Post new topic Reply to topic  [ 8 posts ]
PostPosted: Tue Dec 11, 2012 5:00 am
Hello all, I wanted to get some advice before purchasing a new cassette. I have a TT bike ('08 Felt B12) with a single 54-tooth Osymetric chainring. I was planning on a 54/44 tooth Osymetric setup, but both chainrings rubbed against my Felt's chainstay, so I took off the 44 tooth and added spacers between the spider and 54 tooth chainring, allowing clearance between the chainring and the chainstay. I usually run a 11-23 for TT's, but I am looking for something with some larger cogs since I won't have a small chainring. Is a 28 tooth the largest I can run with a SRAM Rival RD?
PostPosted: Tue Dec 11, 2012 5:15 am
Would you consider trying a WiFli RD? They should give you more clearance. What are the chances you will need those gears though?
BMC SLC01
Visiting South West Australia? Visit Crank n' Cycles!
Rival WiFli (longer cage) is intended to allow up to a 32t cog. Depending on your derailleur hanger dimensions, you may be able to pull it off with your standard rear derailleur, but the upper pulley will likely drag on the 32t. I hops you're still running your front derailleur, or something else as a guide.
PostPosted: Tue Dec 11, 2012 6:02 am
I am planning on doing Tour of the Gila this year, and I've heard there are some big hills during the TT, so I'd want something large on my cassette to compensate for the lack of a small chainring. And yep, I'm running a FD to keep my chain on... hopefully this all works out.
PostPosted: Tue Dec 11, 2012 6:23 am
SRAM recently released a RED rear derailleur with a 'medium cage' - goes up to 32t, same length as the Rival 'medium cage' which goes to 32t, only lighter. :twisted:
Exp001
PostPosted: Tue Dec 11, 2012 7:05 am
As I recall there are some significantly long 7% grades in that.
Any chance you could space your crank over and use two rings?
formerly rruff...
PostPosted: Tue Dec 11, 2012 7:46 am
Man, I wish... I have a SRAM Rival GXP crankset, so I cannot add spacers between BB and frame. I would not be opposed to finding a new crankset/BB that would allow spacers though. Any recommendations?
PostPosted: Tue Dec 11, 2012 8:38 am
If you can find some FSA Carbon Pro arms with a 130bcd spider, you could use a wider BB? This applies to any ISIS/square taper/Octalink?? crankset. If you got a set of double arms and used a triple spaced BB it may work. This is just a wild idea though, not much thought has gone in. It would need verification.
BMC SLC01
Users browsing this forum: Routier, sedluk, stax, woody55 and 77 guests
There are no new unread posts for this topic. 1x10 chainline
wassertreter
Mon Sep 10, 2012 10:11 am
wassertreter View the latest post
There are no new unread posts for this topic. 54/39 setup...?
Juggler
Sun Mar 24, 2013 6:50 pm
Juggler View the latest post
There are no new unread posts for this topic. My Internal DIY Di2 setup
Johhny Bravo
15
2455
Sat Jan 12, 2013 8:32 pm
Johhny Bravo View the latest post
There are no new unread posts for this topic. Old powertap pro with mavic open pro wheel setup
8mann
Thu Aug 09, 2012 6:46 pm
8mann View the latest post
There are no new unread posts for this topic. Problem: New Sram Red 2013 brakes setup
poppiholla
10
975
Fri Dec 21, 2012 8:12 am
refthimos View the latest post
It is currently Tue May 21, 2013 9:40 pm
