Post new topic Reply to topic  [ 9 posts ]
PostPosted: Sat Oct 20, 2012 1:18 am
Hi, I currently have a set of alloy wheels with an alchemy ORC rear hub but was wondering how the stiffness and quality of the wheel would change if I have the wheel rebuilt with a powertap G3? The reason I'm asking is because I'm really hard on wheels and have ruined several sets over the years. I weigh 200lbs and ride on many broken Tarmac.
Thanks in advance
PostPosted: Sat Oct 20, 2012 4:55 am
The flange spacing on the G3 is much narrower than the ORC. This will make the wheel much softer from a lateral aspect. At your weight, I'm not sure it would be the best idea.
What kind of rims are you on right now?
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Sat Oct 20, 2012 5:47 am
The differences between these two hubs seems very small to me, maybe even an advantage to the G3 due to the larger flange of the DS. One mm difference in flange spacing does not seem like much.
Weight: +103g | Center to DS: -2.2mm | Center to NDS: +1.2mm | Flange Diameter DS , NDS: +15mm , -1mm
G3:. 325g | 17.4mm | 38.0mm | 57.0mm , 57.0mm
Orc: 222g | 19.6mm | 36.8mm | 42.0mm , 58.0mm
*edited the Center to NDS from 36.0 to 36.8
CAAD9 - 6.32kg
PostPosted: Sat Oct 20, 2012 9:28 am
center to NDS should be 1.0mm according to your measurements.
the center to DS is much more telling. at 2mm difference, that's huge. the NDS spoke tension will be a higher percentage of the DS spoke tension with the Alchemy.
PostPosted: Sat Oct 20, 2012 12:34 pm
Thanks for the advice, then rims I have are hed Ardennes
The reason the the powertap is for an affordable powermeter. Crank based solutions seem to be out of my price range unless anyone has any suggestions.
PostPosted: Sat Oct 20, 2012 12:44 pm
The G3s are much better than the old Powertaps, but worse than the ORC, which has some of if not the best dimensions on the market. Whether a G3/Ardennes build is acceptable to you will probably depend on spoke count.
I know money is an issue but why on earth would you rebuild? ORC is an expensive hub so you will lose money even if you re-sell at a good price. Then you have to pay for new spokes, a G3 and a rebuild. Better to build an entirely new PT wheel with a rim and spoke count to suit your riding. If you find yourself never using the ORC wheel, sell that intact.
PostPosted: Sat Oct 20, 2012 1:33 pm
Were are you?
Here in Europe a Power2Max power meter is about the same as a PT-wheel
http://www.power2max.de" onclick="window.open(this.href);return false;
/HÃ¥kan
Sweden
PostPosted: Sat Oct 20, 2012 4:55 pm
I think you must not have actually looked at one or read the specs. The DS offset is less on the G3, but the NDS is higher. It will be laterally stiff until one or more NDS spokes go slack due to radial loading.
If you aren't interested in using 11spd cassettes you can probably lace the DS 1x heads-in. And/or use heavier spokes on the DS.
formerly rruff...
PostPosted: Sun Oct 21, 2012 12:17 pm
200lb?
Maybe its time to for healthy dietary focus vs hub focus. ;) My mate went from 300lb to 150lb and its like he is on EPO. Seriously.
Ive got a power tap pro + and love it. The power2max crank gets good reviews on line and is cheap. You can also fit the bb30 axle with a special bottom bracket to fit most BSA frames. Look it up.
My YT channel
http://www.youtube.com/user/durianriders?feature=mhee" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Follow me on Strava
http://app.strava.com/athletes/254600
Users browsing this forum: Google [Bot], jerbax18, madsry, Majestic-12 [Bot], SpeedyChix and 45 guests
There are no new unread posts for this topic. New hubs from Alchemy
madcow
23
4403
Fri Jan 18, 2013 6:26 am
Bingomck View the latest post
There are no new unread posts for this topic. powertap in a sram s80 wheel
109er
Tue Jul 03, 2012 2:00 pm
audiojan View the latest post
There are no new unread posts for this topic. Powertap torque change
ultreia
12
868
Sat Apr 06, 2013 12:08 pm
LittleBill View the latest post
There are no new unread posts for this topic. Powertap SL 2.4 signal find
ultreia
Tue Dec 18, 2012 1:53 am
fio View the latest post
There are no new unread posts for this topic. 12mm Powertap axle
eric
Fri Mar 22, 2013 8:26 pm
eric View the latest post
It is currently Wed Jun 19, 2013 11:46 pm
