Post new topic Reply to topic  [ 9 posts ]
PostPosted: Fri Oct 19, 2012 2:50 pm
I've read now in a few places that sram red bb30 chainset will not accept rotor q rings? Is this correct?, is there any way around this? Other than chopping the rings up? What would be the cheapest way of fixing this? I have a rotor 3d chainset also, so I may have to buy the rotor adapter ?
PostPosted: Fri Oct 19, 2012 3:20 pm
This is incorrect.
PostPosted: Fri Oct 19, 2012 4:01 pm
New Red has the hidden 5th chainring bolt, so that could be a game changer. With the previous generation Red and Force Q-Rings did not fit the compact cranks without either chopping them up or using the OCP3 outer ring. As far as I am aware Q-rings always fit standard BB30 Sram cranks.
PostPosted: Fri Oct 19, 2012 5:22 pm
Yes it will. But as you said, you need to "chop up" the rings. You need to just dremel a part of the ring so it fits over the crank and doesn't hit. Takes about 10-15 minutes with a dremel being careful to ensure you still have all the settings available and don't do the wrong part.
Only the large rings needs this done, inside isn't a problem.
PostPosted: Fri Oct 19, 2012 5:37 pm
Did you two not notice that the picture I posted WAS the new cranks?
I ran them for ~500 miles without the faintest hint of an issue. And shifting was awesome.
PostPosted: Fri Oct 19, 2012 5:41 pm
Pictures are worth 1000 words. thanks for posting the pictures of the Red set with the Q
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 Matt black
2012 Cannondale EVO "Storm Trooper" white and black
PostPosted: Fri Oct 19, 2012 7:49 pm
I can add that indeed the old Red BB30 cranks had this issue, but that there's a "OCP3" ring pre-set in position 3, you can use without problems. And, yes. The new Red is compatible with the normal Q-rings.
PostPosted: Fri Oct 19, 2012 10:01 pm
The OP didn't specify new or old Red. Your photo makes it rather obvious that they work with new Red. Are those standard or compact cranks?
PostPosted: Fri Oct 19, 2012 10:41 pm
Last years sram red standard
Users browsing this forum: BeeSeeBee, Google [Bot], justkeepedaling and 39 guests
There are no new unread posts for this topic. Sram Red Quarq and 3rd party Rings (Osym, Q-rings)
tinozee
Thu Apr 04, 2013 4:06 am
NiFTY View the latest post
There are no new unread posts for this topic. Which bb30 chainset to fit Q rings
dane476
Mon Oct 22, 2012 10:01 pm
Zigmeister View the latest post
There are no new unread posts for this topic. BB30 SISL mk5 rings with dura ace 9000
mattlawro
Mon Jan 21, 2013 1:25 am
AptosBigRing View the latest post
There are no new unread posts for this topic. SRAM 2013 Rings on non SRAM crank?
itsacarr
Tue Jul 03, 2012 3:48 am
boots2000 View the latest post
There are no new unread posts for this topic. Sram Force with praxis rings
Stockie
Tue Jul 10, 2012 1:01 am
Ozrider View the latest post
It is currently Sat May 25, 2013 7:47 am
SRAM Red crankset
