Post new topic Reply to topic  [ 1 post ]
PostPosted: Tue Nov 27, 2012 12:13 am
I have recently purchased a powertap elite+ with 12mm steel axle and freehub body. I would probably like to lighten it up in the future at some point (since this is WW I won't try to defend that urge) by replacing the axle and freehub body with alloy 15mm versions from the more recent models.
I believe that my elite+ uses 6901 (12x24x6) bearings while the 15mm axle models use 6802 (15x24x5) bearings. With the exception of the 1mm difference in bearing width (which I could perhaps take care of with a 1mm spacer on the drive-side to align the freehub body properly), I don't see why I couldn't just pop in 6802 bearings and use replacement axle/freehub body from a powertap SL+ or other 15mm alloy axle model.
Does anyone have any experience with doing something like this?
Users browsing this forum: 6mt, Bing [Bot], Google Adsense [Bot], robertg and 63 guests
There are no new unread posts for this topic. 12mm Powertap axle
eric
Fri Mar 22, 2013 8:26 pm
eric View the latest post
There are no new unread posts for this topic. Is it possible to upgrade a wired PowerTap to wireless?
Mikmik
Tue Jun 12, 2012 8:41 pm
Pokerface07 View the latest post
There are no new unread posts for this topic. Replace 130 mm axle for a 135 possible ?
LouisN
10
413
Mon Feb 25, 2013 10:26 pm
LouisN View the latest post
There are no new unread posts for this topic. Internal DI2 and axle question
DaleRider
10
533
Sat May 18, 2013 7:04 am
freeloader View the latest post
There are no new unread posts for this topic. Using non original axle and end caps as replacement on a hub
LouisN
Sun Feb 10, 2013 4:40 pm
StradaJon View the latest post
It is currently Tue May 21, 2013 3:22 am
