Post new topic Reply to topic  [ 31 posts ]
Go to page 1, 2, 3  Next
PostPosted: Mon Oct 29, 2012 12:00 pm
Hi all
So, I'm completely confused as to what the difference is between these frames. Given the price difference I assume its down to "quality" of carbon and weight, but even on the Cervelo site I can see nothing that explains it to me. The Team and VWD even seem to be given exactly the same weight despite the difference in price, it appears that the forks are the same throughout the range as well. I give in !
Can anyone shed some light on this for me ?
Cheers
Sean
PostPosted: Mon Oct 29, 2012 12:24 pm
It's weight. The base model was claimed to be about 1200g, the team 1100g, and the vwd 1000g. All in a 56. The ones I've measured have been pretty close fwiw. There might be some marginal ride quality changes (lateral stiffness, vertical compliance), but I haven't ridden all three enough to really tell.
I can tell you that the team frame felt more comfortable on bumps than my s3. To me, anyway.
My Rides:
2011 S3 Sram Red/808's/Zipp SLC2/Romin Pro
2009 SWorks Epic/Handbuilt wheels (by me)/Marta SL magnesiums/ XTR drivetrain
2008 Ellsworth Moment/ Handbuilt wheels (by me)/ Marta SL/ X0 (9spd) drivetrain
K.P.A.
PostPosted: Mon Oct 29, 2012 1:01 pm
Funny how both the Team and the VWD are quoted at 996gm for a 54 size though......
And why don't Cervelo (who pride themselves on engineering etc) put more details about the actual differences on their website ?
Thanks
S
PostPosted: Mon Oct 29, 2012 4:52 pm
where do you see the team at a quoted weight of 996? Because I doubt Cervelo is saying that. Its most likely a misprint.
For 2013 they dropped the 3 different designations and went to 2. VWD and base(which I believe is the old team).
PostPosted: Mon Oct 29, 2012 6:49 pm
It's the same with the R5. Is there any difference between the R5 and the R5 VWD other than 100-150gs. You get a crank with the R5 but otherwise they are similar price. I guess the R5 VWD is replacing the R5 but you would have thought this would have happened by now or Cervelo would have just discounted the R5 earlier to clear stock. It's a bit like the R3 and R3SL but they were priced very differently.
PostPosted: Mon Oct 29, 2012 8:49 pm
THe frame on the base and team is EXACTLY the same. The only difference is the Fork. The same with the R3 base and team.
The VWD is the only bike in the family with a different frame.
PostPosted: Tue Oct 30, 2012 3:46 am
Ghost is correct. They said their "team" frames were lighter due to the paint. Notice base models were generally white. Fork on team bike is lighter. I weighed them once-somewhere between 30-50g lighter if I recall accurately. R5vwd were made in an altogether different factory, I would assume that's the case with the s5vwd as well.
PostPosted: Thu Nov 01, 2012 4:07 am
the base model was actually closer to 1300grams.... team version about 60 to 80grams lighter, and the VWD 990gr depending on size...
PostPosted: Thu Nov 01, 2012 5:21 am
If the frame was any lighter it was due to the paint. The frame is EXACTLY the same between the base and team.
PostPosted: Thu Nov 01, 2012 5:59 am
Here are a couple of links where this has been discussed extensively on the Cervelo Forum, including Damon Rinard and other Cervelo tech gurus weighing in:
http://forums.cervelo.com/forums/p/8604 ... aspx#59656
http://forums.cervelo.com/forums/p/8767 ... aspx#60750
http://forums.cervelo.com/forums/t/8315 ... ageIndex=1
EM3
________________
My 2011 Cervelo R5
PostPosted: Thu Nov 01, 2012 7:29 am
EXACTLY? ;)
maybe u mean the compliance, stiffness and ride is comparable between levels of the S5?
PostPosted: Fri Nov 02, 2012 12:46 am
He means they are the same naked frame. Some are painted as regular s5 bikes, some are painted as s5 team bikes. This is a known fact. This is likely why they're simplifying the naming for 2013
PostPosted: Fri Nov 02, 2012 1:27 am
NOT TRUE...if u peruse the URLs I posted above u could read Damon Rinard himself explaining the differences among the frames (hint: carbon weave and carbon layup is indeed different).
The bigger question is whether Regular Joe Weekend Warrior, the typical Cervelo customer, is astute enough to tell the difference between frames if they were given a blind taste test?
EM3
________________
My 2011 Cervelo R5
PostPosted: Fri Nov 02, 2012 2:37 am
Sorry I maybe mistaken but they aren't the same frames... There's more differences than just the weight & color of the paint...
PostPosted: Sat Nov 03, 2012 8:09 am
It appears I got some info crossed up. I'm pretty sure it was the R3/R3team that I was thinking about. Sorry for the mixup.
As a side note, it looks like the 2013 s5team frames are a lot less "lumpy" than before.
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: corredor_x, starlet82, xcnick and 46 guests
There are no new unread posts for this topic. 3T Ergonova Team Stealth & ARX Team + acetone
Anders
7
3276
Thu Mar 28, 2013 1:16 am
yongkun View the latest post
There are no new unread posts for this topic. S5 Team or VWD
v70cat
43
2642
Sat Jul 21, 2012 12:56 am
jerade View the latest post
There are no new unread posts for this topic. New 3T ARX Team stem is shorter!
neeb
Fri Mar 15, 2013 9:58 am
neeb View the latest post
There are no new unread posts for this topic. 3T Dorico Team Seatpost - To Cut or Not to Cut?
Layback
14
1163
Thu Jun 14, 2012 8:48 pm
Layback View the latest post
There are no new unread posts for this topic. New Cervélo P3
Tillquist
Wed Apr 17, 2013 5:38 pm
NGMN View the latest post
It is currently Fri May 24, 2013 7:53 am
