It is currently Thu Jan 18, 2018 5:13 pm
Post new topic  Reply to topic  [ 45 posts ]  Go to page Previous 1 2 3
 Post subject: Re: Dura Ace 9000 hubs
PostPosted: Sun Aug 25, 2013 7:58 am
CX-ray's do fit but it is tight and Paolo probably does not like that. 24H rears should be done 2x. 3x will just lead to problems down the line so it is not even worth thinking about it. Getting normal spokes in is tight on the rear but still nice hubs. I did a build with light rims and I did not feel the overall lateral stiffnes was poor. The NDS flange has moved out a fair bit from the 7900 design and the flange seperation is more 56 or is it 57mm (I can't remember) anyway it is good enough for shallower rims than 38mm in my opinion anyway.
www.thecycleclinic.co.uk
PostPosted: Tue Aug 27, 2013 11:01 am
I'm thinking of using these hubs with a Kinlin XR-200 rim in 24f, 28r, Sapim CX-Ray all round, brass nipples. Can the front hub take a radial spoke lacing? Thinking 2x both sides for rear. Any suggestions?
PostPosted: Fri Feb 07, 2014 1:32 pm
Apologies for the grave dig (and noob question) but found this thread when trying to calculate centre to flange distances. As quoted on the first page of the thread, Shimano quote "flange distance" and "dish" dimensions. How do I use these to arrive at centre to DS and centre to NDS flange distance measurements?
PostPosted: Sun Feb 09, 2014 7:39 pm
Anyone?
PostPosted: Sun Feb 09, 2014 9:41 pm
The numbers you're looking for are posted on the first page. 16.5mm DS and 36.5mm NDS.
PostPosted: Sun Feb 09, 2014 10:31 pm
Those are quoted for a 24h hub; the dimensions for a 28h are slightly different - at least the flange distance and dish measurements are different (56.9 & 9.75 vs 56.5 & 9.95). I'm afraid I don't know how to translate these into LH and RH flange to centre measurements as I am uncertain what 'real world' dimensions they refer to.
PostPosted: Sun Feb 09, 2014 11:42 pm
Thats a new one to me. Flange spacing doesn't vary between hole counts. What would be the point?
PostPosted: Sun Feb 09, 2014 11:44 pm
Ask Shimano, it's their specs! I might speculate that the flange thickness might vary but frankly I don't know what I'm talking about here - in case you hadn't guessed :D
What I'm really asking is how do you calculate the distances from the spec numbers given - what is the equation/what do the numbers 'flange distance' and 'dish' mean when used by Shimano?
PostPosted: Mon Feb 10, 2014 6:15 am
Use the numbers provided a few post up and forget about and 'differences' as if they exist, they are minute.
PostPosted: Mon Feb 10, 2014 9:00 am
(56.9 / 2) + 9.75 = 38.2 (NDS offset)
(56.9 / 2) - 9.75 = 18.7 (DS offset)
(56.5 / 2) + 9.95 = 38.2(NDS offset)
(56.5 / 2) -9.95 = 18.3 (DS offset)
Those are to the outside of the flanges though so you need to subtract to get the center. I subtract 1.7 mm. 36.5/16.5(16.9) for Dura Ace hubs
PostPosted: Thu May 29, 2014 4:02 pm
Was wondering, with the new pre-load adjustment on the 9000 hubs, does the clamping force of the quick release affect the pre-load adjustment?
PostPosted: Sun Aug 16, 2015 9:09 pm
Yes it does. With all hubs in fact.
Don't overtight skewers as that just exacerbates bearing wear.
In fact what I do with Shimano hubs is to leave a tiny amount adjustment or play in the bearing preload so that when the wheel is fastened in the frame, the skewer will take up the slack in the hub.
Shimano produced the most stable hub in the FH-7800 (10 Speed) with a 60.2mm flange separation and we haven't seen anything like it from Shimano since.
7x Forum Racing Ban Champion.
PostPosted: Sun Aug 16, 2015 10:25 pm
Not even close.
50mm inside to inside, 56mm outside to outside.
PostPosted: Mon Aug 17, 2015 6:11 am
I just purchased a set of the C50 wheelset. While doing some buying research the marketing materials say the new hub on the C50 puts the skewer clamping force directly on the axle only. So the bearing preload is independent on the skewer clamping force.
PostPosted: Mon Aug 17, 2015 10:28 am
I have that too when setting the up. Leave play and once clamped there is still play. Take wheel out and re adjust.
There are no new unread posts for this topic. Dura ace 9000 rear derailleur?
sinjun
Mon Apr 10, 2017 6:02 am
richscott View the latest post
There are no new unread posts for this topic. Dura ace 9000 V 9100 brakes
scottmmw
Mon Oct 23, 2017 7:51 pm
evan326 View the latest post
There are no new unread posts for this topic. 28C tyres on Dura Ace 9000 Brake Calipers
chutneyyy
Thu Jun 29, 2017 7:58 am
Delorre View the latest post
There are no new unread posts for this topic. Dura Ace 9100/9150 noisier than 9000!
James0133
11
3488
Sun Aug 20, 2017 5:44 am
James0133 View the latest post
There are no new unread posts for this topic. Tips for dura ace 9000 hood replacement.
SpecializedColnago
Wed Jan 25, 2017 7:21 pm
rossjm11 View the latest post
Users browsing this forum: Bing [Bot], darnellrm, erik$, Google Adsense [Bot], MoreRideTime and 56 guests
cron
