Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 193 posts ]
Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
PostPosted: Tue Dec 04, 2012 2:33 pm
On the bonding issue I have campag carbon cranks and the pedal inserts are bonded in. These don't fail all the time. Also alloy crowns and steerers are common on carbon forks and they survive quite well. So there is a work around and the Ted may have taken this into consideration in the design. Unless someone is going to section up an $1100 crankset we are not going to know for certain. Assumptions are a dangerous thing.
Also if a problem does develop down the line Ciamillo will not be the first company to have to redesign. It happens to the big companies to after all there is only so much product testing that can be done.
454g that is light.
www.thecycleclinic.co.uk
PostPosted: Tue Dec 04, 2012 2:37 pm
Hi 1spd,
For info these will work with standard BBs. Just like the Zipp Vumas did. In fact i am planning to use my Zipp cups for these cranks.
The BB30 element is just that the cranks have 30mm diameter axles. So you may need a shorter cable retainer bolt (if your frame has one) to clear the axle inside the BB shell.
Cheers,
Lig.
3kbikes.co.uk
For best - Parlee Z3
For training - Colnago EPS AKBL
For the pose - 1980'ish' Basso Steely
PostPosted: Tue Dec 04, 2012 4:25 pm
Hello,
Let me introduce you to the forum.
I'm responsible for http://velo-perso.com which is the main European distributor of Ciamillo products.
This year I've been spending 3 weeks at the Ciamillo shop in order to work with Ted on the new products.
My work has been to bring the knowledge to Ted about the crank market, which is different from the brake market.
As a good level rider, I can anticipate the stiffness levels that we need for a such project.
Ted has incredible skills on machining and designing products with 10-20 years in advance on the market. He has with him the chance to adapt quickly all his products to the market needs and that's why we are hearing carefully all your comments.
This crank should be available first in 24mm/110mm because it's compatible to all framesets of the market.
As a Rotor retailer I can supply the bearings of all frames of the market (except Trek) as soon as Ted is making a BB30 version.
Please note that the spiders will be available in both 110/130, but it's not as of today the biggest difficulty. In fact, Ted has such big machining skills that machining a spider on 2 sides is something very easy for him. It has nothing to do with the work that has been necessary to machine the bottom of the arms.
I'll come back here to send you my opinion on the first rides with the Ciamillo prototype crank. That should happen shortly now !
Thanks
Olivier
PostPosted: Tue Dec 04, 2012 11:54 pm
Administrator
At 1 Spd, the crank with correct spacer will work with a VumaQuad bottom bracket. That is how I'm going to run it. :wink:
PostPosted: Wed Dec 05, 2012 5:57 am
www.carbonLORD.com : Zero Gravity Authorized Dealer
PostPosted: Wed Dec 05, 2012 10:09 am
Hey 'carbonLORD' you cant just tease us with some fancy CAD drawing and no info??? :roll:
Lig.
3kbikes.co.uk
PostPosted: Wed Dec 05, 2012 2:25 pm
The caption for that picture on his Facebook page is:
"Zero Gravity Carbon Crank V2 with Aero Cover option. Taking pre-orders now!"
That's all I can find so far.
PostPosted: Wed Dec 05, 2012 2:42 pm
Sorry, it was getting late.
I'm sure Ted has been too busy getting the crank in order to respond with more information. From what I know, (which is not much more then anyone else) the green areas in the image highlight where the materials join, but I'll let him explain the details.
I posted the image to illustrate what the Aero Cover will look like once adapted.
More information (and images) to come, stay tuned...
PostPosted: Wed Dec 05, 2012 3:11 pm
:popcorn:
PostPosted: Wed Dec 05, 2012 3:21 pm
coming soon (not really) after we have taken 200 more deposits to use for R&D :twisted:
PostPosted: Wed Dec 05, 2012 4:59 pm
That's pretty much the definition of a pre-order.....ramp up cash flow for final development and production. Standard business practice.
PostPosted: Wed Dec 05, 2012 5:35 pm
Acording, with the discretion above, it will be 24mm, spindle, not shure, how is it compatible. Being the vuma quad, 30mm.
Other issue is every body is going 30mm, in Search for stiffness, why 24mm first design, compatibility??
See how Thm solve this matter.
About the price, it's in price range, of thm clavícula, M3, and tbe hollowgram, Sims excessive- 1100usd, will translate in 1100 euros in Europe.
Really incredible will see this design, being the pedal insert ok, and the rest tubular to spindle and spider of all carbon.
Best regards
PostPosted: Wed Dec 05, 2012 7:30 pm
Final development, you mean complete redesign
Production, we'll see
normally when you put a deposit on something you know what it is
using customers money to develop your product is bad practice, what happens when/if it fails
PostPosted: Wed Dec 05, 2012 7:37 pm
uraqt wrote:
I have said it before and will say it again!!!
Go TED GO!!!!! : )
C
PostPosted: Wed Dec 05, 2012 7:40 pm
Is the aero cover structure or cosmetic
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 193 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
Users browsing this forum: Bing [Bot], Helmutti, sancle1 and 45 guests
This topic is locked, you cannot edit posts or make further replies. Attachment(s) Ciamillo Crank V2
[ Go to page: 1 ... 6, 7, 8 ]
elfuinha
111
6771
Thu Dec 27, 2012 3:07 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Attachment(s) Ciamillo Gravitas crank, review and poll
[ Go to page: 1 ... 5, 6, 7 ]
lewolive
93
8662
Fri May 24, 2013 12:40 am
runner999 View the latest post
There are no new unread posts for this topic. 2013 Felt Road Launch
Imaking20
Thu Jul 19, 2012 7:35 pm
Imaking20 View the latest post
There are no new unread posts for this topic. Are Fizik about to offer saddles with a cut out?
Lemond75
19
1418
Wed Feb 27, 2013 3:57 am
tommasini View the latest post
There are no new unread posts for this topic. Information about Moser bikes
Omiar
Wed Sep 26, 2012 8:33 pm
Omiar View the latest post
It is currently Fri May 24, 2013 6:37 am
