Post new topic Reply to topic  [ 44 posts ]
Go to page 1, 2, 3  Next
 Post subject: Stripping my Caad10
PostPosted: Fri Nov 09, 2012 10:53 am
Sometimes you need something new, or me this feeling comes in the time of the year when the days get shorter...
So, while beeing in love with my Caad9, I have started stripping a Caad10 frame.
This bike is my inspiration,
http://i39.photobucket.com/albums/e157/ ... r900-3.jpg
The frame (size 54) was 1250 gr without bottlecage bolts, derailleur hanger, seatpostcalmp etc.
Hope it will be around 1100gr when finished.
At the moment I just put on some paint removal stuff, see how it will turns out.
 Post subject: Re: Stripping my Caad10
PostPosted: Fri Nov 09, 2012 11:39 am
AWESOME! looking forward to seeing how much you lose :)
David
'10 CANNONDALE CAAD10
'09 YETI 575 BLACK
'97 Bully Piston
'91 GT ZASKAR Build #2010
PostPosted: Fri Nov 09, 2012 9:46 pm
I always wanted to do a polished aluminium bike. Just seems silly to paint aluminum somehow. GOOD LUCK!
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Fri Nov 09, 2012 9:47 pm
Wow I have the same frame. Silently inside a part of me is crying.
White paint is heavy though.
PostPosted: Sat Nov 10, 2012 10:06 am
Cool project, and nice workshop!
PostPosted: Sun Nov 11, 2012 2:25 am
I was thinking of getting my Caad10 anodized purple and having the hollowgram arms anodized green. I have the 2012 brushed aluminum frame and I am kind of bored of it.
PostPosted: Sun Nov 11, 2012 6:11 am
I hope you weren't stripping the frame just to get 150 grams off.
you are in for a disappointment. It will be in the order of 60-80 grams.
Now if it was for the polished finish, then you'll have a double bonus.
But be prepared, it's gonna take some work or money to get it a nice
as the one in the pic. Hope it comes out well.
Second, white paint is not any heavier than other colours. What you're
getting confused with is that on a carbon frame which is black, it takes
more coats to get the coverage to look white or a bright yellow not to
have a green tinge to it.
As for the anodizing. A frame can be anodized if: any steel inserts on the
frame such as water bottle bosses are drilled out and new ones installed after
anodizing. And.. if you understand that anodizing colours are affected by
the particular alloy being anodized. So the weld zones, which are a different alloy
than the tubes won't have exactly the same shade of purple as the tubes.
Black won't be as bad as some other colours. A good anodized will be able to tell
which colours will come out with the least problems.
AEROLITUS-defender of the faith
PostPosted: Sun Nov 11, 2012 7:22 am
Here is a frame that was stripped, polished, and then anodized, which shows the difference in colour on the welds that wally318 is referring to. I wouldn't actually do the hollowgram arms though.
http://jackchou.com/bicycles/p3/
Scroll down on this link
http://forums.roadbikereview.com/cervel ... 62-12.html
PostPosted: Sun Nov 11, 2012 3:53 pm
My first reason to strip the paint is because I don´t like the liquigas colors.
On the other hand I am very impressed by the polished r600
Little weight savings comes second, but would be nice.
After stripping the downtube I have saved 10 gram...
Here is how the fork and frame look by now
PostPosted: Sun Nov 11, 2012 7:48 pm
Buffalo wrote:
The result of this one is just amazing!!!
My 1998 Trek 5220 paint stripped 7.02Kg
PostPosted: Mon Nov 12, 2012 8:37 am
This is what happens with anodizing:
Welds look shitty, but overall very nice.
PostPosted: Mon Nov 12, 2012 12:04 pm
Meh....retro-look the welds by doing a hand lug lining (old school....and yeah, I know it doesn't have lugs) if you really hate them. I'd be more worried about changes in composition of the thin section tubes. Caustic processes (both stripper and anodising) remove zinc from the alloy quicker than it removes Al doesn't it?? (or are the changes so small as to make no difference?)
Used to race....got too wrinkly and old ;) Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
PostPosted: Mon Nov 12, 2012 9:07 pm
I don't think it's too bad. Sloppy untouched welds are never going to look good, even with paint. The contrast from the anodizing maybe gives it a no-nonsense look. In any case, what's this about "only" 50-80 grams???? People spend $200+ to save that much. And a quick search to this forum finds examples where it is indeed 100g+.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Tue Nov 13, 2012 2:34 am
On a round tube frame like a C'dale that's about all you'll save on an alum. frame.
On a bladed frame like Cervelo etc a bit more because of large flat surface+ more
paint. Only alum frames that have really heavy paint are when they're powder
coated, which is much thicker than standard 2 part epoxy type paints. Also much
harder to get off. 100+ grams of paint are usually on carbon frames.
PostPosted: Thu Nov 15, 2012 5:31 pm
Have the most paint off teh front triangle, down to 1170 now.
Guess it will end up around 1130..
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Helmutti, MarkThailand and 47 guests
This topic is locked, you cannot edit posts or make further replies. Stripping advice
carbon337
Mon Mar 04, 2013 9:56 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Frame stripping advice.
weeracerweenie
11
922
Mon Jul 23, 2012 1:25 am
weeracerweenie View the latest post
This topic is locked, you cannot edit posts or make further replies. Stripping paint from a CF frame
wally318
Tue Oct 23, 2012 9:25 am
NiFTY View the latest post
There are no new unread posts for this topic. CAAD10 Women’s
14
543
Sat Apr 06, 2013 11:57 pm
ultimobici View the latest post
There are no new unread posts for this topic. Build up R3 or CAAD10?
highwater
Fri May 25, 2012 4:40 am
Tinea Pedis View the latest post
It is currently Sun May 19, 2013 11:55 am
