Post new topic Reply to topic  [ 1 post ]
PostPosted: Fri Nov 02, 2012 8:43 pm
I have a new bb30 frame (BMC TM01). I want to run compact rings (50-34) and 170mm crank arms. I'll be running Ultegra mech to start and then switching over to Ui2 TT as soon as its available.
I want to optimize for good front shifting with the Ui2. Which crank-based powermeter and rings do you recommend? Any significant difference/benefits between native BB30 crank vs GXP/hollowtech + BB30 adapter?
I've had good experiences with Quarq in the past, but also open to other suggestions.
Users browsing this forum: Bing [Bot], budgetweenie, ElNotorio, Google Adsense [Bot], HammerTime2, Helmutti, KKB, konky, MattSoutherden, natiedean24 and 71 guests
There are no new unread posts for this topic. Attachment(s) Lightest BB30 powermeter
jainsworth123
Sat Apr 20, 2013 5:23 pm
JackDaniels View the latest post
There are no new unread posts for this topic. Best non SRM crank based power system for Campy 11 speed?
iscarrr
Sat Jul 14, 2012 12:05 pm
gregalfa View the latest post
There are no new unread posts for this topic. Attachment(s) S-works vs Lightning crank for powermeter use.
Kasparz
Fri Aug 10, 2012 1:48 am
There are no new unread posts for this topic. Which compact crank with DA7800
wassertreter
9
355
Fri Feb 22, 2013 3:33 pm
totoboa View the latest post
There are no new unread posts for this topic. Power2max bb30 crank (alternatives?)
tri
Mon Jul 23, 2012 10:45 pm
Beancouter View the latest post
It is currently Wed May 22, 2013 1:45 pm
