Post new topic Reply to topic  [ 4 posts ]
PostPosted: Wed Oct 31, 2012 8:58 pm
So my super record cranks have started to develop a bad creak,
I have tried grease, Carbon paste and even had the shop locktite them but after 20 k's it started again.
The next step is use specialized glue and glue the cups in then glue the campy cups in to them.
If this fails im considering the s works cranks or some hollowgram's.
Is there any weight saving from campy 53/39 2011 super record to the specialized ones?
Has any one here glued there cups in as specialized have started recomending now?
Thanks
PostPosted: Thu Nov 01, 2012 1:33 am
Do you have BB30? See if this doesn't answer your question...
viewtopic.php?f=3&t=93006
That's right, I said it!
PostPosted: Thu Nov 01, 2012 1:38 am
Yes- Specialized cranks will be lighter.
You want to use yellow loctite to secure the delrin bb cups into the frame. I believe the specific loctite is 641.
PostPosted: Thu Nov 01, 2012 1:49 am
There's a several threads at RBR http://forums.roadbikereview.com/specialized/c-bear-osbb-campy-adapter-install-281423.html on this issue with Campy,
The C Bear adapter seems to be the best solution for campy
Users browsing this forum: Alexa [Bot], Google Adsense [Bot], jmilliron, Majestic-12 [Bot], MixMastaPJ, mpower and 62 guests
There are no new unread posts for this topic. New crank from Praxis Works
Ritterview
20
2921
Sat Oct 06, 2012 1:39 am
redhed18 View the latest post
There are no new unread posts for this topic. Attachment(s) S-works vs Lightning crank for powermeter use.
Kasparz
Fri Aug 10, 2012 1:48 am
There are no new unread posts for this topic. Help with Wheel Choices Pls
dvincere
Tue Feb 19, 2013 10:19 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. New bike choices
rich00
14
1217
Mon Mar 18, 2013 1:05 pm
FeitoSpain View the latest post
There are no new unread posts for this topic. whats my next upgrade between these choices
Bianchi10
Tue Sep 25, 2012 1:10 am
Bianchi10 View the latest post
It is currently Wed May 22, 2013 4:15 pm
