Post new topic Reply to topic  [ 8 posts ]
PostPosted: Mon Nov 05, 2012 2:51 am
Hey All,
I have a flat bar which I was going to apply bar tape to and wanted to use a set of crosstop levers as the primaries. The Tektro levers I bought come at their smallest for 24mm bars, my bar is oversize 31.8mm tapering from the center down to 22mm. Because I don't want to mount them very close to the middle of the bar the 2mm discrepancy is causing a bit of a headache.
Would I be committing some heinous act if I were to mount them over the top of the bar tape in order to get them snug?
Cheers,
Tom
PostPosted: Mon Nov 05, 2012 2:55 am
Well, I don't know about heinous, but they may slip over time.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Mon Nov 05, 2012 8:01 am
Bar tape would make a pretty poor shim. I have installed levers with 24 mm clamps on 22 mm bars before by taking a seatpost shim of approximately the right thickness, and chopping it down to be the width of the clamp. So far the lever hasn't moved at all, and you can barely see the shim under the clamp.
PostPosted: Mon Nov 05, 2012 11:05 am
Wrap of old inner tube underneath will do it. Its grippy and less likely to slip than bar tape
Cervelo S3 2011. Blinged 6.718 Kg
PostPosted: Mon Nov 05, 2012 12:31 pm
The rubber spacers that come with lights and computer mounts would work. They come in different thicknesses and can be easily cut to size.
Your LBS has probably got a few in the spares box.
I always keep the spares. They can be extremely useful.
PostPosted: Mon Nov 05, 2012 8:48 pm
Thanks for the pointers guys! I thought as much, it wouldn't be the worst thing in the world but has potential to slip. I have an inner tube which I regretfully made a mess of recently so it sounds like that will be the perfect application. :D
PostPosted: Fri Nov 09, 2012 4:21 am
I would NOT use rubber to shim the levers. I would use plastic in a pinch, but aluminum would work so much better. Rubber has too much give, something with as much leverage as levers (that sounds weird) will surely be able to slip no matter what.
There must be something at the local hardware store that incorporates aluminum strips 0.8-1.0mm thick.
PostPosted: Fri Nov 09, 2012 11:42 am
Trust me, a single layer of inner tube wont slip. Its pretty solid and doesnt squidge that much. It wont damage bars and costs nothing and can be cut to exact size easily. Its an old MTB trick to put it under levers etc to stop them moving
Those pads you get under lights and other clamps are either plastic or rubber, no different from inner tube other than the can be specific shapes
Users browsing this forum: BikeNerd2453, bman11, Google Adsense [Bot], shimmeD, tdudzik and 55 guests
There are no new unread posts for this topic. Which sram levers
Stockie
Fri Jun 08, 2012 1:07 am
etownfwd View the latest post
There are no new unread posts for this topic. Attachment(s) Light brake levers
bm0p700f
20
1046
Mon Oct 22, 2012 7:01 pm
peruffo View the latest post
There are no new unread posts for this topic. crash resistant levers
gt5504b
10
639
Sat Nov 10, 2012 10:57 pm
Foo View the latest post
There are no new unread posts for this topic. Compatibility Cable Set with Campy Chorus 10s QS levers
kojtl1000
Mon May 06, 2013 5:58 pm
bikerjulio View the latest post
There are no new unread posts for this topic. How much can I tighten levers on Zipp VukaSprint bars?
Zak
Fri Apr 05, 2013 9:38 pm
Zak View the latest post
It is currently Wed May 22, 2013 4:13 am
