Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Light seatposts?
PostPosted: Tue Oct 16, 2012 1:09 am
I currently ride an Argon 18 Gallium Pro, and it came with a seatpost, but the thing is a tank (~240g). I think I can drop at least 90g with a new seatpost and still not break the bank. Any suggestions? Looking for something light, but also stiff. I weigh 155lbs. I need 25mm setback as well
Possible candidates:
3T dorico
Thompson masterpiece
Please use search
viewtopic.php?f=1&t=65207
viewtopic.php?f=3&t=65875
viewtopic.php?f=3&t=96093
 Post subject: Re: Light seatposts?
PostPosted: Tue Oct 16, 2012 1:15 am
3T Dorico LTD (have two of them myself). Depending on the length you need around 175 - 180 grams. Has good support under the rails too - which many ubber light posts (setback or not) fail to address....putting stress risers just where you should avoid them.
The Thomson..........I hear time and time again how good it is (so listen to that) but for myself I just can't get beyond the unorthodox looks of that thing (setback version).
PostPosted: Tue Oct 16, 2012 2:41 am
Administrator
I've been on a Woodman Carbo DX for over 2 years. 25mm of setback and 157 grams in a 31,6mm X 350mm. The only place ai could find it is at XXX Cycles in France, Best of all no creaking or saddle creep.
PostPosted: Tue Oct 16, 2012 4:01 am
KCNC Ti Pro Lite. Not sure what diameter you need but the 27.2 is 143g. Pretty good weight for the money and I have had no problems with mine in the last 2 years.
PostPosted: Tue Oct 16, 2012 4:02 am
Thompson Masterpiece
PostPosted: Tue Oct 16, 2012 4:09 am
I like the idea of the Thomson Masterpiece. The texture of the post reduces slippage, and they seem to be consistently durable.
http://www.zencyclery.com
http://www.wheelbuilder.org
Users browsing this forum: Bing [Bot] and 34 guests
There are no new unread posts for this topic. 30.2 Seatposts?
morrisond
Fri Apr 26, 2013 9:22 am
elviento View the latest post
There are no new unread posts for this topic. Offset, 2-bolt seatposts
MileHighMark
10
418
Tue Mar 19, 2013 2:42 am
MileHighMark View the latest post
There are no new unread posts for this topic. Light weight daily semi-aero wheels for a light weight rider
dvincere
15
2593
Sun Jun 03, 2012 9:44 pm
numbers505 View the latest post
There are no new unread posts for this topic. Attachment(s) 31,6mm setback and light... possible?
audiojan
14
676
Sat Nov 17, 2012 11:17 pm
DJT21 View the latest post
There are no new unread posts for this topic. light expander and top cap?
ninjanoir78
13
782
Thu Jun 07, 2012 9:40 am
Juanmoretime View the latest post
cron
It is currently Sun May 19, 2013 1:32 am
