It is currently Fri Dec 15, 2017 9:37 am
Post new topic  Reply to topic  [ 110 posts ]  Go to page Previous 13 4 5 6 7 8 Next
PostPosted: Fri May 24, 2013 9:57 am
Happened to me today. Brand new latest model 340 rim.
2 wraps of 21mm tape.
120psi.
One tyre brand new Vittoria Corsa 23.
Other tyre worn GP4000 25mm.
What a crappy rim!
As if you would let a rim this dangerous get into the hands of cyclists around the world. This is a class action law suit waiting to happen! lol!
My YT channel
http://www.youtube.com/user/durianriders?feature=mhee" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Follow me on Strava
http://app.strava.com/athletes/254600
PostPosted: Fri May 24, 2013 7:54 pm
I sooooo wanted to build some of these up but the thought of it blowing a tyre off a rim at any speed and getting myself killed is enough to put me off...I am going to go hplus archetype for a bit of wide rim comfort.
PostPosted: Sat May 25, 2013 1:47 pm
I have a build in the works - DA7900 32-eyelets with Sapim Laser to Alpha gen2 rims - and I will keep the community updated. I have several mates running alphas for years with zero issues UK including in CX, and I am not overly concerned. Beaides, it cannot be worse than being ran through by a vehicle on multiple ocassions ... at least, I hope not.
I had a Continue 4000s blow off my front OP during a crit last year ... close to 100-degrees and the tube blew. My tire got stuck in brake, and I went from 20 to 0 instantly.
PostPosted: Sun May 26, 2013 4:56 pm
Ive had two sets of older 340's now, never had a tire blow off. I've always used Hutchinson Fusion 3's, and am currently using Hutchinson Galactik's (Always ran them tubeless). I used to wrap with one layer of tape but I found that when the wheels heated up the base tape would soften up and puncture just from the air pressure in the tire. Started using two layers of 21mm Stan's tape and never had a problem. The tires are MUCH easier to bead up, the bead seats tighter once its aired up, and no more leaking/puncture issues with two layers. I know the Fusion 3's arent the lightest, but I highly recomend them. They last forever, have good grip, are puncture resistant, and the carbon beads are solid and fit in the hook on the 340 wheels perfect.
PostPosted: Sun May 26, 2013 10:51 pm
That's weird, I have never had any issue with three pairs of those rims and thousands of miles. Then again I don't get why you would use a tube on a tubeless rim. I always used the hutchinson tires - atom, fusion and intensive and the bead locks in place.
I scanned the thread and didn't see anyone having an issue using tubeless ready tires. Am I wrong? Maybe don't use clinchers and tubes on the 340.
PostPosted: Sat Jun 08, 2013 2:22 am
Got a brand new latest gen Stan's Alpha 400 and using a maxxis tyre it blew that off the rim going around a corner.
Ive riden over 250 000km and never had a tyre blow off a rim. Since using Stan's for the last few weeks, Ive had 3 tyres BLOW OFF THE RIM.
Its time for Stan's to do a recall before someone gets killed. They do not respond to emails nor answer this question on their help forum. Ive also read of people blowing Hutchy Fusion 3's running tubeless, off the rim with sealant covering the rider behind.
My YT channel
Follow me on Strava
PostPosted: Sat Jun 08, 2013 4:24 pm
Got them with Ultremo zlx 25mm with tubes in and one wrap of yellow tape.... should I worry?
PostPosted: Sat Jun 08, 2013 5:24 pm
Durianrider can you link to the stuff you read about people blowing hutchinson fusion 3 off the rim of stan's rims? Not saying I don't believe it, just scary.
Tx
PostPosted: Tue Jun 11, 2013 8:42 pm
Happened the same to me! I was going on a descent and the front tire exploded..
Then I realized that in the holes of the rim, the stans tape with time starts to go down.. and I think that's the reason for the blows.. Somehow the innertube gets fragilized on those holes...
So I've ordered veloplugs, fitted them to the rim, and then I putted 2 layers of stans tape and voilá.. it's solved... :)
Best regards,
Filipe Dias
PostPosted: Tue Jun 11, 2013 8:48 pm
Why do so many people use tubes and clinchers on tubeless rims? I don't get the logic.
PostPosted: Wed Jun 12, 2013 12:38 am
You need two layers of tape.
formerly rruff...
PostPosted: Wed Jun 12, 2013 12:40 am
That is a completely different issue than what we are discussing here, and did you use two layers of tape?
formerly rruff...
PostPosted: Wed Jun 12, 2013 1:18 am
Been riding 340s with clinchers for a couple years. Last 6-12 months or so, both wheels have been upgraded to the slightly beefier, newer rim version after each eventually got cracks where spokes were pulling through the rims. I exclusively ride Veloflex on them. For a while now, it's been Corsa 22s or 23s.
I've experienced no problems on them whatsoever. They saw some hard racing until I switched to tubulars for that. I do my intervals on them, fast descents and some pretty mean group rides on them with no worries. If anything, Veloflex tires are rather hard to install on them (by hand - no tire lever). Based on my experiences, I've absolutely no worries riding them, even after reading this topic, although I'd be really wary now were I to fit other tires or find a tire that was too stretched as to be easier on the install. Ymmv. Be safe!
PostPosted: Thu Jun 13, 2013 8:20 pm
I'm starting to think it's high inflation pressure in a number of these cases. The above 120psi with a 25mm tire on a 340 rim (effectively more like 27mm) is very high - which negates all the benefits of higher volume tires too.
I'm a fan of red veloplugs on 340 rims - just have to push down hard when installing so they lock in place and conform to the curve better. A screwdriver handle will save your fingers some wear and tear.
PostPosted: Thu Jun 13, 2013 8:43 pm
FWIW I ride Veloflex on these rims from around ~95-110, depending on conditions, and have never once had a problem.
I'm currently using two layers of tape, but have also used the red veloplugs on these rims.
There are no new unread posts for this topic. Textured Tires on trainer
misterq
Sat Sep 16, 2017 10:38 am
Kaboom View the latest post
There are no new unread posts for this topic. Winter tires recommendation
CallumRD1
Mon Oct 09, 2017 4:37 pm
CallumRD1 View the latest post
There are no new unread posts for this topic. Best tires for wet, rough roads
nemeseri
38
2656
Tue Aug 08, 2017 7:06 pm
Bigger Gear View the latest post
There are no new unread posts for this topic. Fast, light 700x20c tyres / tires?
kman
Mon Jan 02, 2017 11:44 am
kman View the latest post
There are no new unread posts for this topic. Attachment(s) Tubeless road tires don't work for everyone - discuss
[ Go to page: 116 17 18 19 20 ]
Lewn777
286
16864
Tue Nov 28, 2017 12:49 am
bm0p700f View the latest post
Users browsing this forum: beanbiken, Bing [Bot], Delorre, erik$, Google Adsense [Bot], jbentley, micky, nmx, sib, superdx, Yahoo [Bot] and 39 guests
