Post new topic Reply to topic  [ 26 posts ]
Go to page 1, 2  Next
PostPosted: Mon Oct 22, 2012 10:21 pm
Anyone know the weight of the Shimano Hollowtech II FC-4603 or FC-5703 triples?
FC-6603 is supposed to be 892g but does that include bottom bracket or not?
Any other options to consider for a lightish triple crankset?
PostPosted: Mon Oct 22, 2012 10:32 pm
Campag cranksets are normally lighter than shimano one. For example my Veloce chainset +BB is lighter than my 6600 standard + BB. Thge same may be true for Campags new triple chainset.
www.thecycleclinic.co.uk
PostPosted: Mon Oct 22, 2012 10:50 pm
The new campagnolo triples include an athena 11speed triple that has carbon crank arms. Powertorque BB. I'd be surprised if that isn't going to be lighter than all the shimano offerings. They all are meant to have the lowest Q factors available in road triples.
Apparently they use hollow technology in their aluminium crank arms, so they might come in quite light too. I'm thinking of getting the centaur version for myself, I might change some of the ratios I want with TA crank rings.
PostPosted: Mon Oct 22, 2012 11:03 pm
i believe lightning has a triple spider option, they cost a good amount, but they might be the lightest triple.
PostPosted: Tue Oct 23, 2012 1:08 am
Is the llightning triple a mountain bike triple only? As in, 64/104 BCD?
PostPosted: Tue Oct 23, 2012 4:48 am
if you look at their website, they advertised a 130X74 road triple. they offer this along the 110, 130 and 94 bcd.
PostPosted: Tue Oct 23, 2012 6:33 am
Administrator
It seems you are set on a triple crank, but if you are not hindered by physical problems, please also have a look at compact cranks. Paired with the right cassette they offer about the same gearing ratios without the downfalls of a triple.
Sent from my iPad using Tapatalk HD
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Tue Oct 23, 2012 7:48 am
Agree with Frankie. I did a spreadsheet a few years ago when I switched from triple to compact. The range of gears was almost the same with the compact, except that with the triple there were quite a few gears were wasted as they were so close together as to make no difference. I have a compact with 48/33 rings and a 12/27 cassette. Even for my old legs it's enough.
PostPosted: Tue Oct 23, 2012 8:05 am
Unless you ride a tandem. Then I would go for a triple unless you are either both extremely fit or live in Florida.
PostPosted: Tue Oct 23, 2012 3:40 pm
The question was about weights of various triple cranksets. Not about peoples preferences to compacts or triples!
PostPosted: Tue Oct 23, 2012 5:28 pm
Stronglight Fission Triple is about the best road-specific triple on the market - carbon cranks with a titanium axle. And you have the option of steel or ceramic bearings. It is traditional 110/74 BCD so lots of chainrings to choose from.
Yes there are lots of MTB triples, but these of course come with MTB chainlines.
Yes Campag triples are good, but they are not 110/74 BCD. Mr Campagnolo has not kind of worked out that triple uses generally want small chainrings.
PostPosted: Tue Oct 23, 2012 9:39 pm
Some of us want maximum range for the mountains. I used a 53/39/28 for a number of years, riding exclusively in the Colorado mountains. Worked great, with a 12-25 cassette. Today, I'd choose an 11-25, 11 speed.
PostPosted: Tue Oct 23, 2012 11:07 pm
Yes, a 50/34 or 52/34 compact crank can be used with an 11-34 10spd cassette, using an M772 or M972 MTB RD, and actually provide more range than a 53/39/28 triple and 12-25 cassette :-)
PostPosted: Wed Oct 24, 2012 1:16 am
Yes, but with very wide gear spacing. Sometimes its nice on long rides to be able to ride with closer gear spacings, at the cadence you want. Plenty of times I'd pick that option over a slight decrease in weight...much more efficient in the long run.
PostPosted: Thu Oct 25, 2012 3:58 am
As a former triple user and someone who mainly rides in the mountains, let me suggest one other option. Get a compact crankset and replace the 34t ring with a 33t ring (available from TA Specialites). Pair that with an 11-28 rear cassette and you very nearly have the same low gearing and gear range as a triple. I have this setup on my bike with a D/A 7900 drivetrain. It shifts beautifully front and back, and is WAY lighter than any triple setup. It's actually lighter than a normal 7900 drivetrain with an 11-28 cassette, since the 33t ring is lighter than a 34t ring.
Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
Users browsing this forum: 12x23, Bing [Bot], HammerTime2, mellowJohnny, mnmasotto, rbrtwyn, SpeedyChix and 59 guests
There are no new unread posts for this topic. FSA SL-K Light Crankset/Chain Noise?
mvz2
7
468
Wed Sep 26, 2012 2:21 pm
HugoDrax View the latest post
There are no new unread posts for this topic. Actual weight on a Super Record TI crankset
Arc
Wed Feb 06, 2013 10:35 pm
Bridgeman View the latest post
There are no new unread posts for this topic. Light weight alu tubulars?
cerro
23
1559
Thu Sep 13, 2012 1:32 am
bluhorizan View the latest post
There are no new unread posts for this topic. How strong are light weight cranks?
Kayrehn
10
1026
Fri Apr 12, 2013 1:57 pm
Geoff View the latest post
There are no new unread posts for this topic. Light weight brakes that really work!
[ Go to page: 1 ... 4, 5, 6 ]
rockdude
78
5628
Tue Jun 11, 2013 5:18 am
jooo View the latest post
It is currently Wed Jun 19, 2013 3:29 am
