Post new topic Reply to topic  [ 13 posts ]
PostPosted: Mon Dec 03, 2012 1:55 am
hello weight weenies i have keo 2 max and it has developed a really LOUD SQUEAK that drives me INSANE specially when i try to sprint. :shock:
Does anyone know how to get rid off this DAMN issue the pedals are just 3 months old..! :evil:
PostPosted: Mon Dec 03, 2012 2:08 am
I have keo blades and have found that degreaser on the base plate (the shiny platform section) and then a tiny amount of grease or lubricant removes the sounds. Have to reapply sometimes.
"But when you hit that asphalt down below nothing else matters, your pulse is skyrocketing toward 200"
650b Ritchey
Colnago Mapei
S-5 VWD
PostPosted: Mon Dec 03, 2012 3:27 am
Thanks I will try that :D
If i remove the rubber on the cleat would that work .?
PostPosted: Mon Dec 03, 2012 3:36 am
Bit of Teflon spray. In my experience they get even worse when wet. Sounds like you are being chased by a bunch of penguins
Sent from my HTC One XL using Tapatalk 2
N+1 It Never Stops
PostPosted: Mon Dec 03, 2012 3:52 am
If you are using the "grip" cleats, try switching to the ones without the grip. They are bimaterial, they have a smoother white plastic at the pedal contact points and are much less prone to squeaking.
PostPosted: Mon Dec 03, 2012 9:42 am
Agree but in my experience the non grip ones are harder to find. Aside from less squeaks they also last longer.
N+1 It Never Stops
PostPosted: Mon Dec 03, 2012 11:54 am
mine squeak in very cold weather despite being well maintained. yesterdays -1C ride especially.
PostPosted: Mon Dec 03, 2012 12:25 pm
Very strange, that the original Deltas used to squeak a lot.
Then my the Keo Carbons do not, absolutely zero noise from new to now, almost 3 years old, with grip cleats.
And there's seem to a lot of you who have squeaking on the newer Keo Max? Not a good product development, is it? :)
PostPosted: Mon Dec 03, 2012 1:52 pm
some people have a lot of float and wear the cleat quicker. Others tend to walk on the cleats as if they were casual shoes. Other ride in the rain which picks up dirt that cause wear. Many different variables associated to cleat and pedal surface wear.
PostPosted: Mon Dec 03, 2012 5:33 pm
I already removed the rubberized part from the cleats and even put baby powder on them; as others have stated.
where would i find those cleat that u said..? :beerchug:
PostPosted: Mon Dec 03, 2012 5:53 pm
Paraffin wax on all pedal contact surfaces is the best to kill noise.
swinter wrote:
Mr.Gib got it right
PostPosted: Mon Dec 03, 2012 7:58 pm
Bit of parrafin wax or god forbid a bit of the dreaded gt85 if you're really stuck! It is well annoying if it's anything like I suffer with them, almost certainly cleat rather than pedal based.
PostPosted: Tue Dec 04, 2012 8:15 pm
I can't promise that this is the solution on this generation of Look pedals, but in the past, this worked.
Loosen the screws on the cleat by @ 1/4 turn each. This allows the cleat to flatten out a bit, eliminating the cleat/pedal contact (and thereby the squeak as well)...
Not sure what shoes you're running, but in the past, Sidi seemed to give us the biggest issue due to the curvature of their sole.
Users browsing this forum: Wookieopolis and 46 guests
It is currently Thu Jun 20, 2013 12:08 am
LOOK KéO 2 MAX
