Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
PostPosted: Mon Dec 10, 2012 5:01 pm
I have no idea how good these tires are in the extra legere version, but the weight is pretty spectacular. 181 grams for the 23 mm tires and 232 grams for the 32 mm version.
I've used the regular versions of both the 23 and 32 and they are really nice tires. Hopefully the extra light versions will be just as good.
Riding the Catskills
PostPosted: Mon Dec 10, 2012 6:12 pm
The same place that sells those tires has some good information on rolling resistance:
http://janheine.wordpress.com/2012/06/1 ... -of-tires/
PostPosted: Mon Dec 10, 2012 9:21 pm
I regret they're not available in 26 mm. I'm sold on 26 versus 23. The regular Grand Bois are really good tires: supple and decent puncture resistance until the tread wears too thin, then they become puncture prone. But I've gotten good life out of the ones I've gotten.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Mon Dec 10, 2012 10:48 pm
Agree. 26 mm extra legere would be nice. If it helps any, though, the regular Col de la Madelaine 23 mm tires actually measure 24.5 mm on Enve 3.4s freshly mounted, and the Grand Bois tires have a tendency to expand a mm or two over time. Haven't measured them recently because I moved and can't find my caliper!
John
PostPosted: Tue Dec 11, 2012 12:44 am
Tubbie Guru
Hi,
http://janheine.wordpress.com/2012/06/1 ... -of-tires/" onclick="window.open(this.href);return false;
They seem to have convinced themselves allright...... :?
A mild case of not seeing the trees for the forest if you'd ask me.
Ciao, ;)
PostPosted: Tue Dec 11, 2012 1:40 am
I don't know exactly what fdegrove is saying, but I will say this; I wouldn't automatically throw width out the window as the article seems to, if you are interested in fast paced riding. The difference between say a 23mm tire and a 27mm tire on the FC Zipp 303s can even be pretty huge, like 10 watts at 10-15 degrees of yaw, which at least from data I've seen is typically larger than the rolling resistance differences between a same brand and design 23 and 27mm tire.
PostPosted: Tue Dec 11, 2012 2:53 am
Tubbie Guru
Hi,
That's just one aspect, one which you'll need to take into account once you're reaching a certain level of wind resistance.
I would not be surprised to learn that the difference in wind resistance as seen by say, a 23mm compared to the 27mm version of the same tyre is far bigger than 10 to 15 Watt at higher speeds in a wind free environment already.
Either way, let's just assume that windresistance was not the target of the test.
If you want to measure rolling resistance than the protocol should be the same for every tyre within the apples to apples and oranges to oranges range. Carrying out such tests is far more easy to do and far more precise in a controlled environment.
From that prespective the lab tests as carried out by Tour magazine are scientifically far more valid than any such test carried out on a road.
Whether or not the tyre sees a fixed load (brick of lead fror instance) or a rider + a road as load isn't relevant at all for measuring rolling resistance either for as long as the load is the same for all devices under test. Something you can't be sure of when testing outdoors on a strip of road.
Point is that the relative order of difference between the test participants should and will be absolutely the same in both tests. The absolute figures may differ yet the differences should remain.
In short, there are a number of remarks and conclusions in that article that just goes to show that there's nothing new under the sun; setting up tests is one thing, drawing the right conclusions is quite another....
Plus ca change.....
Ciao, ;)
PostPosted: Tue Dec 11, 2012 3:16 am
Just someone tell me what the ultimate tire and wheel combo to buy for all conditions at all times and under all riders.
Exp001
PostPosted: Tue Dec 11, 2012 3:41 pm
Anyone planning on getting the 23s? Curious how they would compare to say Conti 4000s's
PostPosted: Tue Dec 11, 2012 4:19 pm
I agree with fdegrove. This kind of testing is pretty silly.
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Tue Dec 11, 2012 4:34 pm
From a bird's eye perspective, the testing protocol doesn't seem less in touch with reality than rolling on a steel drum. What do you not agree with specifically, SWijland?
Bikes: Raceur, Beateur
PostPosted: Tue Dec 11, 2012 6:10 pm
Agree. Testing on a steel drum may be more accurate and reproducible, but it has little, if any, relationship to real world use.
You can poke holes in Jan's methodology, but how else are you going to perform the experiment under conditions approximating actual roads? Although they didn't specify their methods, one of the testers is a statistician and ran a presumably valid statistical analysis on the results. The differences were significant. This is a powerful argument that the results that they are seeing are highly likely to be real.
I haven't seen the Tour steel drum test (and I can't read German, anyway) but I'm betting that their experimental methods were shakier than Jan's, and I'm also willing to bet that they did not do a statistical analysis of their results.
I'd suggest that you read the actual papers before passing judgement. Although I disagree with a significant amount of what I read in Bicycle Quarterly, Jan and his fellow testers deserve to be commended for actually attempting to do an analysis that approximates actual riding conditions.
PostPosted: Tue Dec 11, 2012 6:16 pm
That's funny because people have found high correlation between Al Morrison's extensive roller data and use in field testing...
PostPosted: Tue Dec 11, 2012 6:29 pm
That "road" test simply has too many confounding variables... wind being a huge one, plus body position, different wheels, etc. These are easily great enough to swamp any Crr numbers.
formerly rruff...
PostPosted: Tue Dec 11, 2012 6:41 pm
Could you please point out the study where they correlated roller data and use in field testing. I'd love to see the methodology because I haven't seen these data.
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: alexalecu, CBJ, Exabot [Bot], Google [Bot], wrcompositi and 29 guests
This topic is locked, you cannot edit posts or make further replies. All-round clinchers for a grand?
chickenbourne
Wed Aug 15, 2012 9:17 am
fivethirtyonepm View the latest post
There are no new unread posts for this topic. Where to find extra seat post spacers for Look epost
ultyguy
Sun May 05, 2013 1:14 pm
Pugrot View the latest post
This topic is locked, you cannot edit posts or make further replies. Looking for Gumwall Tires
photocycler
Sun Feb 10, 2013 8:51 pm
tonytourist View the latest post
There are no new unread posts for this topic. Rebranding tires - how to do it
petal666
Thu Sep 20, 2012 1:21 pm
chazzawoods View the latest post
There are no new unread posts for this topic. When do you replace your bike tires?
stevec1975
Wed Aug 22, 2012 3:55 pm
prendrefeu View the latest post
It is currently Fri May 24, 2013 1:45 am
