Post new topic Reply to topic  [ 7 posts ]
PostPosted: Wed Oct 24, 2012 9:31 pm
I've had a look through the threads on BBRight and can't see if anyone has successfully fitted a Zipp chainset to Cervelo R5. A reply on the Cervelo forum seems to suggest that they will only work with the "direct fit" BB on the R5ca and not the "pressfit" BB on the R5, I've had a look at the tech drawings on the BBRight site and am none the wiser. Anyone had any luck with this?
Thanks for any info.
PostPosted: Wed Oct 24, 2012 10:05 pm
Well i haven't tried it but this guy has got one fitted to a bb90 crank (just) http://www.the-climb.net/2011/08/zipp-v ... part1.html which is 90mm from outer bearing face to outer bearing face. it was designed for 86mm BBs and the BBRight one claims to be 79mm wide.
Therefore my conclusion is you'll need a 5mm spacer. +/- a little bit for tolerances. Chainline might still be an issue.
Waiver:- This is theoretical not practical.
PostPosted: Thu Oct 25, 2012 2:44 am
I think it might depend on the BB. I would think that you could use one with the THM BBright Pressfit BB. It probably will not work with the SRAM BB that is supplied with the frame.
PostPosted: Fri Oct 26, 2012 9:41 pm
Thanks for replies - will give it a go (expect I'll end up sticking old red chainset on).
PostPosted: Fri Oct 26, 2012 10:26 pm
It should work as long as the bearing race on the drive side is long enough. You'll need a spacer on the DS (probably 13mm) and a wave washer/shims on the NDS.
PostPosted: Sun Oct 28, 2012 4:08 pm
If by "bearing race" you mean the axle surface intended to have a bearing, yes, it works. Zipp makes a bb30 conversion that is just two spacers. You essentially just use one of those spacers on the right side, and you're done.
PostPosted: Tue Mar 05, 2013 8:01 pm
Quick update - finally decided to try sedluk's suggestion and try the THM BBright press fit adapter, got it back from the LBS this morning and it seems to have worked perfectly (just used THM washer and Zipp washers and wavy washer). Did a quick 30 miles on it this morning and nothing fell off or exploded. Thanks for advice.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 40 guests
There are no new unread posts for this topic. Attachment(s) Campagnolo Eps externally fitted?
markyboy
20
2075
Sat Jan 12, 2013 12:43 am
shillc View the latest post
There are no new unread posts for this topic. Repairing Vuma Quad
monchito
20
2200
Sat Apr 06, 2013 10:15 am
latman View the latest post
There are no new unread posts for this topic. zipp 303 FCC Front / zipp 404 FCC Rear
jameskack
Mon Sep 10, 2012 8:10 pm
dmoneysworks View the latest post
This topic is locked, you cannot edit posts or make further replies. Cervelo R3 SL vs R5
Naturel
Thu Nov 15, 2012 9:24 pm
Naturel View the latest post
This topic is locked, you cannot edit posts or make further replies. Cervelo S2 & S3
JBV
Fri Feb 01, 2013 10:34 pm
NGMN View the latest post
It is currently Wed Jun 19, 2013 4:36 am
