Post new topic Reply to topic  [ 6 posts ]
PostPosted: Wed Nov 21, 2012 11:09 pm
I've been running 2012 SRAM Red on my road and tt bikes but considering going electronic. Would go Ultegra Di2 to start since not quite ready to start moving to 11 speed but might eventually go that direction and move the Ultegra Di2 to the cross bike. The biggest thing that is holding me back is the weight penalty. Is the shifting worth the weight penalty?
Not interested in the old DA Di2 since want compatibility with the new system going forward. Record11 is also an option if I were to accept 11 speed but leaning torwards the big S.
Ridley Noah FAST = 7.38 kg
BMC TM01 = 7.96 kg
Raligh HiLife = 7.46 kg
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=104672
 Post subject: Re: Committing WW Sin??
PostPosted: Wed Nov 21, 2012 11:31 pm
Definitely.
The actuation is much smoother, and the front shifting alone makes up for the added weight.
Ultegra Di2 seems like the most practical option to me.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Thu Nov 22, 2012 12:44 am
my sram red (2010) shifts perfectly well, can't see why i'd want to add weight
shift down <<snik>> it's over in a fraction of a second, then you climb for 10km and the weight is there all the way up
PostPosted: Thu Nov 22, 2012 12:53 am
Made topic a little less ambiguous and it's also a topic that's been discussed ad nauseum on here, so searching will help you.
One thing I will mention is that on the TT bike mechanical is still my preference simply because of the reach restrictions you get when going to electronic. I (and mates of mine who TT and even Wiggins and Froome) need the extra reach, so have stuck with mechanical.
Otherwise Di2 is fantastic stuff.
PostPosted: Thu Nov 22, 2012 1:32 am
Just as a counter point to what Tinea said, the electronic stuff on a tt bike also gives the advantage of the second shifting point. I haven't used it though.
There was a huge Sram Red v. Ultegra Di2 topic not too long ago, so definitely search.
PostPosted: Thu Nov 22, 2012 1:52 am
How is shifting a counter point to a fit/aero issue?
No matter how good shifting might be, if you're losing reach and it's not leaving you as aero as possible it doesn't matter how where you can shift from.
Users browsing this forum: carlchristoopher, fio, itsacarr, maverick_1, mind riot and 62 guests
There are no new unread posts for this topic. Is it worth getting a smaller frame to save weight?
RMcC
22
1802
Tue Jul 10, 2012 10:12 pm
rustychain View the latest post
There are no new unread posts for this topic. Shimano Ultegra 12-30 Cassette With Ultegra Di2?
SpeshK
Tue Feb 05, 2013 5:13 pm
SpeshK View the latest post
There are no new unread posts for this topic. replacing fulcrum zero QR
project3
9
587
Sun Mar 17, 2013 8:40 pm
crispy View the latest post
There are no new unread posts for this topic. Replacing Powertap Hub Bearings
dhendriksen
7
779
Wed Aug 01, 2012 5:53 am
Rick View the latest post
There are no new unread posts for this topic. RE: replacing all bolts to Ti ones for Caad10.
Y26
Fri Apr 19, 2013 9:16 pm
mellowJohnny View the latest post
It is currently Wed May 22, 2013 3:26 pm
