It is currently Sun Jan 21, 2018 10:06 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Jun 13, 2013 9:33 am
Tubbie Guru
Hi,
That should work just fine. Not sure if you even need the old 9S jockey wheels iso the new ones.
In case you'd run a 11S chain you could put the SR FD cage back on and the SR jockey wheels as well.
Ciao, ;)
PostPosted: Thu Jun 13, 2013 1:52 pm
Thanks fdegrove! I went with the 9s jockey to have more clearance like on the 10 speed carbon derailleur. 8.9mm instead of 8.4mm. Some said that the 10 speed chain would rub sometimes on the SR derailleur. When I try an 11s chain, i'll put back everything to 11s spec.
PostPosted: Thu Jun 13, 2013 3:12 pm
With an 11 crank I'd suggest an 11 chain due to external clearance for the chain when in the small chainring and smaller cogs. But then if you go with the 11 chain you will want an 11 front der also - as a added width "slop" of a 10 frt der combined with tighter setup of the crank you won't get as clean front shifts with the 10 frt der.
So one option is try the 10 chain and frt der and if you're ok with clearances on the chainrings then go for it.
PostPosted: Thu Jun 13, 2013 4:49 pm
Thanks for the info tommasini.
I`m gonna try the 10s chain first and see if its ok.
If not, I already have an 11s chorus chain and swapping the cage takes 2 minutes.
PostPosted: Thu Jun 13, 2013 5:32 pm
The chain should match the cassette and the FD cage width should match the chain. Using an 11 speed FD cage with a wider 10 speed chain might shift fine, but it's likely to need frequent trimming.
PostPosted: Thu Jun 13, 2013 6:36 pm
Dave thats what i`m planning to do first. 10 speed cassette with 10s record chain and the front derailleur is a super record , but with a chorus 10s cage from 2008.
I think it should be fine with the record 11s crankset. spacing between the small and big chainring is 0.6mm narrower compared to a 10 speed crankset if i`m not mistaking.
There are no new unread posts for this topic. Campagnolo Front Derailleur Question
matty
16
1447
Sun Mar 19, 2017 11:10 am
matty View the latest post
There are no new unread posts for this topic. Campagnolo SR Front Derailleur vs. Carbonice Chaincatcher
mortirolo
18
735
Tue Jan 02, 2018 11:19 am
Geoff View the latest post
There are no new unread posts for this topic. Attachment(s) Campagnolo 11 speed using 34/50x11/36! Yes it can be done with PRE-2015 Athena LC Big Gears on Campagnolo 11 speed
colnagoaddict
16
1554
Mon Dec 18, 2017 8:49 pm
graeme_f_k View the latest post
There are no new unread posts for this topic. SRAM Red Front Derailleur Tuning (YAW)
prendrefeu
Wed Jan 10, 2018 12:45 pm
Jenmoss View the latest post
There are no new unread posts for this topic. Compatibility between etap front derailleur and the 53-39 Q-ring
Eclat
Wed Mar 08, 2017 6:11 pm
1415chris View the latest post
Users browsing this forum: Bing [Bot], Broady, brumbar, Drizzle, Ravnsnaes, wingguy, Zakalwe and 47 guests
cron
