Post new topic Reply to topic  [ 12 posts ]
 Post subject: need saddle help.
PostPosted: Mon Nov 05, 2012 10:17 pm
Again, sorry if i'm missing a topic somewhere for this, but i need help.
I weigh 93kg. Would it be safe to ride a AX-lightness Apollo saddle for Road use?
Cheers, Daniel
Storck Fenomalist 6.3kg.
BMC Teammachine SLR01
 Post subject: Re: need saddle help.
PostPosted: Mon Nov 05, 2012 10:42 pm
Weight limit for the Apollo is 85 kg, so from my point of view, no I would not call it "safe" to ride. Maybe if you were 1 to 2 kg over the limit, but 8 kg over is a little much in my book. The last thing I would want is to sit down and have that thing snap under me 50 kilometers from home. If that, or possibly having exposed broken carbon fibers jammed in your rear at some point sounds like too big of a risk, I would look elsewhere.... Really depends on what your definition of "safe" is. I really believe a saddle is one place not to skimp on.
viewtopic.php?f=10&t=112392 -Gallium Pro
viewtopic.php?f=10&t=100286" -Trek Madone
PostPosted: Mon Nov 05, 2012 10:49 pm
My concern is carbon splinters up the bum...
PostPosted: Mon Nov 05, 2012 11:01 pm
Most likely the the rails/rail to saddle joint would fail first, which would be bad but not the worst possible scenario. It would be more of a challenge for the saddle itself to fail along the middle which might lead to the dreaded splinters up the bum. But after having my seatpost fail out on a ride, a few added grams is a sacrifice I would make to be sure that would never happen again.
PostPosted: Mon Nov 05, 2012 11:05 pm
Do it. Don't you think they are possibly a bit conservative and there would be a few Kg here or there of tolerance?
PostPosted: Mon Nov 05, 2012 11:33 pm
If you do it, watch out for those potholes.
PostPosted: Mon Nov 05, 2012 11:49 pm
I'm about your weight and have ridden both a carbon aspide with ti rails and a full carbon SMP w/ carbon rails.
on the carbon aspide, the joint between the rails and the saddle became creaky and loose (as hornedfrog says), but only after several years and many, many miles. (I can't remember the exact mileage, but it was around the mfg's projected lifetime for the saddle).
the full carbon SMP didn't fare as well. one of the carbon rails cracked after 2 1/2 years. the saddle itself was fine, and the joints were still good.
I replaced it with a carbon SMP w/ steel rails.
on balance, I would advise against the Ax lightness. but if you want to take the chance, you can probably get away with it for awhile. I don't think the saddle itself splintering is very likely. the rails may go sooner for you than for an <85kg person.
"I can't understand why people are frightened by new ideas. I'm frightened of old ones." -- John Cage
http://weightweenies.starbike.com/phpBB ... 928#126928
PostPosted: Tue Nov 06, 2012 12:18 am
So the main concern is the rails cracking. I can live with that. Now i read that the Apollo isn't that nice a ride. So maybe i should go for something els. The Kom-vor is allso limited, but should be the same story?
PostPosted: Tue Nov 06, 2012 12:26 am
Try Berks combo. I had mine spec'ed to 90 kg and the whole combo weighs in at 165 g
Cervelo R2.5
Cervelo P2c
Cervelo R3
Parlee Z3
Parlee TT
PostPosted: Tue Nov 06, 2012 3:57 am
This might be a good saddle :wink:
http://www.google.com/imgres?q=english+ ... ,s:0,i:179" onclick="window.open(this.href);return false;
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 Matt black
2012 Cannondale EVO "Storm Trooper" white and black
PostPosted: Tue Nov 06, 2012 8:45 am
http://www.google.com/imgres?q=english+ ... ,s:0,i:179" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
It's never too late to make fun of a guy ho can't spell right ;)
PostPosted: Tue Nov 06, 2012 3:12 pm
Smud saddle - http://smud-carbon.eu/saddle.html - could be an option.
Weight limit: 100 kg
Price: 119€ (+10% for the weight upgrade)
Comfort: Should be fabulous
Mine should be arriving from Poland shortly...
2012 Canyon Aeroad CF 8.0 Di2 (6.250 grams)
2010 Canyon Grand Canyon F6
2012 (2013?) Canyon Speedmax Evo (is ordered)
Users browsing this forum: Bing [Bot], Google [Bot], Martin.F, woz9683 and 58 guests
This topic is locked, you cannot edit posts or make further replies. saddle bag anyone?
addictR1
Tue Apr 23, 2013 6:31 am
addictR1 View the latest post
There are no new unread posts for this topic. Stripped SLR saddle
hillrider
11
1058
Mon Dec 17, 2012 10:12 pm
artray View the latest post
There are no new unread posts for this topic. Need help-What clamp can I use with my saddle?
Bianchi10
Mon Oct 29, 2012 1:27 am
Bianchi10 View the latest post
There are no new unread posts for this topic. Why the weird looking TT saddle ?
Wadl
7
1063
Thu Dec 13, 2012 5:39 am
spinwax View the latest post
There are no new unread posts for this topic. How would you consider a saddle is worn-out?
kai-ming
12
903
Mon Sep 10, 2012 10:28 am
thisisnotaspoon View the latest post
It is currently Wed May 22, 2013 10:05 pm
