It is currently Mon Jan 23, 2017 10:25 pm
Post new topic  Reply to topic  [ 23 posts ]  Go to page 1 2 Next
PostPosted: Mon Nov 05, 2012 9:39 pm
Does it make sense to buy the Assos Bonka winter jacket when I already have a Assos Habu jacket that is meant for early winter? I mean, there is a lot of overlap between Assos jackets and there temperature use. Can anybody help me out here?
http://i891.photobucket.com/albums/ac11 ... 11af34.jpg
http://i891.photobucket.com/albums/ac11 ... 87f433.jpg
PostPosted: Tue Nov 06, 2012 1:18 pm
Which one's lighter?
Cyclist turned music producer
Visiting South West Australia? Visit Crank n' Cycles!
PostPosted: Tue Nov 06, 2012 3:01 pm
I don't know, but I guess the Habu jacket.
PostPosted: Tue Nov 06, 2012 3:13 pm
By WW decree, I think you have your answer.
I also think you are better off buying performance base layers than spending more on a completely separate outer layer.
PostPosted: Tue Nov 06, 2012 3:27 pm
True mate! Its all about base layers. I ride in about any winter weather condition (lets say up to -10C) and believe it or not down to 2C I use only two base layers and my typical summer jersey with arm warmers. Warm enough, super breathable and keeps me from looking like a Christmas Fred (at least for a while). Lower body wise I use my normal bibs with normal leg warmers.
Good gloves and overshoes are the key for me.
Strava
PostPosted: Tue Nov 06, 2012 4:26 pm
First question to answer is are you cold in your habu ?
PostPosted: Tue Nov 06, 2012 5:02 pm
I have both. The Assos Bonka is warmer and has better neck protection. There is considerable overlap because you can wear base layers with both. I think both are great jackets.
PostPosted: Tue Nov 06, 2012 5:18 pm
No until now I am not cold in my Habu, but I have not used the Habu in temperatues below 5 degrees C.
I think that the Habu can be used in fall, winter and spring. The Bonka is winter only, I guess but maybe bonka rocks during the winter.
Can you tell me more about the Bonka Sedluk? Which one do you prefer and why?
PostPosted: Wed Nov 07, 2012 1:50 am
I would not claim to be an expert in cold weather riding. I really have a distaste for cold weather riding.
Assos recommends wearing a base layer and I think it makes sense. The big problem is trying to keep your temperature warm enough but not so warm that you start to get sweaty. If your garment in not breathable or not breathable enough then you get clammy and bad things happen. You get cold and even worst you get chaffing ect…
So your Assos base is very breathable and by the time it is cold enough to wear either the Bonka jacket or the Habu jacket it is time for a long sleeve base. I have several thicknesses of base.
The Bonka is both a little thicker and a little warmer but also has a little more wind protection on the arms but probably more noticeably better wind protection on the top of the shoulders and neck.
My experience would suggest dressing so that you are a little on the cold side but pay attention to where you are the coldest. If you are wearing the Habu with a base layer and you are still a little too cold overall then a thicker base is probably the best move. But I find that with the Habu and medium or thick base it will eventually be the wind on my shoulder and upper arms that is the cold spot. At that point if I ride in colder weather then the Bonka with a thinner long sleeve base would keep me a little warmer but also more evenly cool.
I think the general rule would be error a little on the cool side and also a little on the more breathable side which generally means cooler fronts of the arms, shoulders and neck where the wind is hitting you.
To complicate this is how sunny. windy or humid and how fast of a ride. And then the problems of a longer ride were the temperature is rising or falling.
So there you have it, from a guy that is not very good at riding in the cold.
PostPosted: Wed Nov 07, 2012 8:47 am
Thanks for your imput. I will try and error in teh weeks to come. The weather in the Netherlands is not that harsh during winter, but it can be cold. I bought a Assos winter base layer already so I will try it in combination with the Habu. The craft base layers that I use are fine and excelent together with the Habu.
If the weather starts to be really cold in de months to come and the Habu combination is not warm enough I will buy the Bonka.
PostPosted: Thu Nov 08, 2012 6:44 pm
I have both, the Bonka is the warmer, and has the built in neck gaiter. The Habu seems to be a looser fit and so you could get thicker base layers under it if need be. For real warmth get the Fugu!!
Riding my road bike in North Wales
http://www.strava.com/athletes/keith_robertson
PostPosted: Thu Nov 08, 2012 11:34 pm
I also have the Fugu, it is very thick and the built in hood is amazing. But it is not very breathable. The latest line of Assos jackets are much more breathable than the element one, 851 and Fugu and it is huge difference. I hope they update the Fugu someday with all of their latest materials.
PostPosted: Fri Nov 30, 2012 10:44 pm
I was thinking the same Habu v Bonka
PostPosted: Sat Dec 01, 2012 7:49 am
I bought the Bonka as well. I have the Habu and the Bonka now and both jackets are different enough to purchase them both. The Bonka is warmer, thicker and heavier. The Habu is great when the temperature is not too cold and autumnal.
PostPosted: Tue Aug 20, 2013 3:10 pm
Bonka in Swedish... Hmmm... :)
There are no new unread posts for this topic. Assos clothing question
KCookie
9
1277
Fri Dec 23, 2016 7:43 am
asc8ic View the latest post
There are no new unread posts for this topic. what does 311 mean on my assos germany flag jersey?
mike
12
1309
Mon Oct 24, 2016 1:45 am
mike View the latest post
There are no new unread posts for this topic. Has anyone gone through WARRANTY or CRASH REPAIR with ASSOS?
g32ecs
10
765
Sun Jan 15, 2017 2:29 pm
robo View the latest post
There are no new unread posts for this topic. Online sources question: Campy + Assos
dgasmd
Wed Jul 27, 2016 7:34 am
AJS914 View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], go4custom, Google [Bot], Hawkwood, kavitator, MSNbot Media, snowdevlin, Yahoo [Bot] and 34 guests
