Show me Your Tuning!
andreszucs
by andreszucs
Just did another modification using a BlackOps seatpost: http://kbcyclewerks.com/wp-content/uplo ... tpos11.jpg
Before: Original weight for 27.2/350mm on my scale was 190g.
Stock tube
Stock craddle
Stock Yokes
Stock Pin
Ti Bolts
Major modification: Head was chopped (titanium hardware around and inside)...and I added an extra carbon tube inside the make it thicker before drilling, I used an leftover tip of Zipp Vuka extension bar and fitted just perfect inside! I used epoxy for maximum bonding.
AFTER: 146g
tube after mod: 104g
homemade craddle (carbon): 12g
China yokes: 12g
Homemade pin: 10g
same bolts:8g
1spd
by 1spd
Pretty sweet!
Cannondale Synapse (alu)...it works
darnellrm
by darnellrm
Good work, but still heavy for a 27.2 post though.
andreszucs
by andreszucs
darnellrm wrote:Good work, but still heavy for a 27.2 post though.
I agree, tube has a pretty thick wall. As I will be using on a Hardtail MTB I might as well think it's a good weight for the strength offered.
Telsun
by Telsun
This thread should be made a sticky!
Telsun
by Telsun
weeracerweenie wrote:To start off ill put forward my contributions, i being 17 / 18 years old and having little money :( So to get my ride under the magic 5.00kg i took to it with a small range of power tools! Here goes:
Tuned Sram Red Rear Derailleur, 11 hours worth of work on it, final weight = 104.67 Grams. Saving of just over 40 grams. Have ridden over 5000km on it with no major failures (bar jockey wheels, see "AFC Pulley Wheel Review" Thread). Light and functional, and i think its pretty too... Plans to go under 95 Grams yet!
What did you actually do to shave so much weight of the rear mech?
voodoojar
by voodoojar
Here are some of mine that I spent a lot of time on. well except the felt hoods those only took like 5 minutes.
liketoride
by liketoride
great wt on both FD-RD, what FD is that? Sram?
voodoojar
by voodoojar
It's a Tiso.
wrcompositi
by wrcompositi
voodoojar wrote:Image
Can you elaborate more on the eggbeaters' modification? The weight is impressive!
liketoride
by liketoride
how is the front shifting with the Tiso?
voodoojar
by voodoojar
wrcompositi wrote:Can you elaborate more on the eggbeaters' modification? The weight is impressive!
hollow spindle, ti spring, aluminum sleeves, ceramic bearing, aluminium nut, plastic end caps and a bunch of material taken of the body. Take all the grease out before you weigh them :D
weeracerweenie
by weeracerweenie
Lots and lots of re shaping and work. The mount bolt is significantly shaped (conclaved in the centre) that took a lot of weight out. The front parallel arm took a massive hot to with the dremelling. Lots of little things.
I guess there's worse hobbies than making a bike light? Right?
jockalldrick
by jockalldrick
This is what weight weenies is all about
Keep up the good work guys
addictR1
by addictR1
Yea I like to know more about the eggbeaters too.
Sent from my cm_tenderloin using Tapatalk
