Post new topic Reply to topic  [ 6 posts ]
PostPosted: Thu Oct 18, 2012 10:42 pm
Has anyone heard of this? I purchased my 3rd SRM and I currently use all of them on a garmin 800. The newest SRM I purchased seems to record accurate immediate and avg power data, but gives me crazy data like a max power of 2508 for my last ride when I know that I didnt go over 900 watts. I also saw that it recorded the avg cadence as 82 rpm but max cadence as 7rpm. What gives? I tried calling SRM but was on hold for 20 mins before I hung up.
PostPosted: Fri Oct 19, 2012 11:24 am
sounds like water damage, mine did the same. There was a crack in the body. Hope you get warranty or have deep pocket as it will not likely require new internals and expensive is an under statement.
PostPosted: Sat Oct 20, 2012 7:23 am
What happens when you try a different head unit?
PostPosted: Sat Oct 20, 2012 12:29 pm
I have not tried a different head unit. Perhaps that Will be next. I could swear I don't have this problem with my other power meters using the same head unit. I am going on a ride in a bit. Will know soon.
PostPosted: Sat Oct 20, 2012 4:49 pm
My other question would be are these crazy figures showing on the head unit, or in Training Peaks/WKO/whatever analytical program you use?
PostPosted: Sat Oct 20, 2012 7:47 pm
No problem today on other bike. Next step is to see if the error is only in garmin connect
Users browsing this forum: Bing [Bot], FastTarik, oreoboreo and 32 guests
There are no new unread posts for this topic. Am i crazy??? DA 7900 ChainRing Bolts
Ladeira
Wed Oct 31, 2012 9:26 pm
bikedoc View the latest post
There are no new unread posts for this topic. where to buy Stages Power Meter
Mikmik
Thu May 02, 2013 8:55 pm
djconnel View the latest post
There are no new unread posts for this topic. Power cordz - would this be an upgrade?
G6612
10
921
Mon Aug 27, 2012 10:03 pm
ms6073 View the latest post
There are no new unread posts for this topic. Has anyone here tried to modify an EPS power unit?
Artisan
12
1228
Wed Oct 10, 2012 4:31 pm
Omiar View the latest post
There are no new unread posts for this topic. Rotor Power details
CharlesM
15
1229
Thu Sep 06, 2012 9:51 pm
CharlesM View the latest post
It is currently Sat May 25, 2013 1:18 am
