Post new topic Reply to topic  [ 6 posts ]
PostPosted: Fri Oct 26, 2012 10:44 pm
I'm having the hardest time setting up my Avid BB7 with Ultegra 6700 STIs. With the caliper adjuster almost completely relaxed I can get the disc spinning freely, but don't have enough cable pull to lock up the wheel. With the adjuster on the more closed side there is no way to have the disc spinning without grinding. Disc is Shimano XTR, not the original Avid.
Am I screwed over by the 1:4 (or whatever) cable pull in with recent Shimano STIs?
(Wanted to run non-STIs anyway, but had the Ultegras around and itching to take the bike for a spin)
Bikes: Raceur, Beateur
PostPosted: Sat Oct 27, 2012 3:37 am
May be a dumb question, but do you have road (silver) or MTB (black) BB7's ?
I've had no issue on 2 separate bikes.
PostPosted: Sat Oct 27, 2012 4:12 am
Yes indeed.
It should be a pair of "BB7 Road", the cable pulls are completely different between the standard BB7 and the Road version.
The only slight issues you might have would be with the rear brakes, but that can be resolved with a inline cable adjuster mounted just before the cable mounts onto the top-tube.
PostPosted: Sat Oct 27, 2012 7:18 am
I have the "road" version. Must try harder then ...
PostPosted: Sat Oct 27, 2012 8:05 am
You must "pre load" the cable from the brake caliber. This makes sure that the wire is tigth. Then you adjust from the red knobs, brake pads clearance to the disc.
This has worked with me with all the manufactures: Campagnolo, Shimano and Sram.
PostPosted: Sat Oct 27, 2012 7:20 pm
kampiakseli, thanks, that does the trick.
Seems like the first 10mm of cable pull or so are causing really little movement in the calipers. Preloading it slightly is the trick.
An inline adjuster for that would be handy. Anyone fitted a thread on the BB7? I'm tempted to give it a try.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 37 guests
There are no new unread posts for this topic. Attachment(s) SWISS STOP for Ultegra 6700
project3
Tue Aug 14, 2012 6:59 am
project3 View the latest post
There are no new unread posts for this topic. Tuning Shimano Ultegra 6700
verycreativeusername
Fri Aug 03, 2012 2:18 pm
Rush View the latest post
There are no new unread posts for this topic. Ultegra 6700 double shifter problem
pofijanika
Sat May 26, 2012 2:20 am
There are no new unread posts for this topic. Anyone paint Ultegra 6700 or DA 7900 shifters?
jz4nyc
Sat Jan 12, 2013 4:54 pm
jz4nyc View the latest post
There are no new unread posts for this topic. 105 5700 vs Ultegra 6700 cassettes (with a difference)
downhiller
11
1243
Fri Jan 25, 2013 2:39 pm
downhiller View the latest post
It is currently Sun May 19, 2013 7:52 am
