Post new topic Reply to topic  [ 9 posts ]
 Post subject: TRP brakes binding
PostPosted: Mon Dec 10, 2012 6:12 pm
My rear TRP 960 brake has bound up twice with almost no movement till I soak it in lube and then it comes back about two weeks later. Is the brake shot or can something be done. Its only two years old. :noidea:
 Post subject: Re: TRP brakes binding
PostPosted: Mon Dec 10, 2012 7:46 pm
Sounds like it's time for a rebuild.
PostPosted: Mon Dec 10, 2012 8:43 pm
I struggled with the same issue on two different pairs after about a year of use. I rebuilt one set and it worked for awhile only to have the same lackluster performance about 3 months later. I eventually abandoned both sets. The 970sl and 970EQs I have do not give me this same problem......at least so far.
Authorized Power2Max Dealer
PostPosted: Mon Dec 10, 2012 9:58 pm
Back the centre bearing off a bit.....surely it is that simple??
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Mon Dec 10, 2012 10:16 pm
I tried that on both pairs of my 960s it didnt fix mine. There was some corrosion on the one I took apart.
PostPosted: Tue Dec 11, 2012 1:09 am
I took it too the shop the first time because it was completely locked up and the mechanic managed to free it up but after telling me I might need a replacement. If that's so according to everybody here is this something that only trp can do or can I get the bushings myself and do this.
PostPosted: Tue Dec 11, 2012 3:14 am
If you find a permanent fix for the problem let me know, I know I have at least one of the pairs around somewhere.
PostPosted: Tue Dec 11, 2012 4:34 am
I'd take it apart, clean it out and re-grease it. I've rebuilt a number of sticky Shimano calipers. They work much better afterwards.
PostPosted: Tue Dec 11, 2012 12:45 pm
I did a complete rebuild on one of mine, it only worked better for about 3 months, then a complete seize again
Users browsing this forum: Dalai, Google [Bot], Google Adsense [Bot] and 37 guests
There are no new unread posts for this topic. upgrade Sram Red 2011 Brakes to the new Sram Red 2012 brakes
poppiholla
Wed Jul 04, 2012 10:20 am
MarkThailand View the latest post
There are no new unread posts for this topic. Attachment(s) New THM matte brakes
coppercook62
14
2024
Mon Jul 30, 2012 3:17 am
thatdkid View the latest post
There are no new unread posts for this topic. AX Lightness Brakes
DamoRider
13
766
Tue Mar 12, 2013 3:14 am
sedluk View the latest post
There are no new unread posts for this topic. Vanguard Brakes
DartanianX
Tue Aug 28, 2012 8:36 pm
TimmS View the latest post
There are no new unread posts for this topic. Ax lightness brakes
liketoride
Fri Apr 19, 2013 3:54 pm
liketoride View the latest post
It is currently Sun May 19, 2013 1:51 pm
TRP roadbike rimbrakes & TRP brake levers at reasonable prices
