Which bb30 chainset to fit Q rings
dane476
by dane476
Which bb30 chainset will be ok to use rotor q rings on?? Sram red doesn't work does it?? So I've heard anyway
Any help much appreciated
Zigmeister
by Zigmeister
Works with 2011 Red. But, you need to dremel the part of the big ring that will hit the crank arm to clear it. If done right, takes 15-20 minutes being careful with a dremel.
Only the big rings needs trimming.
Not sure is the latest Sram Red cranks have clearance issues or not. Just the previous models do.
