Post new topic Reply to topic  [ 6 posts ]
PostPosted: Wed Nov 07, 2012 9:12 pm
Hi the problem i have is compact isnt small enough for where i am (south spain) i currently have 50/34 ultegra chainset, and i want to go smaller would a Mountain bike chainset fit or work? What's my options?
PostPosted: Wed Nov 07, 2012 9:33 pm
http://praxiscycles.com/pages/cx-rings
These won't look as good as the Ultegra rings, but it will work just fine.
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Wed Nov 07, 2012 9:44 pm
Thanks for that but (currently have 50/36) which is to big Im after more of a mounting bike gear ratio?
PostPosted: Thu Nov 08, 2012 7:50 pm
Rotor does 46/34 rings if that is enough. You could always install a 2 ring MTB crank, but that may require some custom work.
Scott Foil Di2 2012
Scott Scale 35 2010
PostPosted: Thu Nov 08, 2012 7:54 pm
What range does your cassette have? There might be some more inches lost there.
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Thu Nov 08, 2012 9:41 pm
Many compact cranks can take 33t rings. On some the crank arms are too long and interfere with the chain side plates. Harris Cyclery sells 33t rings in the US.
As mentioned above you can also get larger cassettes. With the popularity of wide range road cassettes there are plenty of options. You may need a different derailleur if you go over 30t. With Shimano, you can use a 9sp MTB rear derailleur to shift 32t and 34t cogs. The Sram 11-32 looks like a good wide range cassette for road use.
You can fit many MTB cranks if the BB you use has provision (usually spacers) to work on a 68mm BB. But the Q factor will be higher and it may be difficult to find large chainrings that are large enough for enough gear inches on the descent.
Users browsing this forum: Exabot [Bot], Google [Bot], Majestic-12 [Bot], Wookieopolis and 57 guests
There are no new unread posts for this topic. Attachment(s) SRAM red 2.2 chainset?
verycreativeusername
10
807
Fri Nov 30, 2012 5:19 am
tweeks View the latest post
There are no new unread posts for this topic. Need your help with the correct chainset for a pressfit BB
WasFab
Thu Jun 28, 2012 2:38 pm
WasFab View the latest post
There are no new unread posts for this topic. Chainset and BB for Scott Plasma 3 TT
portiabaines
7
258
Mon Feb 11, 2013 11:22 pm
Stuartclark1977 View the latest post
There are no new unread posts for this topic. Which bb30 chainset to fit Q rings
dane476
Mon Oct 22, 2012 10:01 pm
Zigmeister View the latest post
There are no new unread posts for this topic. BB30 Chainset weights
stevenb
Mon Nov 05, 2012 9:06 pm
Anders View the latest post
It is currently Wed Jun 19, 2013 12:46 am
