Post new topic Reply to topic  [ 38 posts ]
Go to page 1, 2, 3  Next
PostPosted: Mon Nov 26, 2012 2:17 am
Looking for a new set of wheels but not having much success with searches. Looking for clincher set that has some aero and is fairly light, around 1300g or so. Would need to take a bit a rain as well.
PostPosted: Mon Nov 26, 2012 2:34 am
1300g is pretty light especially if you want aero too.
For example, XR270s on BHS ultralight hubs (280g) is around 1420g using 20/24 sapim laser spokes.
You could use XR200s but they need more spokes to make a stiff wheel, and they're not even the small amount of aero that the XR270s are.
PostPosted: Mon Nov 26, 2012 3:23 am
These come in at just over 1400
http://www.mavicusa.com/en/product/whee ... syrium-SLR" onclick="window.open(this.href);return false;
The thing is not sure why you would need a training set so light. Do you have super smooth roads where you live? That is what gives me pause about that.
PostPosted: Mon Nov 26, 2012 3:49 am
deleted, please keep the for sale items in that forum. thanks
Other than that check out stans Alpha 340 Pro Wheelset I think around 1300 on an alloy clincher, with nothing esoteric.
PostPosted: Mon Nov 26, 2012 3:51 am
How much do you weigh? What type of terrain are you usually riding?
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Mon Nov 26, 2012 4:06 am
I'm 6'3" at 180 to 190 lbs. The roads are hilly with mountainous stuff as well. Lots of out of corner accelerations. Roads can be a bit rough with the occasional pot holes but for the most part pretty smooth. These are for fast group rides.
I have some old early first gen Campy Eurus clinchers but the bearings are shot. They are so sluggish compared to my tubulars. Not sure what the weight of these old Eurus wheels are but I'm sure wheel designs have progressed a lot since they came out.
PostPosted: Mon Nov 26, 2012 4:26 am
At your weight, you should go with a rim that is a bit stiffer. With that said, maybe take a look at the Velocity A23. It is reasonably priced, and for its weight it is pretty rigid. Regarding the hubs, maybe consider going with some Tunes, or wait for the new Alchemys to come out. Either of those should help you to achieve your weight range, or get close at least.
PostPosted: Mon Nov 26, 2012 4:36 am
Unrealistic, unless you are super gear-friendly and even then, the roads don't sound ideal. You'd be talking Dash or Extralite or top model Tune hubs (you could use an AC front hub to save $$ but it won't cope with the rain) on AC rims and pretty flash spokes. That'd need a high spoke count at your weight.
Less aero=Stans rims. Regardless.....at that mass for a reliable clincher, either some weight or a serious dollar sacrifice will need to be made, I suspect.
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Mon Nov 26, 2012 4:49 am
Good points. The last thing I want is a wheel collapsing under the weight of my huge carcass!
But I'm seeing a range of clinchers out there from around 1100grams on up to 1700 or so. Spada Oxygeno comes to mind.
I know these wheels are not realistic, so I'm hoping for some recommendations.
PostPosted: Mon Nov 26, 2012 6:20 am
Doesn't the farsports 38mm carbon clincher come in at ~1250g?
Apparently my bikes were talking the other day & are undecided whether to upgrade the current rider or get a new one...
one of the schemers...
PostPosted: Mon Nov 26, 2012 7:23 am
Some of them do. The set I ordered were just north of 1400
PostPosted: Mon Nov 26, 2012 10:44 am
I am 77 kg and my light trainers are XR-300 on novatec hubs with 28F/28R spoking (can't buy 24H Xr-200's in the U.K have to buy from aboard). These weigh 1362g. With lighter hubs they would be 1300g but I would not want to build them for someone heavier than me. Also I do not trash gear and more. I have learnt to sympathetic to it.
Given the OP's weight I would suggest the H+ sons Archetype (25mm deep) or Velocity A23. If you are kind to wheels 24F/28R should be fine especially on the Archetype rim.
The DT Swiss RR415 28F/28R should also work (if you are not a wheel trasher). Build these with CX-ray or laser spokes/alloy nips and Novatec A291 F482 hubs then a wheelset with weight of 1420g is possible. Go lighter with the lighter hubs suggested. None of these rims are aero though. For Aero and low weight in clincher form the only alloy rims that measure up are Kinlin Xr270's or 300's. 1400g wheelsets are doable with these with the right hubs. I think a 1300g alloy clincher is a tall ask unless Ti spokes are used and some very light weight hubs which may not be that reiable for training wheels.
www.thecycleclinic.co.uk
PostPosted: Mon Nov 26, 2012 11:10 am
Just curious, why do you recommend these rims? I see alot of people also recommending these rims, whats so special about them?
My wheelbuilding mentor who's about 80kg has always uses an Ultegra(Or record)/Open Pro as their trainer. Its neither light nor aero, but its bombproof
PostPosted: Mon Nov 26, 2012 1:59 pm
I like my Farsports wheels/rims but I don't think they're durable enough for training. I don't like using carbon clinchers for training.... I do too many steep technical descents and don't want to worry about brake overheating. But my theory is that for training I care more about reliability- if I have to bail on a training ride because I broke a wheel, I can't make up for that ride later (due to work and family). If I'm two seconds slower up a climb because my wheels weigh 200g more, well, who cares? I should have been pedalling harder anyhow.
For races of course it's different.
PostPosted: Mon Nov 26, 2012 2:14 pm
Not sure where you are based but I also have a first generation Eurus wheelset which has good hubs but I think the rims are now in need of replacement. If yours are first generation then it is likely the rims are on their way out too. If not then maybe I could let you have the hubs from my set.
Why not get a set of Shimano Dura Ace C24. The 7900 are pretty good price wise now as long as you won't need 11speed and they around 1400g. I've seen these for about 650 euros so thats what I'm looking at getting next to replace the Eurus (2003... god knows how many km!).
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: cesemo, Exabot [Bot], Google [Bot], Google Adsense [Bot], rbrtwyn and 40 guests
There are no new unread posts for this topic. Ambrisio Nemesis vs Clinchers for racing/fast training
campbellrae
16
1264
Sun Oct 21, 2012 10:19 pm
fa63 View the latest post
There are no new unread posts for this topic. The search for training wheels...
Janman
30
2361
Sat Jun 02, 2012 10:45 am
Wingnut View the latest post
There are no new unread posts for this topic. New more exciting training wheels (clincher)?
tri
9
973
Thu Jan 10, 2013 1:19 am
NealH View the latest post
There are no new unread posts for this topic. Training wheels for winter/rain
Kingston
13
790
Tue Aug 28, 2012 10:37 am
wassertreter View the latest post
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2629
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
It is currently Thu May 23, 2013 4:00 am
