higher than, say, MTB tubeless. I've only had my first puncture on road tubeless not so long ago, and that was caused by a big staple piercing right through in two places.
CAAD10: viewtopic.php?f=10&t=107612
PostPosted: Tue Dec 18, 2012 10:52 pm
With what tires? Can you show us some pics?
PostPosted: Wed Dec 19, 2012 12:14 am
Did it flat on the ride or did you make it home? My concern is tubeless are very hard to put on my cross wheels (I imagine road tires will be harder) and I know the sealant many times fixes itself that is not always the case.
Thanks in advance.
PostPosted: Wed Dec 19, 2012 4:21 am
I'm just running some Fusion there. Were you looking a picture of the finalized setup or the taped rim bed?
PostPosted: Wed Dec 19, 2012 10:52 pm
Mind if I ask what tires you're using? Are they UST? I really would not worry about burping a road tire either as that sort of impact would likely have other consequences at speed as well.
PostPosted: Wed Dec 19, 2012 11:27 pm
The rim bead
PostPosted: Thu Dec 20, 2012 6:15 pm
'Burping' is, I believe, a problem that happens almost exclusively to mountain bike tires and cross tires at very low pressures. For my application (Hutchinson tubeless tires on a converted road bike wheel), burping is not a concern whatsoever.
Yes it's because the pressure is higher than mountain bike tires. However, I have had some punctures on three separate occasions where they flat was sealed by the Stan's sealant, but not before a significant loss of pressure. In each instance, I simply kept riding and made it home fine. I could feel the tire being a bit squirrely, but nothing major and no bottoming-out on the rim.
When I got home from these flats, I have checked and seen that I was riding on 40 psi or even as little as 30 psi in one case. All of this is to say that in an emergency get-home scenario, I have run very low pressures for a short time and have had no 'burping'. It is nothing I would ever worry about.
Users browsing this forum: Google [Bot] and 61 guests
There are no new unread posts for this topic. Shimano 35mm carbon tubular rims as rims only ?
LouisN
Fri Jun 29, 2012 2:24 pm
LouisN View the latest post
There are no new unread posts for this topic. Planet X 20mm carbon rims
sawyer
24
3335
Thu Sep 13, 2012 11:28 am
GASer View the latest post
There are no new unread posts for this topic. Carbon Tubular Rims -wear?
Ginsterdrz
Mon Jul 09, 2012 2:25 am
Zen Cyclery View the latest post
There are no new unread posts for this topic. tire lever - carbon clincher rims?
JURE
Thu Aug 30, 2012 10:04 am
JURE View the latest post
There are no new unread posts for this topic. Carbon rims - worn brake track?
Permon
Sun Oct 07, 2012 10:06 pm
Permon View the latest post
It is currently Fri May 24, 2013 12:45 pm
