Post new topic Reply to topic  [ 8 posts ]
PostPosted: Mon Nov 19, 2012 8:15 pm
Hi
I found myself with nice Caad8 frame, optimo and US made. I'm thinking about running internal DI2 cables with seat post battery. Anyone drilled aluminum frame before for this aim? Do you think that the frame get damage? If you had past experience, where is the ideal location for the head tube area drill?
Cheers!
Roy
PostPosted: Mon Nov 19, 2012 10:46 pm
Thinking about doing this myself for next season too. The best way to convert a Cannondale frame would be drilling it like Cannondale does on its new CAAD10 Black Edition DI2
http://road.cc/content/image/61526-cannondale-caad10-black-edition-di2
I assembled the bike in our shop couple of weeks back and from memory the hole was drilled in the non-drive side part of the toptube.
I can post a detailed photo of the wiring and such tomorrow if you want?
PostPosted: Tue Nov 20, 2012 1:38 am
Before you spark up that drill guys have a wee look here,
http://nyvelocity.com/content/equipment/2012/cx-di2-live-build-mark-purdy
not that the link is likely to dissuade you from getting on with the job, but there's folks that've been there already to learn from eh.
I'm still at least 10 years off electronic gearing.
PostPosted: Tue Nov 20, 2012 6:21 am
Don't see that Purdy's experience was that bad. I drilled my Bianchi frame out for "old" Di2.
Bigger holes even than you would need for the new e-tube wiring. I choose the downtube between the cable stops and then right in front of the bottom bracket.
Tapped on the frame to find the thickest parts. Used a bunch of tape to protect the paint and drilled.
The aluminum drills easily. I actually used a carbide Dremel bit to the open the holes to the oval shape recommended by Shimano. No cracks so far, not even in the paint. Probably 700 or 800 miles on the frame so far.
PostPosted: Tue Nov 20, 2012 7:27 am
If you're uncomfortable with the drilling, just get the external cable set. It works just as well. I used it on my Colnago EPS.
PostPosted: Tue Nov 20, 2012 8:49 am
Thank you all for the advices. To be honest, I really don't know what to do, from one hand, the frame cost le less then 200$ and I really wanna use internal cables in conjunction seat tube hidden battery. I do have one Caad 10 black edition frame that I can copy drilling locations.
The only thing I fear from is safety, I'm afraid that the frame collapse under my legs.
PostPosted: Tue Nov 20, 2012 9:59 am
Drill it, did it with my CAAD 10, no issues, no cracks for about 2,000 plus kms. :D But your gonna void the warranty thou...
PostPosted: Tue Nov 20, 2012 10:59 am
I dont really care about warranty..i use this frame for city bike this days. I have supersix as main bike. Is it possible for you to upload some pictures of your drilled bike?
Users browsing this forum: Bing [Bot], Kayrehn, Martin.F, slyboots and 56 guests
There are no new unread posts for this topic. Scott Foil - frame drilling for di2
notaero
Tue Jan 22, 2013 4:04 pm
drchull View the latest post
There are no new unread posts for this topic. Custom drilling on Bianchi D2 Time Trial frame
Bregne
21
1334
Sun Feb 10, 2013 5:02 pm
Bregne View the latest post
There are no new unread posts for this topic. How to put DI2 internal on a Cervelo R3 BB Right frame?
bruno2000
Fri Mar 01, 2013 2:48 pm
bruno2000 View the latest post
There are no new unread posts for this topic. Cleanest way for DI2 on non-internal frame
L3X
Mon Jul 16, 2012 10:16 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Attachment(s) DI2 frame with internal routing can't take the cables intern
WasFab
38
3060
Wed Apr 10, 2013 12:49 am
di2diy View the latest post
It is currently Thu Jun 20, 2013 1:23 pm
