Post new topic Reply to topic  [ 10 posts ]
 Post subject: Time iClic Click
PostPosted: Thu Nov 01, 2012 12:37 pm
I have had a repetetive click coming from my pedals - at least that is what I am leaning towards. It's at the same point of the pedal stroke and with some elimination seems to be coming from my left pedal. I replaced the cleats thinking that might have been the problem. It didn't solve it but the sound level seems to have diminished a little which leads me to believe that with a new cleat the click might be coming from the fibre spring.
Has anyone else had a similar problem with iClics? And if so what was the fix?
Don't let the truth get in the way of a good story......
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
 Post subject: Re: Time iClic Click
PostPosted: Thu Nov 01, 2012 12:45 pm
I had a similar issue with clicking but is was dry threads in the cranks for the pedal axles that solved it for me ! not iclics too
PostPosted: Thu Nov 01, 2012 6:06 pm
I know exactly what you mean. My iClics v.1 when used with the original cleats did not click. They have only clicked with the v.2 cleats. I haven't been able to solve it. The Time iClic system is clearly defective. Nuff said.
PostPosted: Fri Nov 02, 2012 12:20 am
Maybe an email to Mr Time.....
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
PostPosted: Fri Nov 02, 2012 10:33 am
Try riding the bike uphill wearing trainers rather than cycling shoes. If it still creaks only when pushing with the left pedal it's probably the left pedal/crank connection or the bottom bracket. I would try a good sized lump of Ti prep, coperslip or shimano assembly compound on the axle threads. Sometimes a minimalist application of grease isn't enough.
PostPosted: Fri Nov 02, 2012 5:42 pm
I got rid of a very nasty clicking with these pedals using coppergrease on the threads
Eventually though I just got rid of these very nasty pedals.
Di2x2
PostPosted: Sun Nov 04, 2012 12:18 am
Thanks for the tips Mr Fish.
Steve - I've tried a lot of pedals and these ones have been the best all round pedal for me. They do have their flaws but one feature I really like and hate is the way you can be engaged in the pedal without being locked in properly. This means you can get going uphill or even on the flat when the pace is on and worry about getting the cleat in right after your up to speed. It also means that you sometimes have to faff around getting your cleat located properly.
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
PostPosted: Sun Nov 04, 2012 10:31 am
Have you checked that your cleats are tightened?
PostPosted: Sun Nov 04, 2012 12:07 pm
Yep, first thing to check of course :wink:
Argon
CAAD9 6.78Kg
Supersix 6.78Kg
PostPosted: Mon Nov 12, 2012 1:40 am
Been using iClic IIs now for about 6 months with great success. No cicking sounds to date.
Users browsing this forum: addictR1, Bing [Bot], bruno2000, Google [Bot] and 44 guests
There are no new unread posts for this topic. Time VX Edge
willboslice
Mon Oct 29, 2012 1:43 pm
willboslice View the latest post
There are no new unread posts for this topic. Broken Time.
Kevin3182
18
1493
Wed Aug 29, 2012 3:52 pm
em3 View the latest post
There are no new unread posts for this topic. Advice needed - TIME or LOOK
chris217
16
1238
Tue Jun 26, 2012 8:52 pm
MattSoutherden View the latest post
There are no new unread posts for this topic. Attachment(s) Time xpresso pedals
[ Go to page: 1 ... 5, 6, 7 ]
ninjanoir78
99
8584
Fri Apr 26, 2013 12:33 pm
JKolmo View the latest post
There are no new unread posts for this topic. HELP. BB30 on Time NXR is driving me mad
wakadaka
Fri Nov 02, 2012 4:24 pm
styrrell View the latest post
It is currently Fri May 24, 2013 8:09 am
