It is currently Sun Dec 17, 2017 10:52 am
Post new topic  Reply to topic  [ 508 posts ]  Go to page Previous 126 27 28 29 3034 Next
 Post subject: Re: Show me Your Tuning!
PostPosted: Tue Sep 02, 2014 12:15 pm
It is changing the "lever". A lever is created any time a force acts a distance from a pivot - the bearing here will increase the distance from a pivot to where the cable anchors.
Crap description. :s
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
PostPosted: Tue Sep 02, 2014 2:58 pm
Christo, if you understand the principles behind block and tackle pulleys, you'll get what he's trying to do here.
The loop back up to the arm for an anchoring point effectively doubles the cable pull required for each amount of arm movement. It also effectively doubles the force actuated on the pulley pivot, in effect the brake arm.
How well it works remains to be seen but in principle, that's what its supposed to do.
PostPosted: Tue Sep 02, 2014 3:01 pm
PostPosted: Wed Sep 03, 2014 5:06 pm
Does anyone know or seen any Rupture test on Brake and Shift cables? I'd like the see the numbers. Can't find so far.
PostPosted: Wed Sep 03, 2014 8:20 pm
Sram clamps (for trigger shifters) working as an adapter to install the rear shifter from the frame to the handlebar. Looks good!Image
PostPosted: Wed Sep 03, 2014 8:51 pm
hmm, care to explain how you did that? I made a retroshift style from a 1X7 cheap bike, but yours solution looks nice too:
 Post subject: Show me Your Tuning!
PostPosted: Wed Sep 03, 2014 9:22 pm
Yours looks also interesting, but were the cable stop goes?
I don't mind explaining....well, the picture tells the story:
Sram clamp is already square, but I had to use a file to remove some material to fit the shifter base, as you see, fitting worked. The second part you see (from left to right)
is a caliper brake Nut, and I also used a file to make the square shape to avoid rotation versus the sram clamp. The other edge of the nut is also squared to receive the
shifter and fit properly. A 33mm long bolt was needed, and lastly, M5 nut closing the deal. The second clamp is needed to work as a cable stop, they need to work together.
PostPosted: Fri Sep 05, 2014 7:10 am
PostPosted: Fri Sep 05, 2014 2:58 pm
Wow, the pictures are so big it's a pain to follow this thread.
PostPosted: Sun Sep 07, 2014 3:39 am
Saddle ready
PostPosted: Mon Sep 08, 2014 11:28 am
Wow! That looks fantastic! Kudos on the shifter too, raw engineering look. Very cool!
I guess there's worse hobbies than making a bike light? Right?
PostPosted: Mon Sep 29, 2014 2:05 am
Here I have my lightweight junior cassette mod...
This started out as a 14-25 10speed ultegra cassette, but i wanted to have the option of a 27, so in our parts bin at the shop, i found a dura-ace 7900 12-27 cassette. Swapped the last 3 cogs from the dura-ace cassette onto the 14t junior legal corncob, giving us the following;
Image20140928_202342 by greenberg.ethan, on Flickr
But that sucka is heavy! So, I took the primary grouping which is riveted together, got out my drill, and separated the cogs. Used the 1st position 14t from the corncob, the 15t and 16t from the dura-ace, a custom bit i loaded onto the dura-ace carriage, which gives me my 17t and 18t cogs. Then the 19t and 20t from the original corncob, and then my last 3 dura-ace cogs (21, 24, 27 on a carriage). I also replaced all of the spacers with some composite ones. Pretty happy with the end result;
Image20140928_202443 by greenberg.ethan, on Flickr
PostPosted: Mon Sep 29, 2014 2:11 am
Just a reminder not to use it on an aluminium freehub though. Its gonna bite real deep , maybe even through with individual cogs.
PostPosted: Mon Sep 29, 2014 2:18 am
Holy moly dude, thanks for letting me know. Luckily, the DA 9000 wheelset has a TI freehub body. That's ok right?
PostPosted: Mon Sep 29, 2014 5:45 am
You saved nearly 90 grams on a junior cassette? Man I just ran a cable lockout on my 11-23 SRAM Red power dome.
There are no new unread posts for this topic. Show me ur handlebar/hoods...
3Pio
Sun Aug 13, 2017 9:59 pm
3Pio View the latest post
There are no new unread posts for this topic. Attachment(s) Show me your climbing shifters
glepore
Thu Aug 24, 2017 6:59 am
lovemyway View the latest post
There are no new unread posts for this topic. show me your steerer tube ( inside )
stormur
Wed Jan 18, 2017 6:36 pm
stormur View the latest post
There are no new unread posts for this topic. Tuning BTP shifters for Red 22
4ibanez
Mon Jan 02, 2017 9:57 pm
4ibanez View the latest post
There are no new unread posts for this topic. Di2 fine tuning problem
havana
12
1195
Mon Mar 27, 2017 10:11 pm
agravic View the latest post
Users browsing this forum: breezerboy, Jowwy and 36 guests
