It is currently Fri Nov 24, 2017 11:09 pm
Post new topic  Reply to topic  [ 508 posts ]  Go to page Previous 118 19 20 21 2234 Next
 Post subject: Re: Show me Your Tuning!
PostPosted: Wed Jun 12, 2013 1:28 am
Sweet awesome tune, TimmS!
Made me wonder about absolute minimalism:
Are the extra layers needed? Could you just have removed the microtex and be done with?
Are the eyelets required. Could you have just punched the holes and be done with?
Less is more.
PostPosted: Wed Jun 12, 2013 8:01 am
@ shimmeD
What's left after the microtex is removed is just a very thin layer which would not hold up.
I use the eyelets because carbon fibres can be sharp, without eyelest the laces would tear.
@ dereksmalls
The shoes are very stiff, I think it would be possible to ride them without laces!
And off course I have a pair of old shimano's for rainy days...
PostPosted: Wed Jun 12, 2013 11:19 pm
Thanks TimmS, you've inspired me to firstly think about further modifications to my Bonts. Just need another pair of shoes before I rip into them.
Less is more.
PostPosted: Thu Jun 20, 2013 9:04 am
TimmS that is seriously cool, i take it you have seen Adam Hanseens shoes? i forget his username on here but he has a similar idea to yours!
I guess there's worse hobbies than making a bike light? Right?
PostPosted: Thu Jun 20, 2013 10:42 am
Tubbie Guru
Hi,
Yep. That was Zakeen and he still races wearing his self made shoes.
Ciao, ;)
PostPosted: Fri Jul 19, 2013 10:10 pm
Homemade carbon Seatpost looking promising (carbon cradle also).
104+12g yokes = 116g at 34.9mm and 12" total length.
PostPosted: Sat Jul 20, 2013 5:51 am
Can we have some more detail of the cradle and how you made the post andrezucs?
PostPosted: Sat Jul 20, 2013 4:53 pm
Still haven't tried the post yet. Still waiting on the Yokes. Once I try and 'survive' I'll be back to tell the end story! :thumbup:
PostPosted: Tue Aug 13, 2013 8:57 am
Andreszucs, where did you get the hardware for the seat clamp?
I have a ~260 g post I got for $30 and have been very interested in doing this. I haven't gotten to use my dremel on enough bike parts yet.
PostPosted: Tue Aug 13, 2013 6:49 pm
Ebay for the yokes and bolts
yokes:271185641624
bolts:370849308430
Cradle was custom made. I had a carbon tube in my garage, cut in half and made the slots. Working so far!
Pin connector, I found a 3/8 Aluminum rod at home depot...after some art work it worked like a charm!
PostPosted: Thu Aug 15, 2013 5:58 am
Thanks a lot. Finding a place to buy the connector pin was the real issue. I was planning on trimming the post anyway, and using the excess to create the cradle. Looks like I might have to break out more than the dremel to make the connector pin though. What did you use?
PostPosted: Thu Aug 15, 2013 6:49 am
Funny.....I was exactly with the same questions a couple of weeks ago, I even created this desperate post looking for help:
viewtopic.php?f=3&t=117321
Tired of searching I walked into home depot and found my solution! :) $5 for 40" 3/8 rod.
take a look at the final result:
But learn from my mistakes: when you drill the rod, make it as a slot so the bolt have room to change angle, not only 90 degrees, you will probably need to have that adjustment when installing with the saddle.
As pictured, very good weight for a 34.9 post. BUT! I would add a reinforcement extra tube inside at the head, from bolt to cradle to make sure the carbon can withstand the amount of pressure when tightening bolts. So far mine is ok, but I have noticed a small gap under the connector pin with mean the carbon is suffering a little bit to hold the pressure. Make sure to have something SAFE at the and.
:thumbup:
PostPosted: Fri Aug 23, 2013 12:37 pm
yokes:271185641624
bolts:370849308430
I found with my cradles (which i could do for 6.5 grams) the tube i was using was prone to snapping once loaded as the pressure split it in half, the thickness your using seems plenty strong though. something to consider...
PostPosted: Sat Aug 24, 2013 12:08 am
It appears that the lower piece you made was out of aluminum. That being said, the one that came on one of my posts (can't recall if it was the KCNC or my Hylix) actually has the bottom of it milled out to create a "U" shaped groove down the middle of it. Great build none the less.
Cannondale Synapse (alu)...it works
PostPosted: Sun Aug 25, 2013 5:39 am
If you countersink the holes in your pin and round off the bottom edges of the bolt head, the bolts will be under less strain and the yokes will ride on your rails better. Also, when you drill the post, angle the holes so the pin is perpendicular to the ground.
There are no new unread posts for this topic. Show me ur handlebar/hoods...
3Pio
Sun Aug 13, 2017 9:59 pm
3Pio View the latest post
There are no new unread posts for this topic. Attachment(s) Show me your climbing shifters
glepore
Thu Aug 24, 2017 6:59 am
lovemyway View the latest post
There are no new unread posts for this topic. show me your steerer tube ( inside )
stormur
Wed Jan 18, 2017 6:36 pm
stormur View the latest post
There are no new unread posts for this topic. Tuning BTP shifters for Red 22
4ibanez
Mon Jan 02, 2017 9:57 pm
4ibanez View the latest post
There are no new unread posts for this topic. Di2 fine tuning problem
havana
12
1133
Mon Mar 27, 2017 10:11 pm
agravic View the latest post
Users browsing this forum: Google Adsense [Bot], madik and 31 guests
