Post new topic Reply to topic  [ 22 posts ]
Go to page Previous  1, 2
PostPosted: Thu Dec 20, 2012 12:51 pm
A simple piece of plastic tubing should do the trick.
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Sat Dec 22, 2012 1:38 pm
Well - it is decided. I'll go through with it. When i've sold the groupset from the bike i'll strip it completly and drill the holes.
I guess it'll be a good idea to use a clean drill, so the frame won't be damaged.
Anyone who got a last thing or two to say before i get going?
PostPosted: Sun Dec 23, 2012 1:25 am
Tubbie Guru
Hi,
It's your frame. After the drilling it was your frame..... :mrgreen:
Sorry but I just fail to see the point in risking to ruin a prefectly good frame (a nice one at that) just to have internal cabling.
I have internal cabling for the most part on my frame. I wouldn't miss it if I hadn't.
Ciao, ;)
PostPosted: Sun Feb 10, 2013 10:25 am
Hallo again
So i've done it. Now i need som help. In the holes i want to run my cabling through, shouldn't there be like a rubber-thingy to take the cable? What are theese called and where can they be purchased?
PostPosted: Sun Feb 10, 2013 10:37 am
Bregne, do not know your holes dias. :noidea:
But how about using a Nokon inner liner? This thin black but strong inner liner which Nokon has inside the outer alloy parts.
PostPosted: Sun Feb 10, 2013 4:36 pm
Do we know which two frames these are? S2 for the Cervelo?
SWijland wrote:
Bregne wrote:
How in the world should i guide the cable from the hole in probably the downtube, to the hole in the BB?
That parts sucks, whether you do custom drilling or buy one that has been done in the factory. I had to route the cables without guides ones on a Kestrel Airfoil frame. I ended up fishing the cable through with some iron wire bent on the tip to mimic a hook. Make sure to 'fish' through something like a thin shoelace or a textile wire first, as these are more flexible than your shift cables. After you have done that, you can tie the shoelace to your shift cable and pull it through.
Another option is to have the cables exit on the down side of the down tube, just before the weld off the bottom bracket and route the cables externally from that point on. Cervelo uses this method for example.
Or go the Specialized? way:
PostPosted: Sun Feb 10, 2013 5:02 pm
https://farm9.staticflickr.com/8425/777 ... dd30_z.jpg
The thing i'm looking for is something like this. I think i saw Cinneli have some made of rubber to just plug in the hole, at some point. Anyone knows what theese are called?
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 45 guests
There are no new unread posts for this topic. Time RXR Ulteam seat clamp or drilling?
CarlP
10
843
Fri Dec 28, 2012 10:36 pm
CarlP View the latest post
There are no new unread posts for this topic. Scott Foil - frame drilling for di2
notaero
Tue Jan 22, 2013 4:04 pm
drchull View the latest post
There are no new unread posts for this topic. aluminum frame drilling for internal DI2
rOYk
7
750
Tue Nov 20, 2012 10:59 am
rOYk View the latest post
There are no new unread posts for this topic. Time Trial tomorrow TT bike prohibited
rainbowstripes
7
1218
Fri Jul 20, 2012 11:43 pm
CerveloBert View the latest post
There are no new unread posts for this topic. Which front wheel for a time trial tonight?
Juanmoretime
11
572
Wed Jun 13, 2012 2:25 am
Juanmoretime View the latest post
It is currently Sun May 26, 2013 9:48 am
