Post new topic Reply to topic  [ 90 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Nov 30, 2012 3:31 pm
Carbon Cowboy
maxxevv wrote:
That's not possible (or the very least I have not heard of one). Even the chinese/ taiwanese OEM fabricators have them only in 1 1/8 - 1 1/2 .
You could try searching the online for Taiwanese fork makers if they have such a thing. If they don't, then you won't find one as the Chinese won't go into uncharted waters.
I don't want any "no-name", it has to be really good quality. Of course it's no problem if it's made in Taiwan, but it has to be good quality, if you know what I mean..
If I'm right Colnago has 1 1/4 for their disc forks (?) so maybe I'll try to get that fork..will see, but I guess it won't be easy, so that's why I'm searching for some more options.
Berk PROTO-TYPE Composites - Handmade In Slovenia
Berk Composites
PostPosted: Fri Nov 30, 2012 4:38 pm
I believe the C59 Disc uses the 1 1/8 - 1 1/2 steerer as in all their carbon bikes since the EPS was introduced.
PostPosted: Sat Dec 01, 2012 10:57 pm
Carbon Cowboy
I'm not really sure because I can't found an exact information.
If not 1 1/4 then also 1 1/2 would be an option (but then I would need to completely change the design of a frame prototype..and I don't want that). Beside that I also don't like the look of 1 1/2..
Berk Composites
PostPosted: Sun Dec 02, 2012 5:58 am
Yes, understand that.
The 1 1/2" lowers are good if its a beefy or a very large frame. Else it just looks weird.
But that seems to the standard now, most of the frame makes come in the that size now. I can't think of any frame makes that utilise the 1 1/4" lowers right now. Maybe the Italians or some of the French ?
As for the 'good quality' part, granted most of the reputable frame makes source their forks from a few select Taiwanese companies, generally, the OEM un-labeled items from them are considered very good quality too in my opinion.
Just saw this:
http://www.3tcycling.com/forks/rigida" onclick="window.open(this.href);return false;
If you know the 3T distributor in your region, he may be able to get one for you in 1 1/8" - 1 1/4" steerer hopefully ( as it seems to be available in that size )??
PostPosted: Sun Dec 02, 2012 10:24 am
Carbon Cowboy
Thanks for those informations, I do know the 3T distributor personaly, at this moment I have an Enve fork that's 1 1/4. But it's not for disc brakes.
There are quite a few bigger companies who use 1 1/8 - 1 1/4 (Cannondale, Wilier, Scott,..) , but not yet any disc fork, at least I didn't found any. I'm in no rush at all, but anyway, searching for it (road disc fork 1 1/8 - 1 1/4), and any information is welcome.
Berk Composites
PostPosted: Sun Dec 02, 2012 10:50 am
Don't know if they'll sell you just one, but Volagi use a 1 1/8 - 1 3/8" disc fork.
Also, dbikes does them, but not sure what size it is (have the dwg and can check), but a mate tried to get a fork by itself, but wouldn't do it.
PostPosted: Sun Dec 02, 2012 8:06 pm
I've also been searching for a 1 1/8 - 1 1/4 disc fork with no luck.
The Parlee road disc frame runs this size, built by Enve (as far as I understand...) but I doubt it's available to buy as an aftermarket fork.
PostPosted: Sun Dec 02, 2012 8:26 pm
Carbon Cowboy
Hopefully it will be soon possible, I don't see any good reason why it shouldn't be offered to the public?
I'll just write to Enve, and will see then what will they answer, if they will..
Berk Composites
PostPosted: Tue Dec 04, 2012 5:43 pm
Parlee is sourcing a 1 1/4 - 1 1/8" tapered disc fork with Enve for 2013. We are not planning on having these available until late Q1 2013 however.
http://www.parleecycles.com
PostPosted: Mon Dec 10, 2012 4:57 pm
Carbon Cowboy
@parlee_Z1
Hi,
thanks for your answer! Hopefully it will be soon possible to get it...
For all those who are interested - I contacted also Colnago, and they also won't sell their 1 1/8 - 1 1/4 tapered fork.
Somehow it's a shame that you can't buy it, although it already exists..so I'm still searching for a 1 1/4 road disc fork, but slowly I'm loosing any hope that it will be possible to get one for 2013 :?
Berk Composites
PostPosted: Mon Dec 10, 2012 8:54 pm
I think disc brakes overall are great on a mtn bike.. that said I was coming down a paved trail after a nice dirt ride and a dog jumped out in front of me. Instinct took over and I grabbed some lever and almost put me over the bars. Discs on a grippy surface can be a little scary.
The upside is they remove problems with carbon rims and tire glue (or both in most situations here)
PostPosted: Tue Dec 11, 2012 5:18 am
@ Berk,
Have just emailed you the dwg for the fork from dbikes - I think it's a 1 1/2" lower, so isn't what you are after, but it may give you some more info.
Cheers
Michael B
PostPosted: Tue Dec 11, 2012 5:36 am
People said the same things when V-brakes debuted over cantilevers ... and then again the same things when disc brakes debuted on MTB's ....
Likewise, if you go back even further ... people would have questioned the 'need' for dual pivot brakes over single pivot ones ...
Its all a matter of getting used to the response and modulation of the system.
It does remove most of the problems of breaking with carbon rims. And will most probably make a real difference in the overall performance of things now that a lot of that rotational mass is moved inwards towards the axle center rather than at the rims. :beerchug:
PostPosted: Tue Dec 11, 2012 5:39 am
@Jure:
I'm really mistaken on the Colnago fork, I always thought it was a 1 1/8" - 1 1/2" fork ! :shock:
PostPosted: Tue Dec 11, 2012 10:32 am
Carbon Cowboy
And probably carbon clinchers would make sense then.
@MichaelB
Hi, just saw the email, thanks! Every information helps
@maxxevv
It's 1 1/4, and a really nice looking fork, so it's a shame that they won't sell only the fork.
Berk Composites
Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: airwise, BdaGhisallo, Bing [Bot], cyclenutnz and 30 guests
There are no new unread posts for this topic. BTP carbon cage - carbon fiber or plastic ???
maverick_1
16
1354
Thu Feb 21, 2013 8:38 am
mann2 View the latest post
There are no new unread posts for this topic. Beyond Carbon Fiber, Graphene or . . . .
dogrange
9
1157
Sat Nov 03, 2012 2:49 am
Velofreak View the latest post
There are no new unread posts for this topic. Carbon Fiber Kick Stand. 40g, $40USD
prendrefeu
21
1569
Thu Nov 29, 2012 11:21 pm
mellowJohnny View the latest post
There are no new unread posts for this topic. 1 piece custom carbon fiber seat&seatpost
steel515
Tue Feb 05, 2013 9:51 pm
415brian View the latest post
There are no new unread posts for this topic. Aero Wheel & Disc Help Needed for TT and Road Racing
ProudDaddy
16
834
Thu Dec 20, 2012 9:25 pm
gilesharrison View the latest post
It is currently Sat May 25, 2013 10:51 am
