Post new topic Reply to topic  [ 46 posts ]
Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Nov 19, 2012 6:14 am
Put that in the gallery!! :thumbup:
Exp001
PostPosted: Mon Nov 19, 2012 11:29 am
This post prompted me to go do some research on Guru Photons. Oh man did I have the impression SO wrong. This is a seriously light frame. Nice to see that this is not just a wallet weenie job, you are really thinking about it and selecting premium items but then doing the "every gram counts" thing and some serious thought has obviously gone into this. (not to mention the time!!).
Bravo.
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Mon Nov 19, 2012 5:15 pm
This is definitely a bit off topic and I normally wouldn't contribute to continuing to keep it off topic, but I feel this is really important to say. Under absolutely no circumstances would I ever, EVER, recommend anyone actually ride an Ax fork.
Fair Wheel Bikes
Fair Wheel Blog
Friend me on Facebook for behind the scenes updates
PostPosted: Mon Nov 19, 2012 5:24 pm
:unbelievable:
That kinda response deserves it's own thread... one which I would actually click on and read. Jason, could you write one up please?
Exp001
PostPosted: Mon Nov 19, 2012 6:30 pm
Theremery, Thank you for your kind words.Yes, it has been a long labor of love --w/ obsessive research thanks to this site and others like it. I've spent many hours sanding, grinding, drilling and milling.The 2010 Photon was one of the pitfalls; its advertised weight was 654 grams, but actually weighed 754g w/ all fittings necessary i.e. derr hangers and bb guide for size 54 top tube & 47.5cm seat tube. After repairing cracked rear drop-out, it was 777grams. Buying this frame was a costly mistake. I tried to return the frame because of clear coat flaws, weight, and deviations from original blueprint re: size. They wouldn't take it back. The local dealer and Guru were extreme jerks. Guru had just emerged from bankruptcy and didn't care about me--they had my $$. Never again!!! but...I digress (rant) Ultimately, I now have super nice ride that's uberlite--worthy of gracing these virtual pages.PP
PostPosted: Sat Nov 24, 2012 6:09 am
Ahhhhh....yeh....that is sad news re Guru.
Re AX forks......I think I may know the story behind MadCows statement re AX forks......I won't ride them either (can't say the story, sorry.....not my story to tell.....relates to a former WW members accident tho. A very serious accident :( )
PostPosted: Sat Nov 24, 2012 6:16 am
Oh btw.....why not run mini - Ilinks instead of the bungarus if you are using gear cable?....that would be an even lighter solution (and much cheaper)....or will the 1.5mm Cordz not fit in the mini sleeve?
PostPosted: Tue Dec 04, 2012 12:35 am
the long awaited b-link and campag install...
the most important thing is you have to mix up the ferrules to get this system campag friendly..
5mm ferrule for the brake cable into the shifter body and no ferrule for the shifter cables.the EE brake adjusters need the 5mm ferrules as well and the rest of the bike uses the 5.5mm units for any brake or shifter cable/frame interfaces
pretty simple really.
so whats the result..
Very smooth lever pulls and the shifting is best it's ever been. So fast and precise
The minis had a little bit of drag through the rear section. That made it hesitate a little. Now it's faster and a touch lighter on the lever.
make up the length's the same as the old cables
5.0mm ferrule for the shifter body ( brake cable )
5.5mm for the frame
slide it in.. no ferrule on the shifter cable
292mm of course
nail em down with magic packing tape
dont forget your favourite frame protectors
other wise its like a standard cable system.. pretty easy
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
PostPosted: Tue Dec 04, 2012 1:07 am
Thanks for the heads up on the ferrules for Campag, I'll take note of it as that's what I'll be putting mine into when I eventually get around to the install :D
PostPosted: Tue Dec 04, 2012 4:11 am
sugarkane, what types of ferrules are included in the brake kit and shift kit? According to the description on fairwheel bikes site, the brake kit contains 1.5m of housing and the shift kit contains 1.8m. I need only 2.4~2.5m of housing for both brake and shift, which leaves a lot of excess housing from the kits. So I wonder if I can just buy two packs of brake kit, provided both kits share the same types of ferrules?
PostPosted: Tue Dec 04, 2012 4:22 am
the cables are different.
housing looks to be the same in both cases.
the brake kit gets 2 5mm ferrules and the rest 5.5mms
the shift kit mostly 5mms
if you were using sram or shimano you'd be using different ferrules into the bodies as campag is ment to run the cables in on there own.
PostPosted: Wed Dec 05, 2012 12:07 am
So did you actually lose any weight in the end over the minis?
PostPosted: Wed Dec 05, 2012 12:25 am
Only weighed the rear brake section from the bars.
I links with liner came to 11g AiCAN section came to 6g
I'll do some comparisons when I get a chance..
I think the minis are marginly lighter..
But there is a good saving over the std I links
PostPosted: Wed Dec 05, 2012 4:46 am
Even if they weighed the same, they certainly look better than the i Links. Just hard for my niggardly ass to justify the $$$.
PostPosted: Wed Dec 05, 2012 11:01 am
+1
r o y g b i v
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
Users browsing this forum: Bing [Bot], Google Adsense [Bot], nickf, ninjanoir78 and 55 guests
There are no new unread posts for this topic. Attachment(s) AICAN superlight cable system
madcow
34
4920
Mon Apr 22, 2013 2:19 am
liketoride View the latest post
There are no new unread posts for this topic. AICAN Bungarus Cable - Install Question
audiophilitis
Mon Jan 07, 2013 3:05 am
audiophilitis View the latest post
There are no new unread posts for this topic. AICAN Bungarus installation
Leviathan
Fri May 17, 2013 1:36 pm
FastforaSlowGuy View the latest post
There are no new unread posts for this topic. Nokon/Aican brake cabling with Di2 7970?
carlislegeorge
7
470
Sat May 18, 2013 9:31 am
sugarkane View the latest post
There are no new unread posts for this topic. Nokon/Alligator/Aican users - does shape matter?
FastforaSlowGuy
Sun Mar 10, 2013 9:43 pm
drchull View the latest post
It is currently Wed May 22, 2013 2:11 am
