Post new topic Reply to topic  [ 9 posts ]
 Post subject: Shorten seat post...?
PostPosted: Tue Oct 30, 2012 7:35 pm
Any rule of thumb on how much you can cut of the seat post, without compromising safety...? As in "how many cm's seat post is necessary in the seat tube?
Looking for more unnecessary grams to shave of the bike... :)
2012 Canyon Aeroad CF 8.0 Di2 (6.250 grams)
2010 Canyon Grand Canyon F6
2012 (2013?) Canyon Speedmax Evo (is ordered)
PostPosted: Tue Oct 30, 2012 7:39 pm
General rule of thumb is that the seatpost needs to extend past the top-tube junction by 1 or 2 cm.
viewtopic.php?f=3&t=38112
viewtopic.php?f=3&t=90014
:thumbup:
Exp001
PostPosted: Tue Oct 30, 2012 7:43 pm
Thanks...
And sorry for my lazyness (not using the search function) :)
PostPosted: Tue Oct 30, 2012 8:30 pm
Is there not a min mark on it? Just measure what this is to the end and then make sure you cut off leaving this amount. I think its usually around 10cm...
Lig.
3kbikes.co.uk
For best - Parlee Z3
For training - Colnago EPS AKBL
For the pose - 1980'ish' Basso Steely
PostPosted: Tue Oct 30, 2012 8:39 pm
This must be the safe solution... I'll measure and see where that takes me.
PostPosted: Wed Oct 31, 2012 4:48 pm
actually Prendrefeu was right. Marking on the seatpost is there to indicate the strength of the seatpost, and you should also respect the mininum depth of the seatpost, but more importantly you should use the TT/ST as a reference to prevent frame damage.
    2011 Cannondale Flash F1
      2010 Cannondale Caad9
        2000 Cannondale Caad 4 aero
          1999 Cannondale Caad1
            ???? Concorde SS
deleted the quote.
PostPosted: Thu Nov 01, 2012 3:25 pm
TT/ST = top tube/seat tube?
Meaning you agree that 1-2 cm below the point where the two tubes merge is the minimum seat post length?
PostPosted: Thu Nov 01, 2012 3:52 pm
Correct.
Exp001
PostPosted: Thu Nov 01, 2012 4:28 pm
Thanks...
Users browsing this forum: Bing [Bot], Google [Bot] and 75 guests
This topic is locked, you cannot edit posts or make further replies. Seat post recommendations
Penthousepete
Sat May 04, 2013 5:25 am
cyclistcong View the latest post
There are no new unread posts for this topic. GIANT TCR seat post ( WW alternative )
toride
Tue Nov 06, 2012 9:52 pm
NWSAlpine View the latest post
There are no new unread posts for this topic. Seat Post Shims - Good, Bad? -
mellowJohnny
21
1429
Sat Sep 29, 2012 3:05 am
mellowJohnny View the latest post
There are no new unread posts for this topic. light seat post collar?
ninjanoir78
Fri Jun 08, 2012 6:23 pm
bm0p700f View the latest post
There are no new unread posts for this topic. BMC SLR01 Stuck Seat Post
DartanianX
Thu Jun 28, 2012 9:51 pm
DartanianX View the latest post
It is currently Fri May 24, 2013 1:00 pm
