Post new topic Reply to topic  [ 6 posts ]
PostPosted: Wed Nov 28, 2012 8:46 am
Got involved in a 30 bike pile up in a race 2 weeks ago. luckily, the bike looks to be okay except for one small problem:
During the crash my down tube bottle cage (Elite custom race) was somehow ripped right off the frame. I suspect this has caused some damage to the water bottle cage mounts female threading because one of the bolts requires a heck lot of force to screw in , definitely more than what feels right, and the bolt isn't going in perfectly straight.
Now I like to drink water on my rides as much as the next person, and lacking a bottle cage could be a problem in longer races; and I'd hate to write off a frame just because of such small problem. Any Solution?
PostPosted: Wed Nov 28, 2012 9:10 am
Where do you live?
We can suggest qualified persons.
A local composite repair service will take care of this issue.
Carbon fiber is a composite material. :)
Exp001
PostPosted: Wed Nov 28, 2012 1:17 pm
5mm x 0.8 tap
http://www.amazon.com/gp/aw/d/B000BMRPT ... mdp_mobile
________________
My 2011 Cervelo R5
PostPosted: Wed Nov 28, 2012 1:38 pm
does the mount show any sign that it's been twisted/pulled out of position?
if not, it may be that only that the bolt has stripped in the mount so that the threads are clogged - especially if you had proper ww aluminium screws - you may be able to chase out the debris with a needle, or use a tap
also, minor damage to the thread should be fixable, mechanic can recut it with a tap, or you can get a tap and diy, as above, an m5x0.8 taper tap
but if the thread is badly damaged, or the frame-mount bond is affected, that needs more expert attention
worst case, elite do some zip-tie cage mounts, ugly, but functional
PostPosted: Wed Nov 28, 2012 1:43 pm
Photos would help in the diagnosis
PostPosted: Thu Nov 29, 2012 3:24 am
Yes, pics. Or at least details of the type of bike, material, etc. Some frames use rivet nuts. Then all you have to do is remove the old one and install a new one.
Users browsing this forum: Bing [Bot], Exabot [Bot], Google Adsense [Bot] and 61 guests
There are no new unread posts for this topic. Mechanics of switching to compact
psycling
Tue Jul 31, 2012 5:45 pm
aaric View the latest post
There are no new unread posts for this topic. Giant tcr advanced sl vs tcr advanced
Oswald
18
1140
Fri May 24, 2013 1:46 pm
Stoo View the latest post
There are no new unread posts for this topic. TCR Advanced decal set .pdf file???
petje891
Tue Dec 11, 2012 1:47 pm
petje891 View the latest post
There are no new unread posts for this topic. DI2 with Giant TCR Advanced 2009
naylor343
Sun Apr 14, 2013 2:55 pm
cymans View the latest post
There are no new unread posts for this topic. Attachment(s) Giant TCR Advanced M/L or L sizing advice
Roark
27
1348
Sat Nov 24, 2012 11:17 pm
Roark View the latest post
It is currently Fri May 24, 2013 7:44 pm
