Post new topic Reply to topic  [ 7 posts ]
PostPosted: Mon Oct 22, 2012 8:01 am
Does anyone know for sure if this works?
PostPosted: Mon Oct 22, 2012 4:00 pm
I don't see it happening... though I have both items at home. I'll give it a shot and report back.
PostPosted: Tue Oct 23, 2012 6:33 am
Not gonna happen. The profiles on the Zipp handlebars will not accept the "C" portion of the stem and make it slide onto the clamping area of the bar.
PostPosted: Tue Oct 23, 2012 3:08 pm
Not going to happen as in you tried it, or you don't THINK it will work?
PostPosted: Wed Oct 24, 2012 3:21 am
Tried it in an LBS. They had the big curvy VukaSprint version. The sales rep and I couldn't figure out how to make it work. I don't know about the version of the bars you have though.
The clamp on the stem (the "C" part) is only 24.5 mm wide, just enough to fit the narrow portion on regular round bars.
PostPosted: Wed Oct 24, 2012 4:35 am
http://www.competitivecyclist.com/za/CCY?PAGE=BUY_PRODUCT_STANDARD&PRODUCT.ID=11474&MODE=
there's a video link in the second-to-last paragraph, with a how-to. I don't see why it couldn't be placed just next to the clamping area, at the circle-Z logo.
hope this helps.
PostPosted: Wed Oct 24, 2012 8:09 am
It also says:
"Note that due to this 260-degree clamp, the C-260 Stem works best with traditionally shaped alloy or carbon fiber bars."
But I know there are exceptions.
The video shows a straight bar from the narrow portion up to larger diameter clamp area, facilitating the sliding of the stem. The stem must be fully inserted onto the bar for the clamp to slide over to the bar's clamping area properly. Try doing that on the Zipp bars. Good luck avoiding marring the clear coat.
Users browsing this forum: 604Yarks, Bing [Bot], Google [Bot], nagge and 40 guests
There are no new unread posts for this topic. Zipp Vukasprint install
jezza995
25
2481
Tue Aug 21, 2012 12:23 am
refthimos View the latest post
There are no new unread posts for this topic. How much can I tighten levers on Zipp VukaSprint bars?
Zak
Fri Apr 05, 2013 9:38 pm
Zak View the latest post
There are no new unread posts for this topic. ritchey c260 wet black stem
gg333
Tue Jun 12, 2012 9:35 pm
Zigmeister View the latest post
There are no new unread posts for this topic. Anyone try the Ritchey sl carbon c260 stem
NWSAlpine
Wed Dec 05, 2012 5:33 pm
NWSAlpine View the latest post
There are no new unread posts for this topic. Ritchey C260 and 3T Ergonova bars?
mellowJohnny
12
1042
Thu Dec 13, 2012 7:31 pm
1spd View the latest post
It is currently Tue May 21, 2013 9:11 am
