Post new topic Reply to topic  [ 90 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Tue Dec 11, 2012 11:55 am
get a 3t rigida and make a disc brace for it?
PostPosted: Tue Dec 11, 2012 2:02 pm
Carbon Cowboy
It would be possible, but not safe!
All the disc forks are around 450g or more, standard forks are around 300g. So there is 150g more, and that's with a reason. You really don't want to snap off the fork while braking,.. don't remember where I read that, but I think that Colnago had some problems with their early prototype forks, so they made quite a lot of tests to make it safe. The forces aren't small while you're braking on disc brakes, and mention that the front brake takes most of the forces. And I already repaired rear dropouts that were "pulled out" because the disc brake in the rear, so it's a "no-go" for me to modify a standard fork.
I could modify it without any problem, but if I'm honest I don't want to risk anything. We have some descents here where you can reach also 100km/h, and that's also why I would prefer disc brakes instead of carbon. But of course you can still use ALU rims..but the main idea is to use some light high profile carbon rims with disc brakes - in my opinion it would make sense, also for clincher carbon wheels.
Berk PROTO-TYPE Composites - Handmade In Slovenia
Berk Composites
PostPosted: Tue Dec 11, 2012 2:20 pm
yeah, I guess then you'd have to either add a lot of reinforcement or use a 1.5 steerer option.
Or use a so-so quality chinese fork and make a reducer crown race on a lathe.
PostPosted: Mon Dec 24, 2012 7:58 pm
Just a quick update, I wound up buying a St. John Street 700c carbon road disc fork, and while it came to 605g cut to length, it has been a great fork for me, on my old Storck Scenario w/ 72.5 head angle.
I had tried a couple of cyclocross disc forks, but the axle-to-crown was 395mm or so and made the effective head angle too slack. Now with this SJS fork and its standard road 367mm axle-to-crown, the head angle is back to where it should be, and the bike handles great.
This fork is made slightly asymmetric to accomodate the left side caliper. It's super rigid (and better be for that weight). It's also confidence-inspiring to use my disc brake to its full potential, even with road geometry.
I only use a disc on the front, the rear is a regular caliper road brake, because (a) it's a road frame, and (b) I just don't think a disc is needed on the rear.
Short story is that after 2 good rides it has been the best road disc fork I've tried thus far (even though it's the only true road fork I've been able to find). And the price was very reasonable, made it worth the experiment.
PostPosted: Mon Dec 24, 2012 8:25 pm
Carbon Cowboy
Thanks for that update! Any photos of your setup? I'm really interested how it looks like, thanks!
Berk Composites
PostPosted: Tue Dec 25, 2012 3:34 am
Try this:
http://imageshack.us/g/1/9933440/
My bike still dirty from yesterday's ride. And the old caliper & rotor just for setup purposes; I have better parts once I get around to building my special disc wheel w. Extralite HyperFront hub & carbon rim! My front lever is a basic TRP alloy road brake lever.
PostPosted: Tue Dec 25, 2012 7:54 am
Im modifying a enve road fork for front disc use. It was a CX fork from beginning so sturdier than a road fork.
I know it will be a completely different load case when moving from bending the legs outward to bending only one leg backwards. I will do approriate reinforcements then paint up to give it a original look.
Experimental Prototype
PostPosted: Tue Dec 25, 2012 11:44 am
+1 :mrgreen:
PostPosted: Tue Feb 05, 2013 1:28 pm
Carbon Cowboy
Just saw this today: http://apace-bikes.de/c1rd-carbon-disc- ... -prototyp/
I'm still searching for a 1 1/8 - 1 1/4 road disc fork, so if anybody has any new informations what is possible to get please share that information..:thumbup:
As I wrote before Enve won't yet sell their 1 1/4 road disc forks (they only made it for Parlee), Colnago isn't interested to sell only a fork, etc.,..
Berk Composites
PostPosted: Tue Feb 05, 2013 2:56 pm
This I believe is a FM166, an open mold frameset based on the rather popular FM066. I believe it uses 1 1/8" and 1 1/2" headset.
Oops... its not, but I have seen it somewhere before. Here's the FM166:
PostPosted: Tue Feb 05, 2013 3:03 pm
Ahh.. here it is, its the FM065
Uses a 1 1/2" lower bearing too.
PostPosted: Tue Feb 05, 2013 4:24 pm
Berk wrote:
Just saw this today: http://apace-bikes.de/c1rd-carbon-disc- ... -prototyp/" onclick="window.open(this.href);return false;
So, that frame is an oem frame made by HungFu and rebranded by Apace, right?
PostPosted: Tue Feb 05, 2013 4:40 pm
As far as I know, Hongfu are not manufacturers. But they do sell many of the popular open mold framesets on the market now.
PostPosted: Tue Feb 05, 2013 6:56 pm
Yes, you're right. I believe that HungFu is a reseller, but DengFu actually builds in-house. So the question becomes, is the DengFu FM166 worth a second look?
Also, Berk - can you read the language of that website? I'm curios to know the wheel build. What are our hub options when building a wheel?
PostPosted: Tue Feb 05, 2013 10:49 pm
Carbon Cowboy
Sure, I speak also German and it's no problem, but they just "branded" also the hubs with their name. But as I can see it's Novatec (they already made some hubs for road disc 100 / 130 mm). Unfortunately I don't know which rims are these, but as you can see they are some carbon clinchers - in my opinion finally carbon clinchers make sense if you're using disc brakes..
Berk Composites
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: carlchristoopher, fio, Google [Bot], itsacarr, maverick_1, mind riot and 61 guests
There are no new unread posts for this topic. BTP carbon cage - carbon fiber or plastic ???
maverick_1
16
1349
Thu Feb 21, 2013 8:38 am
mann2 View the latest post
There are no new unread posts for this topic. Beyond Carbon Fiber, Graphene or . . . .
dogrange
9
1153
Sat Nov 03, 2012 2:49 am
Velofreak View the latest post
There are no new unread posts for this topic. Carbon Fiber Kick Stand. 40g, $40USD
prendrefeu
21
1558
Thu Nov 29, 2012 11:21 pm
mellowJohnny View the latest post
There are no new unread posts for this topic. 1 piece custom carbon fiber seat&seatpost
steel515
Tue Feb 05, 2013 9:51 pm
415brian View the latest post
There are no new unread posts for this topic. Disc Road bikes in 2013-14, will it happen in mass?
[ Go to page: 1 ... 5, 6, 7 ]
spytech
98
4313
Fri Apr 19, 2013 2:05 am
maxxevv View the latest post
It is currently Wed May 22, 2013 3:26 pm
