Post new topic Reply to topic  [ 49 posts ]
Go to page 1, 2, 3, 4  Next
PostPosted: Tue Oct 30, 2012 9:19 am
Not super WW but looks interesting:
http://flocycling.blogspot.se/2012/10/f ... y-flo.html
PostPosted: Tue Oct 30, 2012 10:50 am
I wonder how similar these are to the Zipp 101's. From the published weight I suspect the rim will be over 500g though, there's no way 44 CX-Ray spokes, brass nipples and reasonable weight hubs will build a sub 500g rim to 1600g... FWIW wheelbuilder has the 101 rim weight at 530g so I'll be interested to see how these compare if someone manages to get a weight for these rims.
Apparently my bikes were talking the other day & are undecided whether to upgrade the current rider or get a new one...
one of the schemers...
PostPosted: Tue Oct 30, 2012 3:31 pm
Heavy but I like what I'm seeing!
PostPosted: Tue Oct 30, 2012 3:39 pm
Cool. I really like the shape of that Flo 30.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Tue Oct 30, 2012 3:53 pm
Classic luck for me. I have been going back and forth for months if I should get a custom set of wheelbuilder 101 wheels or just get some kinlin XC279s built. Now the Zipp 101 copy is finally released the week after I buy mine.
PostPosted: Tue Oct 30, 2012 5:39 pm
The Flo 30 shape is very different from the Zipp 101... particularly where the spokes insert. Flo is very round while the Zipp 101 is more pointy. It's hard to get a very rounded shape to not dimple without making the sidewalls beefy... that might be why the 101 is shaped that way.
The Zipp 101 tested poorly for aero in Tour's test compared to a 24mm tall Corima tubular that was very rounded. An inherent advantage of tubulars is that the tire width doesn't change on a wide rim... clinchers will always bulge out a bit.
formerly rruff...
PostPosted: Tue Oct 30, 2012 6:07 pm
Rruff, I've been pondering an idea lately that the key to maintaining aero clincher performance(from the tire standpoint) seems to be a wide rim width outside to outside, without a wide inside to inside width. So something on the order of 15mm width and 23-24mm outer width. You don't get the purported ride quality benefits of a wide rim but your tire maintains a more aero profile(pointy) and better matches the rim sidewalls in width. Another con is you also gain weight with thicker side walls(but this may be happening with carbon clinchers anyways).
It seems like Zipp may be going this route a little bit, as they seem to have stuck with a bead width of 16mm on their firecrest line. Whereas Hed has gone up to 18.2mm on their new Vanquish line.
PostPosted: Wed Oct 31, 2012 9:18 am
Anyone able to have a guess at the rim weight?
PostPosted: Wed Oct 31, 2012 9:25 am
Guess? surely it should be possible to calculate the area compared to the zipp's section and scale the weight. Just from looking at the sections I'd guess 10 to 15% more material than the Zipps, which would give 580g to 610g (rounded). Someone with a CAD program could do an exact calculation.
PostPosted: Wed Oct 31, 2012 9:42 am
I'm going to have to go carbon if I want decent Aerodynamics at under 500g aren't I ? :cry: The best rim I can think of (for aero and light alloy) is the BHS C472w (kinlin XC279) :noidea:
PostPosted: Wed Oct 31, 2012 4:09 pm
If Flo's specs are correct, the rims weigh ~530g.
formerly rruff...
PostPosted: Wed Oct 31, 2012 4:12 pm
Yep... but I hear rumors of a lighter rim with a similar profile being available soon.
formerly rruff...
PostPosted: Wed Oct 31, 2012 4:48 pm
Flo looks to be committed to clinchers. What's out there, if anything, in a similar medium profile in a tubular? I would think there would be significant weight advantages -- plus you avoid the whole carbon clincher heat concerns (edited -- I missed that the Flo is an alloy rim).
Anyone have experience with http://www.yoeleo.com/best-23mm-rim-700c-38mm-carbon-tubular.html ? wider rim, but not sure of the profile....
The Bontrager D3 looks neat in the 38mm height, but all their tubulars come w/DT 180 internals. From what I've read they are not as reliable as the 240 config. And they are only available as a wheelset, not rims.
PostPosted: Wed Oct 31, 2012 5:43 pm
The Corima Winium + tubulars tested extremely well in the wind tunnel. Was more aero than the 101 and a lot of deeper wheels. Weight is 1150g for the set. http://www.corima.com/wheels/winium-plu ... wheel.html
they are 22.6 wide and 24 deep
PostPosted: Thu Nov 01, 2012 5:06 pm
NWSAlpine wrote:
The Corima Winium + tubulars tested extremely well in the wind tunnel. Was more aero than the 101 and a lot of deeper wheels. Weight is 1150g for the set. http://www.corima.com/wheels/winium-plu ... wheel.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; they are 22.6 wide and 24 deep
Winiums look good for a carbon rim. I wonder about an alloy tubular in the Flo shape. Looks like the closest right now is the Hed C2, which is hard to find as a bare rim. Anything else in alloy tubular at the 23 wide range?
Got the profiles for the 23mm wide Yoleo 38mm and 50mm carbon tubulars;[url]the 50 is the exact same graphic as that on the Focus Carbon site http://www.focus-carbon.com/ProductShow.asp?id=559" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;[/url]; it's probably the same as the Farsports as well although they don't have a cross section graphic. I don't see anyone else (yet) with a 23x38 rimm.
Also looks like none of the 23mm wide carbon rims come with basalt brake tracks.
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2, 3, 4  Next
Users browsing this forum: Bing [Bot], carbon2329, CarpetFibre, deek, Exabot [Bot], Google [Bot], VMac and 83 guests
There are no new unread posts for this topic. New Wide Rimmed Reynolds Wheels Coming
geedawg
11
1837
Sun May 27, 2012 5:55 am
lancejohnson View the latest post
There are no new unread posts for this topic. Do latest wide profile wheels increase rolling resistance?
dynaserve
44
2655
Thu Jan 24, 2013 12:02 am
fdegrove View the latest post
This topic is locked, you cannot edit posts or make further replies. Attachment(s) 38mm clincher wheels
Fernandez
Tue Jun 12, 2012 7:11 am
Frankie - B View the latest post
There are no new unread posts for this topic. New more exciting training wheels (clincher)?
tri
9
972
Thu Jan 10, 2013 1:19 am
NealH View the latest post
There are no new unread posts for this topic. Bontrager Aeolus 5.0 D3 Clincher Road Wheels
kingkongsfinger
Thu Dec 13, 2012 4:28 pm
CharlesM View the latest post
It is currently Wed May 22, 2013 4:58 pm
