Post new topic Reply to topic  [ 76 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Oct 12, 2012 7:26 am
Only that it's a tad wider and because it doesn't have bead hooks the tyre sits more like it's on a 23mm rim.
It's also reportedly a bit stiffer.
They are different alloys too but I don't know what the practical implication of that is.
r o y g b i v
PostPosted: Fri Oct 12, 2012 12:17 pm
I had 3 blow off! 2 layers of 21mm Stan tape, (older rim ,Spada Oxygeno wheelset), Michelin airlight tube, Veloflex 22 tire: pumped to 100 psi, bike was in the living room, overnight I heard an explosion, front tire blew off. Next day rear tire blew off!!
I used then IRC pro light tubeless for 3000 km with no problem, mounted Vittoria light tube, Conti GP TT, no problem for 200 km, then in straight line, tire at 110 psi, 15 km/h, rear tire blew off!!
Now I'm scared with tube, and I've just put on IRC RBCC tubeless for fall/Winter season.
PostPosted: Fri Oct 12, 2012 4:56 pm
A nice thing about the bead socket design is that it makes the tire rounder and wider than a normal bead hook, which improves the ride and cornering, and maybe the rolling resistance. Typically the tire is ~2mm wider than on a normal rim of the same width. Plus the 340 rim is ~1.5mm wider than the XR200 anyway. And it's a little stiffer so you can use fewer spokes.
formerly rruff...
PostPosted: Fri Oct 12, 2012 5:04 pm
So the correct taping method, and Veloflex and Conti GP TT coming off. Tires blowing off right after mounting *could* be caused by getting the tube pinched. Don't know how much experience you have and if you've ever had this happen with another rim.
formerly rruff...
PostPosted: Fri Oct 12, 2012 6:44 pm
mounted hundreds tires,never used tire levers, never had any issue like this with any of my wheels!e
PostPosted: Sat Oct 13, 2012 3:14 am
Never had issues myself. I had the old ones (light ones), and rode about 4000km on them. No issues. Using both latex and butyl tubes paired with Veloflex Corsa's which I can mount by hand. I recently had the eyelets crack on the rear drive side, so now I have the newer heavier version on there. Still no issues with that setup. This is all configured with the 2 layers of 21mm tape from Notubes. Just adding to the pool of experiences.
PostPosted: Sat Oct 13, 2012 7:00 am
I was hoping to discover that no one had blow offs with two layers of 21mm tape, but that doesn't seem to be the case.
It would be nice if there was a foolproof protocol, but I'm not seeing it at the moment.
formerly rruff...
PostPosted: Sat Oct 13, 2012 7:29 am
So i runs stans alpha 340, laced 20/24 to white ind.
I run gp400s and no rim tape but i use velo plugs.
I have done about 5000km with not one flat or Tyre roll off.
This scares me at some of the speeds my group rides hit.
PostPosted: Thu Oct 25, 2012 1:40 am
This just happened to me on a new style Stans 340
Conti 4000S
100 psi
been mounted for a couple months
10 minutes into a easy ride
on flat straight road.
Now I'm concerned I have some wheels that could kill me.
2013 Cannondale F-Series 29'er, Carbon 3
2012 Cannondale CAAD10-1 custom build, 14.06 lbs
2011 Specialized Crux, Alloy
2009 Specialized Roubaix Pro SL SRAM Red
1980 Palo Alto custom build
PostPosted: Thu Oct 25, 2012 3:50 am
Different rims bit I've had alot of trouble with GP4000s blowing off... I've had 10+ blow offs over 2years...
Rims used - Dura-ace C50 7850 & 7900
I had the rim replaced thinking it was a bead issue but it still persists (thanks shimano). Mainly happens under breaking and descending, ie when rim heats up... Tyre never inflated more than 110psi. I run 95 now for more peace of mind. I've also had Gp4000s blow off straight after CO2 inflation. I've also had a couple blow off after pumping up with my (accurate) track pump if I inflate to 120psi... Commonly within a few minutes the tyre will blow off while the bike is sitting still on its stand.
On every occasion the bead is checked and seated correctly before inflation to eliminate this as an issue...
Never had this issue when using GP4000s on my Zipp 404/303s however...
PostPosted: Fri Oct 26, 2012 3:23 am
zipp rims with aluminum brake tracks are very, very tight. it would be almost impossible to mount a tire on them with a part of a tube under one of the beads.
i know you all are going to deny this one strongly, but i would guess that *most* of these are related to having at least part of a tube stuck under the bead. often, a pinched tube is obvious after inflation, but sometimes the visual clue is much more subtle. in these situations involving a history of blowouts, after the tire is mounted but before inflation, i pull the bead back and make sure there is no tube visible. i check this all the way around and on both sides. it takes much less time than a long walk home.
PostPosted: Fri Oct 26, 2012 3:49 am
I'll be the first to deny.... Given I use green tubes, when I check the beads on both sides it's obvious if the tube isn't seated within the tyre belly... If it isn't, then it's massaged in before seating the bead...
I can understand however that if one isn't paying close attention, what u describe above is certainly going to cause blowoffs
PostPosted: Fri Oct 26, 2012 4:25 am
Red Veloplugs + Vittoria Corsa Evo SC + Conti Supersonic tubes + Stans Alpha 340 = never a single issue...
(20/24 on Extralite hubs SX/SLX ~ I'm between 155-165lb)
PS. confirming I have the older light rim...
PostPosted: Fri Oct 26, 2012 5:53 pm
That sounds like a tube getting pinched... which is something entirely different.
Did the tires fit tight when you installed them?
formerly rruff...
PostPosted: Fri Oct 26, 2012 5:57 pm
How was your rim taped?
Was the tire new when installed?
Was it tight?
formerly rruff...
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
Users browsing this forum: CarlosFerreiro, Google Adsense [Bot], lechat, thprice and 44 guests
There are no new unread posts for this topic. Attachment(s) Stan's ate my rims.... WARNING
hotshod
25
2859
Sun Mar 03, 2013 9:53 am
hawiken View the latest post
There are no new unread posts for this topic. Tire suggestion for stans ztr alpha 340 rims
fitty4
20
1386
Thu Jan 17, 2013 7:53 pm
MarkMcM View the latest post
There are no new unread posts for this topic. Stan's tube sealant
sungerdds
Fri Oct 19, 2012 2:46 am
Getter View the latest post
There are no new unread posts for this topic. Veloplugs or Stan's on Shimano RS80's
btompkins0112
19
1005
Thu Sep 06, 2012 12:10 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Tune Mag 170 & Mig 70 with Alpha 340 's
nelson
14
1728
Tue Sep 04, 2012 12:22 pm
sjc166 View the latest post
It is currently Wed Jun 19, 2013 1:02 am
