Post new topic Reply to topic  [ 9 posts ]
PostPosted: Tue Oct 09, 2012 7:26 pm
Thinking of trying the Clavicula M3 crankset in 110bcd.
What would be a good chainrings in 52/36 110bcd to be used with Campy 11 speed ?
Same question for bolts ?
Thanks!
PostPosted: Tue Oct 09, 2012 10:48 pm
praxis 52/36s i have a set and they shift every single bit as good as the campag rings..
bolts thats a matter of personal taste.. i have extralites which have a bit of texture on the backside sections so you only need one tool to do them up.. and they are torx head which are less prone to rounding. i also like the parts of passion bolts, they look real nice
http://fairwheelbikes.com/c/forums/topi ... parlee-z5/
PostPosted: Wed Oct 10, 2012 5:48 am
Thanks. I had seen yours and it is good to know that they shift as well as the campy rings. I was hoping some that look more traditional than the Praxis outer ring.
PostPosted: Wed Oct 10, 2012 1:01 pm
Stronglight CT2's?
http://www.flickr.com/photos/67717721@N03/7923142628/" onclick="window.open(this.href);return false;
PostPosted: Wed Oct 10, 2012 2:37 pm
Not sure why I did not think of the CT2, I guess they are 11s compatible ?
On the TA range the 11s compatible rings seems to be the ones that only fit campy cranks.
PostPosted: Thu Oct 11, 2012 10:50 am
Yeah, they're fine with 11 speed
The chainrings are actually engraved 10/11 speed now -
my CT2's are a couple of years old now and are just marked 10 speed, but they've always been fine.
PostPosted: Fri Oct 12, 2012 1:46 pm
Praxis Clover and KCNC bolts
PostPosted: Sat Oct 13, 2012 4:16 pm
Thanks for the pic. You can save some weight but cutting your FD cable :D
PostPosted: Sat Oct 13, 2012 7:03 pm
TA rings are always work well.
www.thecycleclinic.co.uk
Users browsing this forum: HammerTime2, maissi and 66 guests
There are no new unread posts for this topic. Damaged Chainring Bolt Removal
Valbrona
Thu Jul 26, 2012 1:24 am
stella-azzurra View the latest post
There are no new unread posts for this topic. Attachment(s) FSA K Force 2-bolt Seatpost w/setback--lighter options?
sandico
Fri Sep 21, 2012 8:53 pm
sandico View the latest post
There are no new unread posts for this topic. 7900 Front caliper pivot bolt damaged. Replacement options?
racermech
Tue Sep 18, 2012 1:18 pm
oysters View the latest post
There are no new unread posts for this topic. THM Clavicula M3 - who's got them? please report
pawnii
13
1147
Thu May 16, 2013 10:12 pm
civdic View the latest post
There are no new unread posts for this topic. THM Clavicula Install
RudyMontana
Sat Dec 15, 2012 7:29 am
Geoff View the latest post
It is currently Wed Jun 19, 2013 8:20 pm
