It is currently Thu Jan 18, 2018 5:15 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
 Post subject: Re: Shamal goes 'pop'
PostPosted: Fri Nov 16, 2012 10:49 am
Well for normal rims 0.9mm wall thickness is the norn before retiring them. Most rims would look quite concave at this wall thickness.
DT Swiss RR465 and 415's are 1.65 mm thick so they have a fair ammount of wear and the XR-200 I am sure is about 1.3mm thick so that has some wear before it become unusable.
So do wonder what Stan's say about the the minium wall thickness then. 0.9mm thick for a new rim is not alot. They would wear out pretty quickly in the weather we have here.
www.thecycleclinic.co.uk
PostPosted: Fri Nov 16, 2012 10:58 am
I managed to pop my 2006 Campag Zonda that only day in the winther where i decided to use the hometrainer. I've also ridden Campag Shamal (Gold edition), with green swisstop. two seasons and almost wear at the brakingtrack. Hopefully I'm going Super Record next year, and I'm gonna stick with stock brakepads for training.
PostPosted: Fri Nov 16, 2012 11:04 am
Tinea Pedis wrote:
Why on earth are people not sticking with Campag pads?
Or have I missed something here?
Tinea, standard Campag pads aren't that great for UK winters. I believe they've changed the compound but I've not tried them yet.
SwissStop Greens are the best winter pads I've used but as Lig found out they are quite abrasive and not really suitable for softer rims.
PostPosted: Fri Nov 16, 2012 11:32 am
When I did eventually swap out my Swissstop Greens - for Halt Gooey Pads - I got a MASSIVE increase in braking power. This is with KCNC CB1s, so any improvement was welcome.
Under the Sun - a thriller for weightweenies with bike loving main character on Kindle here
PostPosted: Fri Nov 16, 2012 4:48 pm
Yeah, those green Swissstop pads are junk. They don't bring anything good. Their braking performance is lame and there are chances that they'll destroy your rim as well (sooner that you'll think).
PostPosted: Fri Nov 16, 2012 4:49 pm
Hi all,
Well i tried to take a photo but its really not worth posting as you just cant see the extent of the rim wear. And because they are the 2 way fit its hard to measure the rim thickness, but i will have a go at this when i get chance.
I think we all agree that the Swissstop greens were a bad choice on these wheels, probably on any top end alloy rims really??
The Shamals are a great wheel, although i have got a set of R-sys SLRs and i think they would just top them but there wouldn't be much in it....
I have replaced them with some handbuilt H-Plus-Son Archetype rims, with CX-ray spokes on Chris King hubs and i have to say I am pleasantly surprised. I was expecting them to be quite sluggish. They are about 150g heavier for the pair than the Shamals, but are very nice to ride - the hubs are superbly smooth and do run better than the shamals, and they absorb more road bumps which i think is down to the 23mm rim width - I would say the only negative is that they arent quite as snappy when you get out the saddle - But when climbing there is 0 flex in them! These are for my winter bike and i wanted something i could easily rebuild and thought I would invest in good hubs.. Any how the chap who built them did say he thought the best pads around are the standard Shimano DuraAce pads and at £9 a pair I am going to give these a try (I do hate to put Shimano parts on my bike though - I did have to scrape off the shimano text on the pad so no one would see :D ) The brakes are TRP and are shimano fit.
Cheers guys - and if your rims looking suspect then get 'em checked out or bin em!
Lig.
Look 695 Light Campag EPS v3
Colnago C50 Campag SR
Parlee Z3
PostPosted: Fri Nov 16, 2012 5:04 pm
The dura-ace pads are excellent. You can also get the kool stop black dura 2 pads (dry). I really like those pads on aluminum wheels.
PostPosted: Fri Nov 16, 2012 6:17 pm
Wow, I have some Eurus wheels on my winter bike that have some significant brake track wear. I better have a closer look at them next time I wash the bike. They do not seem exceptionally worn to me, I have ran other rims like Mavic CXP-33 to the point of being extremely concave before retirement (sorry no numbers).
For brake pads in wet weather, I have found (over many years of rainy winter riding) the best pads in terms of rim life are the Kool Stop salmon. This compound is harder than others so grit and small stones are not as easily embedded in the pads and this helps greatly with rim life. Braking power is adequate but not exceptional. Another thing that really helps with rim life is keeping your bike clean, take the time to rinse off the pads and rims between rides. The worst rides for rim wear are when the roads are wet but it is not actually raining. Here, grit gets on the pads and the rims but it is not being washed off by the rain so every application of the brakes is like taking a grinding compound to the rim.
There are no new unread posts for this topic. Shamal C17 in Dogma 60.1
Daniel1975
Mon Mar 13, 2017 7:17 pm
Daniel1975 View the latest post
There are no new unread posts for this topic. Shamal Mille C17 vs DT-Swiss PR1400 Oxic
bruno2000
7
2500
Sun Apr 23, 2017 11:11 pm
snowdevlin View the latest post
There are no new unread posts for this topic. 10 Speed Cassette on Shamal Ultra 2015 wheelset. Do i need spacer or not?
3Pio
Mon Oct 09, 2017 10:42 am
3Pio View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], darnellrm, erik$, Kojie, MoreRideTime, WESTMOTORSPORTS and 58 guests
cron
