Post new topic Reply to topic  [ 66 posts ]
Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Wed Nov 07, 2012 11:37 pm
Like all good research is needs to verified independently. It is a starting point though.
www.thecycleclinic.co.uk
PostPosted: Thu Nov 08, 2012 12:02 am
WMW wrote:
ticou wrote:
I pay for goods not information.
This sort of information is important for deciding what goods to buy. And it's relatively cheap information. And it cost a lot of money and time to obtain.
If you feel that all information should be free, then that means you are fine with being limited to information that costs little or nothing to obtain, or some other party profits from dispensing... ie they have an ulterior motive for making it available, and it is usually tied to advertising. That isn't a very good way of finding out the truth.
A fair point, but I use my 30 years experience on bikes, the valued experience of top flight independent lbs's, the track record of a company,multiple owners opinions, and only then did my aesthetic and gut feeling go for Campy. I do not rely on advertising, ever. A youtube vid might help, but that's the cherry on the top.
PostPosted: Thu Nov 08, 2012 12:36 am
Tubbie Guru
Hi,
IOW a perfectly subjective choice.
Whilst I agree that Campa's stuff is leading edge as far as combatting friction goes in currently available grupos and wheels, I must add that there's still quite a margin for improvement left.
Ciao, ;)
PostPosted: Thu Nov 08, 2012 2:45 am
fdegrove, earlier in this thread you mentioned optimising your bikes for 'as low as possible friction'. Any pointers you could give the rest of us?
Not necessarily looking for something along the lines of this component friction testing study, but more around the type of 'adjustments' you would normally make to hubs (e.g. tighten/loosen cones), freewheels (e.g. different grease), any specifics around chain lube etc.
You obviously have a lot of experience so would love to hear your thoughts.
I know you've written posts along these lines before, but I find it difficult finding the gems. It could also tie in nicely with Tinea's road forum index?
Storck Fenomalist 6.8kg
PostPosted: Thu Nov 08, 2012 3:41 am
Have you read the report? I think it might disagree with you...
Much of the friction on the bike is simply impossible for a rider to discern. It's too small... people can't even detect a 10W increase in drag from the tires, let alone 1W in the bearings.
formerly rruff...
PostPosted: Thu Nov 08, 2012 3:46 am
bikedoc wrote:
does anyone really worry about how much energy a jockey wheel is costing them??
after watching this video and comparing to your own stock pulleys you tell us - is there a potential difference and also could the mental encouragement gained also help your performance? http://www.youtube.com/watch?v=KiXH7HDRPKYAfter" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;"
I've added up a number of individual 3 - 4 or more watts saved (claimed) from a few focused aero improvements, riding fine tubbies, and bearing improvements (w/Campy CULT). While each one incrementally is a pretty small gain, the real life collective gain from all of them is VERY noticeable to me - having 2 very similar bikes that only differ in the areas just noted. Plus knowing what I've done I take on an added pressure to perform to the level of my equipment - no let downs.......so collectively reducing watts and gaining the "encouragement" from the improvements I've found it to be quite frankly....addicting....... :beerchug:
And here is another example - again training, tactics, personnal genics, etc, etc will be most important, but incremental gains in other places can add up. http://www.youtube.com/watch?v=IpLbLJhe ... re=related
PostPosted: Thu Nov 08, 2012 8:46 am
There is no such thing as perfection in bikes, but when you get subjective and objective smoothy woothies, I'm a happy camper with Chorus.
PostPosted: Thu Nov 08, 2012 12:58 pm
Tubbie Guru
Hi,
Why would it matter when someone can discern the difference or not? Surely if it can be measured it must be there?
1W here, another Watt there....At the end of the day it all adds up and that's what it's all about I would think....
Ciao, ;)
PostPosted: Thu Nov 08, 2012 7:34 pm
I think you are misunderstanding me... you claim to have "perfected" your drivetrain losses, without test data. Since the differences are too small to be discerned by the rider, how could you know this is the case? Spinning parts in your hand certainly won't do it... it has to be under load.
formerly rruff...
PostPosted: Thu Nov 08, 2012 7:58 pm
on the loaded vs. unloaded point ... is there any convincing research that supports that for bicycle components - i.e. that there is little or no positive correlation, or even a negative correlation - god help us - between friction when unloaded and friction when loaded in a drivetrain/wheels?
PostPosted: Thu Nov 08, 2012 8:09 pm
Unloaded friction is going to be mostly seals and grease so long as the bearings are properly adjusted. This is a big deal with some new and recently overhauled parts, since it takes time for grease and seals to "break-in". If a new part spins very easily, it probably has crappy seals and light grease... and will need to be overhauled more frequently, while providing very little resistance benefit.
Under loads, the actual bearing friction comes into play along with any issues due to bending and misalignment.
formerly rruff...
PostPosted: Fri Nov 09, 2012 1:00 am
Tubbie Guru
Hi,
That does not mean there is no test data. Data taken from one set up can be ported to the next one and so on.
It isn't exactly rocket science either.
Probably always the case with industrial bearings: when it spins suspiciously easy it more often than not tells you it is of the low tolerance, low quality metal retainer type.
The problem with these industrial bearings is that no matter how good they are, none of them are designed with our kind of use in mind.
You occasionally come across some that have been made to order or carefully selected for our kind of application but I bet that most guys in the industry just can't be bothered.
Which is why these measurements are so important. If it clearly shows that better bearings/lubricants/seals etc. are wortwhile we'll at long last have some leverage.
@Sawyer: You can safely say that there is no correlation.
Ciao, ;)
PostPosted: Fri Nov 09, 2012 2:10 am
http://www.cyclingnews.com/features/fri ... efficiency
PostPosted: Fri Nov 09, 2012 2:13 am
Looks like James lurks ;)
PostPosted: Fri Nov 09, 2012 3:07 am
Jason (Friction Facts Man) is based in Boulder, so James and I are both on this. :) He's doing some exclusive testing for us, for an upcoming issue. In fact, James mentions it...
VeloNews Magazine/VeloNews.com tech
Contact always welcome - http://velonews.competitor.com/author/cfretz / cfretz at competitorgroup dot com.
Twitter: @CaleyFretz
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
Users browsing this forum: 11.4, Bing [Bot], eric, ethan44, MarkThailand, rijndael, Rippin and 44 guests
There are no new unread posts for this topic. Revisiting old school cranks and friction testing
Praha19300
Sat Feb 16, 2013 3:18 am
fdegrove View the latest post
Praha19300
20
1046
Tue Feb 19, 2013 1:25 am
There are no new unread posts for this topic. C4 bike component hubs review and experience
devinci
35
3933
Mon Nov 19, 2012 11:52 pm
notthatmark View the latest post
This topic is locked, you cannot edit posts or make further replies. Giant- The Truth About Road Frame Testing.
durianrider
Sun Nov 11, 2012 10:06 am
metal View the latest post
There are no new unread posts for this topic. Attachment(s) New frame testing data comparing top bikes (by Giant)
[ Go to page: 1, 2, 3, 4 ]
Ryan94
57
5515
Tue Oct 16, 2012 3:53 am
53x12 View the latest post
It is currently Sun May 26, 2013 1:29 am
