Mechanical groupset on Di2 CAAD10 Black
igotyofire
by igotyofire
What about clamp on cable stops? Seems welding would call for repainting, anyone put mechanical on this bike successfully?
showdown
by showdown
You could rivet the cable stop onto the frame...
Drilling a 2-3mm hole into the frame isn't ideal but as you can see many manufacturers do this so it certainly isn't the end of the world.
SLCBrandon
by SLCBrandon
To chime in with the semi off topic aspect, I own 4 road bikes, 3 with Red and 1 with DA/Di2......I don't find the di2 to my liking at all. The lack of feedback has me looking down at my cassette constantly to see if it actually shifted.
Love the DA brakes but I'm not at all a fan of electronic shifting. (And no, it wasn't a short sample size. I have 1000miles + on the di2 bike, including a team camp that I used it for).
NiFTY
by NiFTY
Not wanting to derail the conversation further but I have 1 friend who bought a specialized tarmac with ui2, had repeated issues with junction boxes failing, poor charge holding on his battery and then upgraded to SRAM (unfortunately with hydro) - he now has standard cable callipers and cable shifting and is happy. Another has just bought a BMC TMR01 with 9070 and is not impressed with it and wishes he had gone cable actuation. Another mate bought a SL4 tarmac with 9070 after his SRAM Venge got written off in an accident, he likes Di2 but notices no real difference compared to his SRAM in terms of shifting quality.
Di2 is superior for TT bikes, no argument, and if you shift under loaded uphill (I can't say this would be a frequent requirement)
re: the original question, Converting the frame for cable shifting would not be worth the trouble. You could weld cable stops to the frame, but if poorly done they would weaken the frame at that point. In fatigue related frame failure it is often the welds for the cable stops or frame drilling sites which are prone to failure.
http://www.sheldonbrown.com/rinard/EFBe ... e_test.htm
