It is currently Fri Jun 23, 2017 1:20 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Oct 11, 2012 12:39 am
I have been trying out some bolts that I bought from Mattias Hellöre. Mattias Hellöre is a regular here and has made some interesting and special parts for people.
The original Ax Lightness bolts that are included with each brakeset do a good job at securing a steel brake cable but they need some special work to hold a Powercorz cable. You have to drill out the hole that the cable fits through and do a little dremel work so that the cylindrical part has a better bite. Then you tie a knot at the bottom of the cylindrical part so that the Powercordz does not get sucked into the little cylindrical part. It is not a very elegant solution so people look for aftermarket bolts. BTP made a few of them and still has them listed on their web site, in fact they are still listed as “New”. Good luck buying them, I am not sure what kind of things they are making, but $20 bolts is not one of them.
Mattias Hellöre came up with his solution. It does not have the grub screw like the BTP part but it has a raised edge so that the bolt does not slip out of the brake. I have never had a bolt slip out while riding but very rarely it can happen when traveling. I think this is a nice feature.
I spent some time thinking about the best way to tie the knot that would secure the cable and what I came up with is called an Arbor Knot. What I did first was smooth out the openings on the bolt. Mattias has already machined them a little but I wanted to make sure that the cable would not be cut by the corner where the Powercordz cable comes out of the bolt at a sharp angle.
I was out in California riding the Levi Gran Fondo and it really put everyone’s brakes to the test. The descent down Kings Ridge is a real pad burner and at times hits 20% for a while with something like 1,600 ft of descent.
The Arbor Knot tightened up just like it is supposed to and I have included a picture.
PostPosted: Thu Oct 11, 2012 7:04 am
Thanks for the writeup!
But credits should ge given to Gumgardner and Andy2, they gave me neccessary measurements and I drawn up the part and got it machined.
Have done carbon ones for Gumgardner, very light but could be lighter as the grub screws and aluminum tube inside wasn´t needed.
Experimental Prototype
PostPosted: Thu Oct 11, 2012 2:50 pm
Bolts? Where are they? I see only a cable tied in a knot. Better not have that come loose in a fast decent, then again, ships have managed sailing the seven seas over the past thousands of years with ropes that have knots, so it's probably safe enough on a brake. Well done, Swedes (and non-Swede)! ;)
Although I'd be concerned about that particular brand of brake. :roll:
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
PostPosted: Thu Oct 11, 2012 8:24 pm
Question, gents:
If the Arbor Knot is so strong, and it looks like it is, why couldn't you just tie the knot on the underside of the barrel-bolt and just have the Powercord(z) pass through once?
I'm asking because those of us with the Planet-X / Featherlite type brakes have a similar mechanism for cable pull on the brake, but it is not as wide of an opening on the AX Lightness, so the cord can only pass through once. Why not just tie the knot at the bottom beneath the bolt and call it a day? Will the cord slip loose?
PostPosted: Fri Oct 12, 2012 6:24 pm
When the cord is tightened around itself, it is strong! Over 80K cycles on this knot, still counting....
PostPosted: Fri Oct 12, 2012 6:43 pm
I see that the knots both from Powercordz and used in this thread for Mattias Hellöre's solution wrap around the bolt, then back through.
This isn't really possible with the Featherlite/Planet-X brakes: the bolt is very small and the opening on the cam mechanism looks to only be wide enough for one line of cable.
Can either of you or anyone here come up with a decent solution?
Pics:
PostPosted: Sat Oct 13, 2012 4:49 pm
Here's the BTP one that I had on my bike for a comparison:
Have you ever wondered if there was more to life, other than being really, really, ridiculously good looking?
PostPosted: Sat Oct 13, 2012 7:52 pm
I have Planet x brakes on my trek . I use the KCNC teflon cables they weigh 14grms so not to bad.
To use powercordz prendrefeu and myself would need someone out there to make a new part of the brake so we could use powercordz .
Mattias Hellöre could you help? . A small carbon section would be awesome and drop the weight some more .
PostPosted: Sun Oct 14, 2012 5:51 am
A carbon rod with a drilled hole in center?
But make a thread in a carbon rod is not a good idea, the bolt will strip immediately, maybe a another way?
Let me know how you want it.
Added a pic on Gumgardners brake bolts I did.
Alu center pipe with grub screws not needed so deduct 0.5-1g from the total.
PostPosted: Sun Oct 14, 2012 10:20 am
What about if the cordz goes round the bolt and up .Then wrapped around some kind of pinch bolt attached to the cable. ?
PostPosted: Tue Oct 16, 2012 12:45 pm
I thought about the same, let me know when you want one in mail or PM.
PostPosted: Tue Oct 16, 2012 8:51 pm
Thanks Mattias . KCNC have just released some new cables 7grm and 11grm . I think this now is the best option as a extra bolt with the Cordz will end up at about the same weight
http://clee-cycles.co.uk/esite/P18503/product" onclick="window.open(this.href);return false;
:beerchug:
There are no new unread posts for this topic. ee brakes + powercordz
sungod
9
859
Sun Mar 12, 2017 2:03 pm
mdeth1313 View the latest post
There are no new unread posts for this topic. Engage Gravial brakes with Powercordz Swift
Kayrehn
Thu Aug 11, 2016 12:49 pm
Kayrehn View the latest post
There are no new unread posts for this topic. Best Brake Pads That Won't Scuff/Mark Alloy Brake Tracks?
McGilli
Thu Oct 06, 2016 5:02 pm
tomycs View the latest post
There are no new unread posts for this topic. Attachment(s) Ax lightness vial evo experience
Naturel
11
2027
Fri Jan 06, 2017 2:01 pm
sakattack View the latest post
There are no new unread posts for this topic. Attachment(s) Berk Lupine, Ax Lightness Leaf II. .
MyM3Coupe
34
3419
Tue Jun 20, 2017 11:13 pm
Vuong05 View the latest post
Users browsing this forum: Atmos312, Bluecoupe, dwiller, fabriciom, irf3, kelih, norcimmus, pyrahna, silvalis, vladi78, Yahoo [Bot], YungLegs and 28 guests
