Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sat Dec 15, 2012 3:35 am
Anybody successfully used an SM-PCE1 with a Mac? I run VirtualBox on my Mac for WKO and downloaded the E Tube software but it won't recognize the SM-PCE1 so I can't update the Ultegra Di2. The computer recognizes the device when I check the port but it E Tube won't recognize it. Any help would be appreciated.
Ridley Noah FAST = 7.38 kg
BMC TM01 = 7.96 kg
Raligh HiLife = 7.46 kg
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=104672
PostPosted: Sat Dec 15, 2012 12:25 pm
try installing vmware fusion - there's a 30-day free trial so it won't cost anything - i've found this works well with usb devices
but some usb devices/windows drivers seem to go through a few connect/disconnect/connect cycles during device detection/initialiaztion, ones that do this can be a real pain to use with a virtual pc unless you can configure the usb port to be dedicated to the virtual machine rather than arbitrated/prompted for on each connection
PostPosted: Sat Dec 15, 2012 2:33 pm
I would second the recommendation for VMWare Fusion. It works well with all USB devices, I use it everyday for my job. I wont be able to test the shimano di2 usb dongle with it till my bike arrives.
PostPosted: Sat Dec 15, 2012 4:04 pm
Thanks for the feedback, I'll check out VMWare Fusion. The odd thing is that I've never had a problem mounting the Garmin or a USB memory stick for uploading files in WKO and the if I check the drive while in the virtual machine it recognizes it but it's like it won't mount completely. May try to find a PC to hook it to to validate that it's not the dongle itself.
BMC TM01 = 7.96 kg
PostPosted: Sun Dec 16, 2012 4:20 am
Tried VMWare Fusion and it worked, thanks guys!!
BMC TM01 = 7.96 kg
Users browsing this forum: angrylegs, Bing [Bot], Google [Bot], sedluk and 64 guests
There are no new unread posts for this topic. TT fit - top tube
Kermithimself
14
706
Mon Aug 27, 2012 12:14 am
WMW View the latest post
There are no new unread posts for this topic. Stan's tube sealant
sungerdds
Fri Oct 19, 2012 2:46 am
Getter View the latest post
There are no new unread posts for this topic. Can I run a cable through this steerer tube?
quattrings
Sun Jan 27, 2013 3:04 am
BobDopolina View the latest post
There are no new unread posts for this topic. Thin carbon tube, good or bad?
ichobi
Mon Mar 11, 2013 5:02 pm
ichobi View the latest post
There are no new unread posts for this topic. Top tubes and Head tube length.
MerckzFan
Sat Jan 12, 2013 8:12 pm
Geoff View the latest post
It is currently Sat May 18, 2013 3:18 pm
