It is currently Sun Feb 26, 2017 4:30 am
Post new topic  Reply to topic  [ 51 posts ]  Go to page 1 2 3 4 Next
PostPosted: Thu Oct 25, 2012 11:22 am
I was wondering what stem length most people prefer around here for road biking. I have mostly ridden with 100mm stems, a few times with a 120mm - pretty standard geometry with 73 deg HTA and a normal fork (my guess is a 49mm rake, still checking).
I found the 100mm usually rode nicer, a bit faster steering, whilst the 120 felt a bit more sluggish.
What's your favorite stem length from a point of view of handling? (from a visual point of view I find 120-130mm best :))
No longer in the industry
PostPosted: Thu Oct 25, 2012 11:48 am
How about choosing your stem length based upon proper fit?
PostPosted: Thu Oct 25, 2012 11:55 am
Well, if you can choose your frame and know your fit, either TT length or stem length can be the dependent variable.
PostPosted: Thu Oct 25, 2012 12:16 pm
Stem length makes an appreciable difference in handling. It's not just a means to an end in getting the correct reach.
Me, 120 or 130.
http://www.nicksquillari.com.au
PostPosted: Thu Oct 25, 2012 12:19 pm
I designed my first custom frame around a 120 mm stem, and liked it that way so I did the same when I ordered my second one. With that said, I have ridden frames with stem lengths ranging between 90 and 130 mm, and to be honest I found that after a short while my body just adapted to it and I couldn't really tell the difference.
My Bikes
My Photoblog
PostPosted: Thu Oct 25, 2012 12:24 pm
I ride 120mm stems on all my road bikes, but anything between 110-130 is perfectly ok. Going shorter starts to feel too twitchy and if I need a 140, I probably have the wrong frame for my body build
PostPosted: Thu Oct 25, 2012 1:02 pm
120, -10.
But I'm trying a 130, -10 this season.
I hear Iit's going to steer like a boat lol. :wink:
I only train on days that end with "y".
Eli
PostPosted: Thu Oct 25, 2012 2:01 pm
I ride 80mm -17. I'm 5'5" with an extremely short torso so I can't have the luxury of longer stems (100mm+), as there simply aren't frame sizes small enough. That said, I really like the way my bike rides with the 80mm stem, I don't think the handling suffers because of it - like someone says it's what you get used to.
PostPosted: Thu Oct 25, 2012 2:19 pm
I run 100mm stems on most of my bikes. I ran 110 for awhile, but the 100 fits me better.
For me, I need a shorter length stem due to my body proportions. I have very long legs for my height, and as a result, a very short torso. I can't go with a smaller frame/longer stem because the headtube ends up being too shorts and I cannot bend over that much.
PostPosted: Thu Oct 25, 2012 2:35 pm
You do not need to quote the post above
Very similar here. I'm 2m with long legs. I have done everything to get as low as possible on the saddle (mid foot cleat + super thin soles), but still have 86cm saddle height. I ride a 20cm HT with 25mm top cap, 5mm spacer, 100mm 0 deg stem. (59cm TT). My handlebar drop is around 15cm. Unfortunate to be proportioned that way, but so it goes.
If I want to ride 110 and -6 without spacers I need about 21-22cm HT and 57.5cm TT :-)
PostPosted: Thu Oct 25, 2012 2:49 pm
130 -17 slammed on my trek ...on my Awesome Guru photon I was 120 -10 slammed ,that may change when I build it up again.
PostPosted: Thu Oct 25, 2012 5:01 pm
Tinea Pedis wrote:
Stem length makes an appreciable difference in handling. It's not just a means to an end in getting the correct reach. Me, 120 or 130.
+100
My 6696gr Cipollini Bond
My 9733gr Colnago Master X-light
PostPosted: Thu Oct 25, 2012 6:01 pm
Didn't think they made stems in that angle.
I'll show myself out.
PostPosted: Thu Oct 25, 2012 6:44 pm
There is no "correct" or "optimum" length for stems. They must be fit to individual anatomy.
The usual rule is (Stem Length) = .433*(penis length).
So I always use a 140.
PostPosted: Thu Oct 25, 2012 7:15 pm
110 or 120, depending on the fit of the respective frame. Below 110, steering becomes to nervous, above 120 too sluggish.
Get a bicycle. You will certainly not regret it, if you live.
This topic is locked, you cannot edit posts or make further replies. Canyon Stem Length Ridiculousness...
[ Go to page: 14 5 6 7 8 ]
TheDarkInstall
107
5966
Mon Oct 31, 2016 9:43 pm
mdeth1313 View the latest post
There are no new unread posts for this topic. Actual length Zipp Service Course SL stem
Dr.Dos
9
862
Wed Sep 28, 2016 10:07 am
Fiery View the latest post
There are no new unread posts for this topic. Going to start biking again, Tarmac?
WiryMike
28
1608
Fri Feb 17, 2017 6:17 am
TheDarkInstall View the latest post
There are no new unread posts for this topic. Lightest Long Road Stem
KWalker
18
2217
Wed Jun 29, 2016 4:49 am
jimborello View the latest post
There are no new unread posts for this topic. Anyone running the Enve Road Stem/aero bar combo?
sd5500
Tue Nov 01, 2016 6:48 am
spandexboy817 View the latest post
Users browsing this forum: BRM, jimaizumi, Lukester and 7 guests
