Post new topic Reply to topic  [ 13 posts ]
PostPosted: Mon Oct 15, 2012 3:08 pm
Hi guys,
need some input.
I recently noticed that my carbon steerer looks like its pinched (torqued it 4nm)
I have yet to bring it to my LBS but it definately doesnt look like its cracked.
Do u think its safe to ride or should i get a new fork?
PostPosted: Mon Oct 15, 2012 4:08 pm
Hard to say, but that looks cracked up at the top. If there is a sharp ridge that you can feel when you run your finger across it then you better take it in to have it looked at.
PostPosted: Mon Oct 15, 2012 4:20 pm
cut it off and slam your stem for the win :D
PostPosted: Mon Oct 15, 2012 4:31 pm
Cracks usually run in a jagged pattern where scratches are usually less errant....looks like u have a crack. EM3
________________
My 2011 Cervelo R5
PostPosted: Mon Oct 15, 2012 5:22 pm
This is the best solution and more aero :thumbup:
PostPosted: Mon Oct 15, 2012 8:40 pm
Carbon Cowboy
+1
Berk PROTO-TYPE Composites - Handmade In Slovenia
Berk Composites
PostPosted: Mon Oct 15, 2012 9:49 pm
Where there is a crack there is often a delamination, don't use it until it has been professionally inspected.
Specialist Sports Technology
http://www.luescherteknik.com.au
Zerocompromise High Performance Footwear
http://www.zerocompromise.com.au
Carbon Bike Repairs
http://www.carbonbikerepair.com.au
PostPosted: Tue Oct 16, 2012 5:21 am
If you don't see any irregularity from the inside, then some epoxy and a 2"-long aluminum tube (go to home depot and get a pipe in the 22-24mm range) will easily fix it. I did it on a Nag Dream HP and worked just fine. Only complication was expander plug was replaced by a star fangled nut.
If u c a crack from the inside, then it's gone.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Tue Oct 16, 2012 10:16 am
Ok hold on, what do i do with the 2" aluminium tube?
PostPosted: Tue Oct 16, 2012 5:02 pm
you epoxy the crap out of it to the inside of the steerer after you have removed the compression plug. The forks that cervelo has (3T) do this also to reinforce the steerer.
PostPosted: Wed Oct 17, 2012 10:16 am
ok just got back from LBS and my steerer are fine, just a pinch no cracks whatsoever.. phewwww
PostPosted: Wed Oct 17, 2012 10:19 am
Make a little mark so you can check if it gets worse . Better to be safe .
PostPosted: Wed Oct 17, 2012 1:49 pm
pinch is a precursor to a crack. use carbon paste and slightly less torque. like others have said, i would try to epoxy it to smooth out the sharp pinch...sand it smooth. check your stem.
- Storck Fenomalist + Campy SR11 + Enve 45
- Parlee Z5 SL + DA7900 + Enve 3.4
Users browsing this forum: deek, Google Adsense [Bot], Miller and 75 guests
There are no new unread posts for this topic. Gap inside stem to fork, steerer tube
tri
Wed Sep 26, 2012 10:05 am
ttts2 View the latest post
There are no new unread posts for this topic. Fork Question: 1.125 Steerer in Tapered Head Tube ?
ldamelio
Wed Dec 19, 2012 1:54 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Need help with cracked carbon frame
WasFab
Mon Jul 02, 2012 10:49 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Carbon tubular rim replacement for cracked Shimano C24
owen
Mon Jun 18, 2012 10:55 am
Antoine View the latest post
There are no new unread posts for this topic. THM Scapula F Aero Carbon Fork... anyone actually used one?
Cheers!
13
797
Mon Jan 14, 2013 4:55 pm
elfuinha View the latest post
It is currently Tue May 21, 2013 10:14 pm
